Notched Joists - General Discussion - Contractor Talk
Notched Joists
Old 02-05-2019, 11:55 AM   #1
trcmag's Avatar
Trade: Residental Construction
Rewards Points: 6
Notched Joists
Is there any way of fixing these joists where the plumber notched out 2/3rds of the 3 joists?
Can I put metal strapping on the bottom, or maybe a bracket?
Any help would be awesome.
Thanks
trcmag is offline
Old 02-05-2019, 12:04 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,494
Re: Notched Joists
that's a lot of wood hacked out of there.
no supervision?
likely need an engineer to prescribe a fix for that mess.
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Calidecks (02-06-2019), greg24k (02-06-2019), sunkist (02-10-2019), trcmag (02-05-2019)
Old 02-05-2019, 01:11 PM   #3
builditguy's Avatar
Rewards Points: 1,362
Re: Notched Joists
As said above, an engineer might have an answer, if you are wanting to leave it as is. Possibly a flitch plate?
For me, I would cut out the plumbing, sister the joists, and find a new route for the plumbing pipes, which would avoid cutting anymore of the joists.
Of course there is a difference between notching a joist and drilling a hole.
builditguy is offline
The Following 3 Users Say Thank You to builditguy For This Useful Post:
Fouthgeneration (02-05-2019), Rooster Cogburn (02-05-2019), trcmag (02-05-2019)
Old 02-05-2019, 02:55 PM   #4
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 280
Re: Notched Joists
cut out that pipe and beat the plumber over the head with it.
Rooster Cogburn is offline
The Following 18 Users Say Thank You to Rooster Cogburn For This Useful Post:
Calidecks (02-06-2019), dayexco (02-05-2019), fjn (02-10-2019), goneelkn (02-05-2019), greg24k (02-06-2019), griz (02-05-2019), jimwalter (02-09-2019), Live Edge (02-12-2019), MarkJames (02-05-2019), onmywayup (02-06-2019), rblakes1 (02-06-2019), SouthonBeach (02-05-2019), tang (02-06-2019), tgeb (02-05-2019), trcmag (02-05-2019), WarnerConstInc. (02-06-2019), Xtrememtnbiker (02-05-2019), Youngin' (02-05-2019)
Old 02-05-2019, 04:05 PM   #5
Ed Hartmann's Avatar
Rewards Points: 220
Re: Notched Joists
Drop the pipe down into a soffit. Soffits aren't the greatest but they are better than structural failures.
Ed Hartmann is offline
The Following 8 Users Say Thank You to Ed Hartmann For This Useful Post:
Calidecks (02-06-2019), fjn (02-10-2019), greg24k (02-06-2019), hdavis (02-05-2019), Rio (02-06-2019), ScipioAfricanus (02-05-2019), SouthonBeach (02-05-2019), trcmag (02-05-2019)
Old 02-05-2019, 07:05 PM   #6
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,280
Re: Notched Joists
Beat the plumber and the GC. Is that a 4" pipe? Why so big? I see a lot of HO's run 4" waste lines when 3" is fine for more than one toilet.
Golden view is offline
trcmag (02-05-2019)
Old 02-05-2019, 07:12 PM   #7
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,290
Re: Notched Joists
All that work to save (1) $3.00 45į fitting.
Big Johnson is online now
trcmag (02-05-2019)
Old 02-05-2019, 07:14 PM   #8
Re: Notched Joists
Originally Posted by Rooster Cogburn View Post
cut out that pipe and beat the homeowner/diyer over the head with it.
trcmag (02-05-2019)
Old 02-05-2019, 07:14 PM   #9
edward trowelhands
Trade: Diplomat
Re: Notched Joists
Will the plumber pay for the electrician to remove and reinstall his wire too after you sister it?
trcmag (02-05-2019)
Old 02-05-2019, 07:19 PM   #10
Re: Notched Joists
Originally Posted by Golden view View Post
Will the homeowner/diyer pay for the homeowner/diyer to remove and reinstall his wire too after you sister it?
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
Golden view (02-05-2019), trcmag (02-05-2019)
Old 02-05-2019, 07:20 PM   #11
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,857
Re: Notched Joists
It's understandable. He probably didn't have the fitting, he was running late, and he still had to get back on the road.
MarkJames is online now
trcmag (02-05-2019)
Old 02-05-2019, 11:10 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,533
Re: Notched Joists
Two Long radius 90s or Four 1/4 bends= easy to snake, fewer plugs.
Run the DWV pipe into the left wall using correct high flow fittings,, re pair And or replace cut joists, go British and leave it exposed.
10" wide Crown mold?
