OSB Question. Vs Plywood? - General Discussion - Contractor Talk
Old 05-29-2009, 08:03 AM   #1
enforcer's Avatar
Trade: windows-siding
i am siding over some aspestas(spelling) with fiber cement board..i need a rigid surface so i simply cannot rely on insulation board.. someone reommended OSB ,either 1/4 or 7/16 to use over the existing shingles..
my question is how good is OSB for this type of application? how is it better or on par with plywood? i know if OSB is cut,it can be prone to water damage,however i will tyvel over it so cutting it will not be a factor?
enforcer is offline
Old 05-29-2009, 08:05 AM   #2
Lack Of All Trades
Darwin's Avatar
Trade: Construction & Home Improvement Services
Re: OSB Question. Vs Plywood?
OSB is just as strong as plywood but doesn't cost as much.
Darwin is offline
Old 05-29-2009, 08:20 AM   #3
enforcer's Avatar
how bout as wall sheathing? water ect...?
enforcer is offline
Old 05-29-2009, 04:26 PM   #4
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
I would use either Advantech(OSB) or CDX fir plywood, 1/2" thickness. Advantech is very resistant to moisture and swelling, some OSB products are less resistant. Fir plywood, 4 and 5 ply is equally acceptable for this app.
loneframer is offline
Old 05-29-2009, 04:33 PM   #5
OGStilts's Avatar
aspestas(spelling)
Ok at some point you've just got to say to yourself, it's worth 30 seconds for me to hit the spell check button so I don't look like a fool.
Thanks for the laugh.
OGStilts is offline
Old 05-29-2009, 04:38 PM   #6
KemoSabe
loneframer's Avatar
Follow manufacturers recommendations for spacing, (1/8" all sides,) regardless of whether you use plywood or OSB. I have used OSB on many homes and prefer OSB overall. Advantech is top dog in OSB in my opinion.
Old 05-29-2009, 04:42 PM   #7
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Another vote for Advantech.
-Dennis
WarriorWithWood is offline
Old 05-29-2009, 04:42 PM   #8
advanced_energy's Avatar
Rewards Points: 75
are you using 1/2" OSB over the original siding he's talking about "loneframer"? 1/8' gaps?
advanced_energy is offline
Old 05-29-2009, 04:52 PM   #9
KemoSabe
loneframer's Avatar
Manufacturers recommend 1/8" spacing on all edges, I have practiced this for the last 12 years. Regardless of whether you use OSB or plywood, the gaps will close up to some degree with high relative humidity, sometimes to the point of non-existance. If it is not gapped it will bind and either pucker at the edges or "washboard" between studs. Same goes for T&G, always gap the edges.
Old 05-29-2009, 04:57 PM   #10
Crock's Avatar
Trade: Fan of Bodger
Rewards Points: 250
and the tyvel its cheaper than tyvek
Crock is offline
Old 05-29-2009, 07:56 PM   #11
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 434
I have a neighbor who's a good guy, but also a four-eyed geek. He built his own house over a period of several years, researching each step and skill needed in excruciating detail. Somehow he missed that one.
He sheathed the house in plywood cut with micrometer accuracy and fitted so tightly together that you couldn't get a gnat's eyelash through the cracks.
Just about every single sheet wound up bulging like a bullfrog in full song. and he had to cut big X's in them to relieve the pressure.
Ditto, but I generally don't use it for wall sheathing. The cost is justified for floors that might catch a couple of rains before you're dried in, but walls don't usually get soaked during construction, and after you're done, they shouldn't be getting wet at all.
Tinstaafl is online now
Old 05-29-2009, 08:08 PM   #12
AustinDB's Avatar
Rewards Points: 1,426
my recommendation would be to use the cheap 7/16" osb-at less than $6/sheet, it's much more cost effective as compared to plywood/advantech.
what is the purpose of the wall sheathing-is it to keep the broken asbestos shingles in place after they break from being punctured with nails? If so, 7/16" is fine. If you're looking to make a nice flat surfce, the plywood may have more resilence to flexing (4ply vs 3ply)-if you've got money to burn that is. nail at the bottom of each shingle lap-nailing between the bottom of the lap and the top could introduce bowing in the sheating.
AustinDB is online now
Old 05-29-2009, 09:16 PM   #13
AndrewHess's Avatar
Rewards Points: 25
I ran it through my spell check and my computer started smoking.
AndrewHess is offline
Old 05-29-2009, 09:23 PM   #14
KemoSabe
loneframer's Avatar
That is just one of the reasons that I sheath my walls after standing, usually just before starting the roof framing. BTW, I used 7/16 OSB on the walls of my own home, plywood on the floors and roof.
Old 05-29-2009, 09:25 PM   #15
KemoSabe
loneframer's Avatar
I agree with everything stated in the above post.
Question from lawyer trying to help contractor scp Business 52 02-25-2011 01:23 AM
Question for GC re: rough/final cleans britanie General Discussion 6 06-07-2009 06:42 PM
Quick weather question Just-In-Time Masonry 9 11-19-2008 06:38 AM
Underlayment question AustinDB Roofing 12 10-17-2008 12:19 PM
OSB vs. CDX FRAMERBEN Framing 51 10-16-2008 06:57 PM
