Need Suggestions On Specialty Caulking. - General Discussion - Contractor Talk
Old 06-10-2019, 05:06 PM   #1
Eric Vick's Avatar
Trade: Finish Carpentry
Rewards Points: 18
Looking for suggestions on a caulking situation I have.
On the interior of my project I have a situation where stone flooring meets wood flooring. At the stone edge I have installed a Schluter strip to protect the edge of the limestone. Then, I have a 1/4Ē expansion gap before I get to the Wenge flooring. I read the expansion tables of Wenge and have determined that the width of my flooring will require a 7/16Ē total expansion in the event that the hardwood has a 1% moisture variance in EMC. I have divided that expansion in half since I need expansion at both edges. The Wenge flooring is pinned between two areas of stone flooring.
Now to my question:
I would like to install an architectural grade flexible caulking that will act as my expansion joint. I would like the caulk to sit flush with the flooring and be durable enough to walk on yet just supple enough to allow for movement.
I would like a colored caulking material since I will not be painting it. Dark brown or black would be best.
Many flexible caulks can remain slightly tacky and attract dust and dirt. I would like to avoid this.
Can anyone suggest a product?
Thanks,
Eric
Eric Vick is offline
Old 06-10-2019, 05:46 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,603
Re: Need Suggestions On Specialty Caulking.
That's not a caulk-friendly situation. You need a transition strip to allow for that sort of movement.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Bull Trout (06-10-2019), Rio (06-10-2019), Robie (06-10-2019)
Old 06-10-2019, 06:17 PM   #3
Eric Vick's Avatar
Rewards Points: 18
Yep, so true. Thing is that everything in this project is flush. It’s a $15million project. It’s been really fun and challenging. Some very unique challenges too. Anyway, any thoughts on a caulk product?
Old 06-10-2019, 06:35 PM   #4
Bull Trout's Avatar
Rewards Points: 618
Yeah, donít use it for that
Bull Trout is offline
The Following User Says Thank You to Bull Trout For This Useful Post:
SmallTownGuy (06-10-2019)
Old 06-10-2019, 06:45 PM   #5
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,122
Itís a $15million project.
buwahahahahah.....
SmallTownGuy is online now
Old 06-10-2019, 06:50 PM   #6
Eric Vick's Avatar
Rewards Points: 18
Clearly I’ve come to the wrong place.
Old 06-10-2019, 06:56 PM   #7
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 2,760
Do you have any pictures?
Idothat is offline
Old 06-10-2019, 07:01 PM   #8
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 1,236
Clearly Iíve come to the wrong place.
No, itís just that youíre asking for a lot here. The biggest problem being the dust magnet issue. Iíd prob look at something with a urethane for this application. Tower Tech 2 would work, but it will attract dust. You can check into Sika products. No matter what itís nit going to be flat, it will have a slight concave to it. Nature of the product. Youíll want to use a backer rod so the bead forms and hourglass shape otherwise itís not going to last through expansion/contraction cycles.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
overanalyze (06-10-2019)
Old 06-10-2019, 07:05 PM   #9
Radical Basement Dweller
Robie's Avatar
Rewards Points: 6,720
Would a flexible epoxy product work....poured into the gap and allowed to self level?
Could be tinted also.
Just thinking out loud.
When the debate is lost, slander becomes the tool of the losers.
Robie is offline
Old 06-10-2019, 07:05 PM   #10
Eric Vick's Avatar
Rewards Points: 18
Thanks,
I was leaning towards Sika although I was hoping for a water clean-up product. Great tip on the backer rod.
Old 06-10-2019, 07:07 PM   #11
Eric Vick's Avatar
Rewards Points: 18
Flexible epoxy:
Interesting thought. What name brand? I know most epoxy is pretty rigid but if there was a flexible one...might be the way to go.
Old 06-10-2019, 07:10 PM   #12
Thanks,
Frog tape on either side of the gap. Wipe the tape edge with a damp cloth to activate the agent that stops bleed through and you should be able to get a clean joint without making a mess on the flooring.
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
Eric Vick (06-10-2019), Idothat (06-10-2019)
Old 06-10-2019, 07:10 PM   #13
Robie's Avatar
Flexible epoxy:
I would call these folks. I use their products fairly often.
https://www.westsystem.com/specialty...ughened-epoxy/
Robie is offline
The Following 2 Users Say Thank You to Robie For This Useful Post:
Old 06-10-2019, 07:16 PM   #14
Eric Vick's Avatar
Rewards Points: 18
Thanks again fellas!
Old 06-10-2019, 07:59 PM   #15
1handygal's Avatar
Trade: paint, woodworking, general "handy" services
Rewards Points: 8
What about a urethane flexible grout product? Might something like that work?
1handygal is offline
Old 06-10-2019, 08:01 PM   #16
Eric Vick's Avatar
Rewards Points: 18
Iíll check it out. Thanks.
Old 06-10-2019, 09:51 PM   #17
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,585
Thinking way outside the box...caulk, let dry, then apply a grout colorant. Rinse and sweep several times after that.
(I told you it was outside the box...)
MarkJames is offline
Old 06-10-2019, 10:03 PM   #18
Texas Wax's Avatar
Rewards Points: 1,784
Look at Tremco caulks. Often what is spec'd (or comparable) for concrete expansion joints at walkways and such.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 06-11-2019, 08:52 AM   #19
AustinDB's Avatar
Rewards Points: 1,188
I can't comment on it's ability to not attract dust, but I've used Pergo's acrylic caulk before. I almost always use (just) a joint between my tile and wood flooring because it's clean and less of a trip hazard.
Last job I filled the 3/16 joint between the marble and engineered flooring with the same Mapie Flexcolor CQ grout used on the tile floor. It's not as flexible as a caulk joint, but it's not rigid like old fashioned grouts.
AustinDB is offline
The Following User Says Thank You to AustinDB For This Useful Post:
Eric Vick (06-11-2019)
Old 06-11-2019, 12:01 PM   #20
Eric Vick's Avatar
Rewards Points: 18
After some good head scratching last night I think I’ve decided to use Dap230 caulk which is paintable. Once the caulk cures I’ll put a couple coats of clear Diamond acrylic over it. Should be durable and dust resistant.
