Manufactured Home Seismic Straps - General Discussion - Contractor Talk
Old 12-14-2018, 06:51 PM   #1
Mordekyle's Avatar
Rewards Points: 5,458
Looks like I have to tie down somebodyís house.
Anyone got Clif Notes?
Mordekyle is offline
Old 12-14-2018, 07:05 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 376
Re: Manufactured Home Seismic Straps
3 types i'm aware of.
auger, screw in
drive in, like a big spike with teeth
concrete wet set bolts
then cables or steel straps connect the two.
out here the state inspects mobile/modular homes.
check to see who has jurisdiction in your case and then determine what anchor to use.
griz is online now
Old 12-14-2018, 07:44 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 152
What are your specific needs?
I can probably come up with a solution for you.
Andy.
ScipioAfricanus is offline
Old 12-15-2018, 08:54 PM   #4
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,160
House or mobile home?
If house, I'm sure the local code enforcement office should be able to tell you the specifics.
dave_dj1 is offline
Old 12-15-2018, 11:36 PM   #5
Eater of sins.
Rewards Points: 152
I may be miss-remembering but I think that you are not in a seismic zone so you probably only need to worry about some uplift and wind shear (lateral loads) so I think you maybe would be interested in this thing. I love'em.
Andy.
Old 12-15-2018, 11:42 PM   #6
Eater of sins.
Rewards Points: 152
Or something more like this?
Andy.
Old 12-16-2018, 06:26 PM   #7
Mordekyle's Avatar
I talked to the inspector/engineer, who was somewhat helpful yet somewhat confusing.
He described a cable that loops around the steel I beams of the frame, angles toward the footing, and is anchored to the slab/runner with a concrete anchor. A bolt is turned which cinches the cable tight. Apparently the anchors go into the runners instead of the stem wall because they are reinforced while the stem walls may not be.
He couldnít think of a manufacturer or a part number.
Old 12-16-2018, 06:38 PM   #8
Mordekyle's Avatar
Old 12-17-2018, 07:05 PM   #9
Mordekyle's Avatar
Perfect, I found some in Portland and my brother is fetching them for me.
Old 12-18-2018, 08:22 AM   #10
Joasis's Avatar
Rewards Points: 604
Every mobile home I have ever seen has those...being in tornado country means they are a necessity.
Believe it or not, the way the installers put these in is either with a power auger head with an attachment to screw the anchors, or no kidding, a water hose pushed into the ground and then a rod turning the anchor in like a big screw.
I suppose they work in straight line winds, but after a real storm, they are laying there in the debris field.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 12-18-2018, 11:27 PM   #11
Mordekyle's Avatar
Iíll be installing them tomorrow.
5/8Ē redhead into the concrete that runs the perimeter. The ground anchors/augers look like a real pain.
16 straps.
Old 12-18-2018, 11:31 PM   #12
Mordekyle's Avatar
Iím glad my DIY worthy questions werenít taken as opportunity to bash my ignorance and inexperience. TY.
Then again, maybe yíall donít know much about them because you work on nicer houses than the dumps I work on.
Old 12-19-2018, 07:45 AM   #13
Joasis's Avatar
Rewards Points: 604
Your post count gives you a lot of latitude.
Besides, there are a lot of manufactured housing units being sold, and the market is growing. If I had to do more then a few of these, I would get a power post hole auger, a 2 stroke or 4 stroke, and make and connection to run the screws in the ground...because one thing I have seen..when the house is blown away, the screws are still in the ground...
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
The Following User Says Thank You to Joasis For This Useful Post:
Mordekyle (12-19-2018)
Old 12-19-2018, 07:59 AM   #14
MarkL's Avatar
Trade: Fencer
Rewards Points: 46
Perhaps it makes sense to check the magnitude of a possible earthquake in your area.
MarkL is offline
Old 12-22-2018, 10:59 AM   #15
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,830
Don't get ahead of yourself. I'm sure it's coming. Hahahaha
Sent from my E6810 using Tapatalk
CityDecks is online now
Old 12-22-2018, 11:03 AM   #16
CityDecks's Avatar
Trade: Deck Builder
CT is an place to figure chitt out. So resources experience and knowledge here. It's really impressive. My hat's off to all who contribute here. It's amazing how much I've learned over the years here. Thank you all. Happy holidays!
The Following User Says Thank You to CityDecks For This Useful Post:
asevereid (12-22-2018)
Old 12-22-2018, 11:11 AM   #17
CityDecks's Avatar
Trade: Deck Builder
I'm also glad that DIYr and h.o. get kabosh'd on here. It keeps keep pro to pro with a side razz. It reminds me of when I was growing up. There's was fee business owners clubs/ associations in town that I always heard about and was asked to join but didn't see the value because they where all in retail trade masonry, roofing supply ETC. I was in the food business back then and essentially fed them all. Now I realized what they did next to playing poker. They contributed to each other success. Get involved invilved with new developer's zoning etc. Give there blessing in way. Again really great full for the knowledge that's passed around here.
Old 12-22-2018, 01:28 PM   #18
Mordekyle's Avatar
Straps were done, and I replaced some rusted out metal pier jacks under another manufactured house.
The first one kicked my butt. I learned I need some elbow pads if I do any more work on these things. Concrete is hard on the elbows.
Replacing the blocks went well thanks to the fact there was a full slab under that one. Furniture dollies made hauling blocks in a lot easier for my two helpers.
I definitely learned some new tricks this week.
As CD said, this is a great forum for advice and practice and some good natured ribbing. I have learned a ton on here the last four years as well as contributed a little bit of advice, opinion, and ribbing.
Cheers and thanks to all. And a Merry Christmas.
The Following User Says Thank You to Mordekyle For This Useful Post:
CityDecks (12-22-2018)
Creating targeted list? LeeFowler Marketing & Sales 21 11-26-2012 05:03 PM
Vet Employment Issues at Home Depot? MAULEMALL Off Topic (Non Trade) 12 04-11-2012 06:01 PM
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 02:50 PM
The House of Tomorrow from the Recession Today NC2X4 General Discussion 11 02-28-2009 05:05 PM
Custom Home Builder vs. Spec and Tract Builder renet General Discussion 4 11-16-2008 01:51 AM
