Novice Question - Hardwood Flooring And Exterior Threshold - Page 2 - General Discussion - Contractor Talk
Old 08-12-2015, 10:51 AM   #21
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,306
Re: Novice Question - Hardwood Flooring And Exterior Threshold
Martial artist Bruce Lee urges us to "Be water." If I were a drop of water, I'm fairly sure I'd have a fairly easy time sneaking between that concrete and the wood floor/plywood. When all my raindrop friends arrived over the years, we'd have an easy time rotting the wood. The trip hazard is the least of your worries. Very poor detailing.
Kowboy is offline
Old 08-12-2015, 02:31 PM   #22
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Originally Posted by Tom Struble View Post
you don't set a door on the finish floor..period..
I guess I'm REALLY getting old or my attention span and reading comprehension is waning. I didn't realize I guess, that the door threshold was sitting on top of the finished floor.
I guess I thought they raised the door for some reason. I was focusing on the picture of that concrete extension on the outside of the door and wondering why it was even there.
There is no way that thing is NOT gonna leak.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 08-12-2015, 05:10 PM   #23
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
at least you're not as old as you will be next year..
Tom Struble is offline
Old 08-12-2015, 05:33 PM   #24
John the Builder
SmallTownGuy's Avatar
Rewards Points: 8,200
Hear that.
SmallTownGuy is offline
Old 08-12-2015, 06:37 PM   #25
oldfrt's Avatar
Rewards Points: 94
Originally Posted by TimelessQuality View Post
Notice his barefeet in the second pic.. The sign of a dedicated handyman
Maybe he just has short fingers..........................
May have been a better approach to have used PT under the door,leveled with the sub floor and a pan under the sill with a drip to cover the PT, set back a bit from the edge of that door sill.
Doors are always set before hardwood.
Still don't like that cement half step,real awkward to step over and on to the floor,plus being a rain trap.
oldfrt is offline
The Following User Says Thank You to oldfrt For This Useful Post:
Kowboy (08-12-2015)
Old 08-12-2015, 09:03 PM   #26
John the Builder
That filthy, nasty-azzed door has been hanging there for decades, and so has that pimply, scabbed over precast concrete sill and gray mud-dauber caulk.
I'm thinkin' the OP just got hold of some bad weed, and had a hard time figuring out why that threshold suddenly appeared.
Old 08-12-2015, 09:14 PM   #27
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,529
A mild thread hijack, if you will allow....
...are doors supposed to (always) be set before concrete landings and "stoops"? I ask this because I seem to run into stupid installs with townhome developments and multi-unit buildings where the concrete seems to have come later. Makes for a bit of a pita when swapping out an entry door. What's that about?
MarkJames is online now
Old 08-12-2015, 09:16 PM   #28
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,472
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Old 08-14-2015, 09:24 AM   #29
furlong's Avatar
Trade: handyman
Rewards Points: 4
Yes, exactly! The house has 3 doors. The flooring contractor removed the thresholds on 2 of the 3 (front and back) and didn't remove it on the garage door. So, the plywood and hardwood must be butting up against the garage door but it's under the other two doors. The garage door is what I consider normal, low threshold but the other two you really have to step over. The door frames were never removed, they just took the doors off the hinges and cut about 3" to 4" off the bottom and stuck them back on.
I've been busy at other jobs and haven't been back to the house to see what it looks like after being cleaned up. The owner that contracted with these guys is not happy with the ascetics and she is considering having them cut out the hardwood and subfloor and put new thresholds down at the slab level. Of course, that means replacing the two doors and a screen door that they cut down.
She went over and looked at some Toll Brothers model homes and she said they did it like that too (on top of the hardwood) but not with concrete shoved up under there, with brick. So, now she's torn about what to do. I think she should have them do it whatever way makes her happy or she'll stew over it for years, especially if people trip over it...
Thanks to everyone else for their feedback and yes guys, those are my pretty little piggies in the picture. Floor coated with polyurethane the day before so boot at front door. Didn't want to step out in that concrete mess in my socks!
furlong is offline
Old 08-15-2015, 08:57 AM   #30
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
If Jesus was a barefoot carpenter, then God was the GC.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
