Metal Cut Off Wheel 7" On Table Saw - General Discussion - Contractor Talk
Old 03-14-2019, 02:39 PM   #1
rservices's Avatar
Rewards Points: 380
Has anyone put a metal cut off wheel 7" on a table saw. I need to trim a piece of stainless and this would give me a nice straight cut vs an angle grinder or a circular saw.
I have used it in a circular saw in the past will good results.
Any feedback would be great
thanks
rservices is offline
Old 03-14-2019, 04:23 PM   #2
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Re: Metal Cut Off Wheel 7" On Table Saw
No one in your parts with a shear ?, I might be inclined to try it has the s/s got a protective film If so it should slide on the table.
Still "Shakin" the tree boss
sunkist is offline
Old 03-14-2019, 10:13 PM   #3
rblakes1's Avatar
Rewards Points: 4,012
Sounds like a good excuse to buy a track saw
-Rich
rblakes1 is online now
Old 03-14-2019, 10:16 PM   #4
rblakes1's Avatar
You're likely going to discolor the metal using any type of saw. I'm with sunkist, I'd call around to metal fab places.
You could probably make a straight edge and use a nibbler if you wanted to do it yourself
-Rich
Old 03-15-2019, 12:24 PM   #5
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,302
Heck, just go to a local fab shop and pay them a couple bucks to cut what you need.
Fishindude is online now
Old 03-15-2019, 09:52 PM   #6
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 484
Yeah, I've done it. Wasn't a big deal. Used to cut a lot of thin metal with a milwalkee metal blade.
https://www.amazon.com/Milwaukee-48-.../dp/B00023S32C
pinwheel is offline
Old 03-16-2019, 06:35 PM   #7
dayexco's Avatar
Rewards Points: 762
Water torch
Sent from my SCH-I545 using Tapatalk
dayexco is online now
Old 03-17-2019, 08:09 AM   #8
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 322
I use a metal blade occasionally on my table saw. I've only cut light gauge aluminum for window trim. I'm not sure about stainless steel. Make sure to use a full face shield.
rjconstructs is offline
Old 03-18-2019, 11:56 AM   #9
test
cedarboarder's Avatar
Trade: General
Rewards Points: 815
Crappy used blade and put the blade on backwards. I cut some rigid aluminum gutters that way and didn t have any issues.
Not sure about stainless steel tho.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 03-18-2019, 01:06 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
That works with thin steel that's used for roofing but I wouldn't do it on stainless.
Inner10 is offline
cedarboarder (03-18-2019)
Old 03-18-2019, 01:24 PM   #11
Texas Wax's Avatar
Rewards Points: 2,168
I say someone try it on stainless, get video
Plus a a sharp fresh blade, the right way, works helluva better than crappy old backwards on gutters, or Aluminum Siding or hell even vinyl siding (if cut from the back).
...as the page loads, so go the days of our lives, at CT
Texas Wax is online now
The Following User Says Thank You to Texas Wax For This Useful Post:
cedarboarder (03-20-2019)
Old 03-20-2019, 05:31 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,835
The cut out material will do real damage to the table saw.....
Remove sawdust prior to fire....
Excuse to buy a 4" to 14" cold cut metal saw????
I'm trying to do Zero abrasive cutting/grinding in most areas my shop, the grit destroys all machine parts, and the steel waste isn't much better for damaging/spoiling many types of finishes/coatings wood and metal.
Example, abraded Carbide ending up in rebuilt gas engine......
P.S. any evidence of metal cutting with wood designed tool, no purchase of same.....IMO
Fouthgeneration is offline
Old 03-21-2019, 08:32 AM   #13
Inner10's Avatar
I don't know what it is about stainless steel but everytime I have to deal with it I curse it. It starts to get hot, then it gets really hard and impossible to cut and snaps off the carbide teeth from your cutting device.
Inner10 is offline
cedarboarder (03-21-2019)
Old 03-27-2019, 11:14 PM   #14
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 5,482
i use a plasma cutter
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
New shop (table saw table) rservices General Discussion 9 06-12-2017 10:53 AM
Corrugated metal fence stanfordconst Decks & Fencing 2 05-31-2010 12:38 PM
Expanded Metal in Security Wall? RizzoMaryland Commercial Construction 17 03-03-2010 09:11 AM
