New Construction Windows With Dark Interior Finish? - General Discussion - Contractor Talk
Old 02-06-2015, 06:07 PM   #1
erik123's Avatar
Trade: general carpentry
Rewards Points: 14
Hi Guys, Im having a bit of trouble finding new construction vinyl casement windows with both black/dark brown exterior AND interior finishes (including grills) The only options I can find are Anderson 400. They would work but are soooo over budget! The house has 65 windows... Lots of Companies make the dark exteriors but the interiors are white. This look and style is really becoming popular. I think many manufacturers will soon make these color options in an affordable vinyl.
Thanks for any thoughts or suggestions! Cheers Erik
erik123 is offline
Old 02-06-2015, 08:29 PM   #2
Delaware Mike's Avatar
Trade: window door siding contractor dealer
Rewards Points: 124
Re: New Construction Windows With Dark Interior Finish?
Soft-Lite had in the past with their older extrusions (Pro/Classic, Barrington, and Baindbridge series available with a medium brown int/exterior finish. It's a vinyl product and they offer integral factory installed nailing flanges. I don't know if they can do the nailing flange return and face in any other color but white or possible tan/almond.
I don't sell those lower lines from SL but it's worth a try. Several national building supply chains have accounts with Soft-Lite like Lansing. Good Luck.
Delaware Mike is offline
Old 02-06-2015, 08:35 PM   #3
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
talk to marvin the will do it special i think
pappagor is offline
Old 02-06-2015, 08:40 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,706
Marvin Integrity
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Jaws (02-06-2015)
Old 02-06-2015, 08:59 PM   #5
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 538
Vinyl already moves a lot compared to glass. Dark colors would really compound this.
EricBrancard is online now
Old 02-06-2015, 09:10 PM   #6
Rewards Points: 124
Soft-Lite sash to master frame tolerance should be loose enough provided a precision installation. Soft-Lite utilizes Q-lon weatherstripping unlike the rubber bulb system on a tighter tolerance unit like Sunrise. Chances are the SL color is too light in comparison to a darker bronze that was desired. I hate those brown vinyl windows myself and never do them unless my arm is twisted. Better play it safe and just put in some Eagles or just sub the job out to RBA LOL……….About that budget?
Old 02-06-2015, 09:19 PM   #7
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Aren't Anderson 400s pine interior?
Marvin would be my pick, but if Anderson is way over budget I doubt Marvin will be.
jlsconstruction is offline
Old 02-06-2015, 09:24 PM   #8
paul100's Avatar
Rewards Points: 60
Where are you located?
paul100 is offline
Old 02-06-2015, 09:32 PM   #9
Lettusbee's Avatar
Rewards Points: 1,136
Milgard has a "painted" finish option for the exteriors on their Vinyl Tuscany series. I've never asked if they will do that on the interior, but if you have a dealer close by that may be an option.
And yes, I agree that dark colors on vinyl windows are a bad idea.
Lettusbee is offline
Old 02-06-2015, 10:04 PM   #10
VinylHanger's Avatar
Rewards Points: 11,500
I get asked this three or five times every year. Usually to match an cedar interior and exterior.
Always a pain and haven't really found anything that is budget freindly. I found one manufacturer, can't remember who that would send them out for paint.
The window would be like 400 bucks and then another 400 bucks to paint it. That blows the budget for a 3x3 window.
This is for a full vinyl which is what people around here usually want.
VinylHanger is online now
Old 02-06-2015, 10:08 PM   #11
The Sheriff
Jaws's Avatar
Rewards Points: 13,092
Marvin Integrity. Marvin and Marvin Integrity is about all we install anymore. Great heat gain coefficient.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following User Says Thank You to Jaws For This Useful Post:
jlsconstruction (02-07-2015)
Old 02-08-2015, 05:15 PM   #12
EPAYNE's Avatar
Trade: Remodeling, Additions, Kitchens, Baths
Rewards Points: 56
I believe Quaker you can get black and brown. We installed vinyls with white exterior and brown interior recently.
EPAYNE is offline
Old 02-09-2015, 10:49 AM   #13
erik123's Avatar
Rewards Points: 14
Thanks so much guys! Thats alot of really great suggestions. I have sent the window scedule out for some new numbers and think we might have a great option. I really appreciate the time you guys took to help!
Paul100= the project is located in Baltimore County Maryland, Thanks
erik123 is offline
Old 02-09-2015, 07:22 PM   #14
paul100's Avatar
Rewards Points: 60
Try BF Rich windows out of Newark Delaware. I know that they have a program where they will apply a paint to their vinyl windows.
paul100 is offline
Old 02-09-2015, 11:58 PM   #15
Design/Build
EmmCeeDee's Avatar
Trade: Design/Build
Rewards Points: 660
We have used bronze Jeld-Wen A200s on a couple of projects and been happy with the results. They are aluminum and so might not work with traditional designs, but for contemporary projects they are not bad, and not that expensive either.
EmmCeeDee is offline
Current post (detailed) construction cleaning interior no windows sschiff Business 1 03-16-2013 07:42 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Reed Construction Data Launches SmartLead Grumpy General Discussion 0 12-18-2008 09:40 AM
A REAL riddle! AAPaint Off Topic (Non Trade) 122 09-08-2006 04:41 AM
