Old Gasoline - Ok Enough In Large Vehicles? - General Discussion - Contractor Talk
Old 04-17-2016, 10:56 AM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,533
So what would you folks do with a measly gallon or less of 5-month-old gas? More specifically, has anyone simply blended it with a full tank into their large vehicles (without ill effect)? That's the most tempting option right now.
MarkJames is online now
Old 04-17-2016, 11:01 AM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,588
Re: Old Gasoline - Ok Enough In Large Vehicles?
I put it in the lawn mower. Just got rid of 10 gallons that I had no idea how long they were in the cans for, before I bought them at an auction.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
tedanderson (04-17-2016)
Old 04-17-2016, 11:02 AM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,114
Heck yes I've run older gas than that.
Inner10 is online now
MarkJames (04-17-2016)
Old 04-17-2016, 11:06 AM   #4
MarkJames's Avatar
To better understand....it would be ok to use in a mower, but not let gas "sit and go bad" in a mower to gum up the carb?
Old 04-17-2016, 11:08 AM   #5
I like Green things
Probably, but I don't always do what I know I should.
Warner Mill Works
Facebook
YouTube
Old 04-17-2016, 11:11 AM   #6
Inner10's Avatar
I wouldn't dump it in the mower because you may not be able to start it. The longer it sits the less volatile it is.
Old 04-17-2016, 11:11 AM   #7
I like Green things
starting fluid....
Warner Mill Works
Facebook
YouTube
EthanB (04-20-2016)
Old 04-17-2016, 11:13 AM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,355
I might think twice about using that in a finicky two-cycle, but anywhere else I wouldn't worry if it was a year old.
Tinstaafl is online now
Tom Struble (04-17-2016)
Old 04-17-2016, 11:25 AM   #9
MarkJames's Avatar
Thanks for the info. I'm just going to pour it into a vehicle and be done with it.
I've gummed up more lawnmowers by leaving gas over winter than I care to remember. I finally left them dry this year, thankfully. Not going to tempt fate.
Old 04-17-2016, 02:53 PM   #10
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,052
I wouldnt dump it in a small engine but i usually mix it in with my truck when the tank is pretty full so it mixes well with the fresh gas
Windycity is online now
The Following 4 Users Say Thank You to Windycity For This Useful Post:
concretemasonry (04-23-2016), dayexco (04-19-2016), fjn (04-17-2016), Golden view (04-20-2016)
Old 04-17-2016, 03:37 PM   #11
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,509
^^^This^^^
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
Big Shoe (04-17-2016), tgeb (04-17-2016)
Old 04-17-2016, 04:19 PM   #12
Big Shoe's Avatar
Rewards Points: 1,910
I just burned through 20 gallons of 90 no ethanol in my truck. I pulled out of my boat. One year old, but did have stabil in it.
I've got five gallons of 50:1 from other boat going in next.
Been doing this my whole life. My dad showed me this.
No nasty gas.
Expect the Unexpected
Big Shoe is offline
Old 04-17-2016, 04:24 PM   #13
LRG WoodCrafting
Leo G's Avatar
Gas without ethanol will last a lot longer then gas with.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
dayexco (04-19-2016), Red Adobe (04-20-2016)
Old 04-17-2016, 06:06 PM   #14
fjn's Avatar
Trade: mason
Rewards Points: 10,718
I would not hesitate to dump old gas in a tank of new gas. Just be sensible with the ratio. Also,there are products that "refresh" old gas. I just became aware of them about 4 yrs. ago. A few of the big box stores around me carry it. Menard's is my usual go to place.
Here is just one of the brand names.
http://theepicenter.com/emergency-po...treatment.html
fjn is online now
Old 04-17-2016, 07:30 PM   #15
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,480
That's what I use also....
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Old 04-17-2016, 07:46 PM   #16
VinylHanger's Avatar
Rewards Points: 10,344
What if I have a couple gallons of what I think is mixed gas? Will adding mix oil still work in the weedeater if it's doubled, I don't have a running gas rig. I usually just dump a bit out and see the color, but I have one that is yellow and one that is blue. The blue I know is mixed, the other not so sure.
VinylHanger is online now
Old 04-17-2016, 07:54 PM   #17
Capra aegagrus
Tinstaafl's Avatar
Dump it. Might not hurt a 4-cycle, but if you're not sure, don't put it in a 2-cycle. Those things are the work of the devil.
tgeb (04-17-2016)
Old 04-20-2016, 05:01 PM   #18
Big Shoe's Avatar
Don't screw with gas/oil mix.
Mark one gas can with Sharpie for lawn tools only. I run all Stihls. 40/50:1 mix.
I also wrap blue painters tape on all lawn tool/boat cans. Wife knows the drill.
Big Shoe is offline
Old 04-20-2016, 08:38 PM   #19
pizalm's Avatar
Rewards Points: 810
The couple bucks you'd save messing with the crap gas won't be worth the headache.
pizalm is online now
Old 04-20-2016, 10:41 PM   #20
Mordekyle's Avatar
Rewards Points: 4,724
Pour it on some poison oak
Mordekyle is offline
Those of you with large crews - Managing tools, loss and damage pm_sup General Discussion 14 09-19-2013 06:33 PM
problem with a large order of pond products Outdr Contractr General Discussion 6 12-20-2012 07:51 AM
large format tile Video charimon Tiling 9 10-11-2012 09:38 PM
Lighting large live oaks Ironwood Land Outdoor Lighting 7 03-13-2010 03:42 PM
large scale tree removal AustinDB Landscaping 6 03-25-2009 09:39 PM
