Most Efficient Job Site Heater? - General Discussion - Contractor Talk
Old 01-31-2019, 11:37 AM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,478
I could sit down and do all the math, but I'm hoping someone here has an off-the-cuff assessment of these.
I'm looking at electric, propane, or kerosene.
I'm a little concerned about propane, because of the moisture issue. I'll be using it from framing through paint, and I don't want drywall to take 3 weeks to dry.
Not sure if kerosene has the same issue.
I'm guessing an electric heater would be pretty pricey to run?
I'm looking to heat between 1,000 and 2,000 SF at a time.
Thanks.
Get Off My Lawn.
Old 01-31-2019, 12:24 PM   #2
hdavis's Avatar
Rewards Points: 2,998
Re: Most Efficient Job Site Heater?
Up here, it's cheapest to temporarily set up a kerosene direct vent system like a used OM-22. They run about 23K BTU, so they don't put out the heat a torpedo does.
Some people put in an actual furnace temporarily.
hdavis is online now
Old 01-31-2019, 12:51 PM   #3
402joel's Avatar
Trade: carpenter
Rewards Points: 333
Iíve worked around diesel radiant heaters and I think they are the best
Similar to this
https://www.sunfireheater.com/
NRA Life Benefactor
SAF Life
402joel is online now
Old 01-31-2019, 08:45 PM   #4
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,700
Despite the cost, I prefer electric vs flames, refueling, vapor, odors, stains, etc.
With drywall, sometimes more heat costs less. 80 degrees plus a dehumidifier means a coat a day. 60 degrees and wet might be half the cost per day but 5x the days.
Half of all people are below average.
Golden view is online now
Old 01-31-2019, 09:03 PM   #5
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 248
Homeowner pays for electricity so itís cheapest for us.
We run diesel salamanders during the day until itís insulated and then switch to these
https://www.globalindustrial.com/p/h...er-15kw-240v-1
These things are badass, and they always work. We have had one for 15+ years? They make the meter spin but you can leave them on 24/7 because of the thermostat and no worries.
I can't compete with hacks.
donerightwyo is offline
Old 01-31-2019, 11:36 PM   #6
51carpenter's Avatar
Trade: Carpenter Contractor
Rewards Points: 428
The link didnít work for me.
Professional wood welder
51carpenter is online now
Old 01-31-2019, 11:41 PM   #7
Rewards Points: 428
I picked up a new diesel heater this fall, it lasted a couple days, then I returned it.
I always try to run electric heaters. Homeowner pays the bill, no fumes, and I donít have to buy fuel.
Old 02-01-2019, 12:30 AM   #8
Trade: Builder/GC
Thanks for all the info, guys.
Gonna have to check into a few of those.
Forgot about the diesel option.
Get Off My Lawn.
Old 02-01-2019, 07:57 AM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 2,804
If there is a gas service Schwank heaters are the go to here:
Inner10 is online now
Lady Dreamer (02-01-2019)
Old 02-01-2019, 11:37 PM   #10
Rewards Points: 248
Originally Posted by 51carpenter View Post
The link didn’t work for me.
Maybe this one....
https://www.grainger.com/product/FOS...r-Heater-3LY27
Old 02-02-2019, 09:59 AM   #11
edward trowelhands
Trade: Diplomat
It's worth noting that that big electric heater is only 50k btu but still requires an 80A breaker. If you need more heat, your only option might be fuel powered.
Old 02-02-2019, 10:29 AM   #12
Rewards Points: 248
RightIt takes a lot of juice, and we wire directly into the panel with a long cord we have on it. If you are leaving the heat on all the time though(insulated) it will heat a large area, and is worry free.
Old 02-02-2019, 12:15 PM   #13
Trade: Builder/GC
At .19 cents a KwH, it'll cost $70 a day to run.
I've been looking at those little propane heaters that attach right to the top of the tank.
Remember, my "low" temp here is 40. Brrrrr.......
Get Off My Lawn.
Old 02-02-2019, 12:27 PM   #14
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 4,292
Equiv to 40 lbs of propane
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Golden view (02-02-2019)
Old 02-02-2019, 01:23 PM   #15
edward trowelhands
Trade: Diplomat
Electric is usually very roughly double the cost of other heat sources.
Assuming you need to run it 24 hours, I'd still pay $35 a day extra to not pick up, haul, spill, connect, run out of fuel, and no fumes or moisture.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
donerightwyo (02-02-2019), Seven-Delta-FortyOne (02-02-2019)
Old 02-02-2019, 01:59 PM   #16
Trade: Builder/GC
Yep.
One of the advantages is not having to deal with fumes and CO in an enclosed structure.
Get Off My Lawn.
Old 02-02-2019, 02:59 PM   #17
Inner10's Avatar
That's running flat out...
Old 02-02-2019, 05:11 PM   #18
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,635
It is the 21st Century, the wet dangerous open flame heat is persona non grata on nearly all jobs here.
Use home style LP furnaces on the start to finish homes, spot heat with the diesel/kerosene heaters...
Change to N.Gas jets whenever N.G. available.
My old boss still use pot heaters, he has had the drive bys call the fire department, and they shut down the heaters WITH NO COURTESY call... several times the last two winters....
Un vented = WET = Silly IMHO
A used(removed from service) N.gas/LP furnace,is cheaper, quieter, and dryer.
use a couple flame proof fabric hot air trunks on a tee plenum.
use the air filter box, reduce indoor air\ pollution levels
Very large homes use 2 or 3 heaters, removing one as the home is tightened up.
Natural Gas right now is so much cheaper, buy the meter(~225.00$) if necessary, if it on or near site.
L.P. for rural gas free areas, but use large tanks(if you own one or two you can pick the dealer)
under 300 gallon tanks will cost far more the the bulk nurse tank.
One can leave out a basement window and put chimney thimble in...
Condensing furnaces chimneys are much simpler, other then you need back up heat to keep the water from freezing in the furnace, a couple of 100 Watt light bulbs.....
A few minutes one can install wheels and filter boxes on the furnace. along with the 24 Volt transformer and a thermostat wire & programmable t-stat.
Many times installed black pipe in place is the cheapest solution for temp piping. just label it and leave in place.
Keeping the house at the same temp and humidity as it future conditions will reduce moisture related call backs. using dehumidifiers everyday in a new home is a no- brainer for insuring your rep as a quality builders at a cost of only a few hundred dollars of electricity.
And of course a pleasant work space will attract higher quality workers and subs all winter long.
Fouthgeneration is offline
Old 02-02-2019, 06:44 PM   #19
edward trowelhands
Trade: Diplomat
Or do it how I used to: 12 month build cycle, maybe a little less with some later winter remodels.
Start when the ground thaws (June in Fairbanks Alaska), get insulation and permanent heat installed around September or October, do all inside finishes throughout the winter.
hdavis (02-02-2019)
Old 02-03-2019, 11:20 AM   #20
Rewards Points: 428
Those are pricy, probably work great.
Back Link Strategies. CGallagher Websites and SEO 20 08-08-2017 12:27 PM
Ideas from the group on my website/marketing Tidewater07 Marketing & Sales 31 01-18-2013 02:55 PM
Adding blog to web site gastek Websites and SEO 4 03-08-2012 05:59 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