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
trcmag (02-05-2019)
Old 02-05-2019, 11:58 PM   #13
trcmag's Avatar
Rewards Points: 6
Re: Notched Joists
Well, thank you all for your input. I have decided that because the ceiling is very tall that I will order THA213 hangers and hang 2x6 ceiling joists under all of the existing 2x8 joists and drop the ceiling. Basically a large soffit.
Do you see any problems with this? Besides how to hide the body of the plumber that did this?
trcmag is offline
The Following User Says Thank You to trcmag For This Useful Post:
Rooster Cogburn (02-06-2019)
Old 02-06-2019, 12:21 AM   #14
edward trowelhands
Trade: Diplomat
Re: Notched Joists
Good catch, those look like vent fittings.
trcmag (02-06-2019)
Old 02-06-2019, 01:28 AM   #15
Trade: Masonry
Re: Notched Joists
Note sideways studs, and "kneewall" issue as rimjoist/ plate???appears to be shifting off the 2" deep wall......
The elbows still need to be replaced with turd rated bends, is there a vent stack for code issues close enough for the stool to work correctly?
I love high ceilings,you could screw on 2x6 sideways under the old joists everywhere, I'd still install some Simpson 1.5" wide straps under the notches. remember jack the old wood up to flat prior to attaching any new materials, so old material isn't over tensioned.
trcmag (02-06-2019)
Old 02-06-2019, 01:41 AM   #16
back doors to hell put in
Irishslave's Avatar
Rewards Points: 920
Re: Notched Joists
That PVC will support the floor load don't worry about it.
Seriously you could double up and header it but it would be a big PITA now.
Those look like vent elbows too. They aren't long sweep
Television is fake...The internet is real
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
trcmag (02-06-2019)
Old 02-06-2019, 07:38 AM   #17
Re: Notched Joists
Those arenít vent elbows, just standard. Iíve never seen a plumber around here use a long sweep, and they rarely use 45ís.
I finally asked my current plumber about it a while back and he said he likes to get the pipe close to a wall as soon as possible so 90ís are his way. I think itís because itís faster and easier to figure out the run. 45ing a run takes more precision.
This is a vent elbow:
Golden view (02-06-2019), trcmag (02-06-2019)
Old 02-06-2019, 08:19 AM   #18
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,604
Re: Notched Joists
That entire floor system is hosed. What an idiot.
Sent from my SM-N960U using Tapatalk
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 3 Users Say Thank You to WarnerConstInc. For This Useful Post:
greg24k (02-06-2019), tgeb (02-06-2019), trcmag (02-06-2019)
Old 02-06-2019, 09:05 AM   #19
tjbnwi's Avatar
Rewards Points: 3,706
Re: Notched Joists
I'm currently in Colorado. Here it is one vent through the roof, then AAV's.
Doesn't matter how large the house is or expansive the plumbing system is.
Being originally from Illinois, the system really is odd to me.
tjbnwi is online now
trcmag (02-06-2019)
Old 02-06-2019, 09:39 AM   #20
General Contractor
greg24k's Avatar
Rewards Points: 8,156
Re: Notched Joists
What Ed said, that would be the best solution and a less costly one to resolve this and drop the pipe into a soffit.
That said, what the other side looks like where the pipe is coming from? There is no wall nearby where that pipe can be dropped into the basement?
I mean I never had to run a sewer pipe or seen anything like this where there was a need to run a sewer pipe across the entire floor subframe even in the old Homes built from the '20s and up they never did that with a sewer pipe for the toilet, there is always a straight run between the joist cavity to the nearest wall to make the drop.
In some cases when faced with bathroom remodeling and when plumbing being re-routed because they want to move a toilet, etc and the toilet ends up in some location where there is nothing nearby to drop a pipe you would make floor joist modification to something like the picture attached, but any contractor or an architect always try to avoid sewer pipe re-routing because it can be costly.
I'm sure there is a much better way to get that pipe down because if the plumber did this he definitely doesn't know much what he is doing.
Forget about the straps or plates, you obviously don't know much yourself about the structure or floor loading to even think that. If you use straps or plates that floor will be like a trampoline and that if you don't end up collapsing the floor first.
greg24k is offline
trcmag (02-06-2019)
Deck joists in concrete block pockets and notched into steel beam Mr_Stop Decks & Fencing 17 01-13-2018 10:22 AM
Should we frame flooring joists? DavidReid1985 Flooring 2 10-05-2012 10:31 PM
Roof rafters, floor joists. Wood to mortar contact. Baltimore Masonry 16 08-04-2012 02:58 PM
notched floor joists illectric Framing 16 12-05-2011 10:03 AM
Joists Replacement While Maintaining Fire Escape Access? Lovegasoline General Discussion 17 11-19-2010 02:06 PM
