New Hardwood Deck Over Vinyl Duradeck - General Discussion - Contractor Talk
Old 04-27-2013, 09:19 PM   #1
jonno38's Avatar
Trade: carpenter
I have a client that wants a Red Belau Hardwood deck and pergola over and existing vinyl Dura deck. I am wondering if anyone out there has run into a similar situation and what their solution was. My first instinct was to go over it with a waterproofing membrane and then sleepers on top of that. Then I thought that it may be better to remove the vinyl first. I don't suppose that going right over the Dura deck with sleepers in elastomeric sealant is a good idea, right?
Any input would be much appreciated. Thanks
jonno38 is offline
Old 04-27-2013, 09:54 PM   #2
C2projects's Avatar
Trade: General Contracting
Rewards Points: 1,084
Re: New Hardwood Deck Over Vinyl Duradeck
I always recommend starting fresh. And I would push it pretty hard. I feel more comfortable with something I have built over adding onto what someone else has done. In which case with the wood they are going (atleast with what it costs here) with the cost to tear down and rebuild would be quite minimal in comparison.
If they will not be swayed then make it very clear that if something were to happen you're not reliable because of the direction they chose to go.
In this case you shouldn't need a water proofing membrane because that is the job of the duradek. I would just make sure it is sloped properly away from the house. I would maybe consider rolling some landscape fabric underneath along with putting some 2x on the flat the keep it off the deck so if there is a spot that pools the boards aren't soaking in it.
Hope this helps
Proper Prior Planning Prevents Piss Poor Performance
C2projects is offline
Old 04-27-2013, 09:55 PM   #3
C2projects's Avatar
And the landscape fabric is only so you don't see the color of the duradek between the board gaps
Old 04-27-2013, 10:03 PM   #4
bmcquin's Avatar
Trade: deck builder
Rewards Points: 1,646
I make it very clear to anyone who I talk to that wants to re-skin a deck: : I will not, can not and won't offer a warranty of any type........and you're on your own with decking the manufacturer/supplier. Seems to make sense to most people.
bmcquin is offline
The Following User Says Thank You to bmcquin For This Useful Post:
CarpenterSFO (04-27-2013)
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 01:34 PM
Deck 1983 Bunited2 Decks & Fencing 5 11-27-2012 02:40 PM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 05:09 PM
Deck Fire greg24k General Discussion 8 10-10-2012 12:19 AM
Vinyl siding/ stain saga SwiftRes Windows, Siding and Doors 5 10-01-2012 09:26 PM
