Ledger Pulling Away From House - General Discussion - Contractor Talk
Old 06-30-2019, 08:07 PM   #1
micro123's Avatar
Trade: Framing
Rewards Points: 50
Took a look at a deck today. Pretty old. Everything looks ok except for a 3 foot section of the ledger that is pulling away from the house.
To be honest, I think it may be have been somehow built with that small portion of the ledger away from the house (meaning it hasn’t really pulled away - more just built that way). Because the joists are all toe nailed into the beams and those haven’t moved.
Ideas on best ways to fix this WITHOUT removing the nail connection holding all joists to the beans and shifting the deck toward the house on that end?
micro123 is offline
Old 06-30-2019, 08:11 PM   #2
micro123's Avatar
Trade: Framing
Rewards Points: 50
Re: Ledger Pulling Away From House
I should have included in the first post that the reason I’m looking at this is because there’s a big squeaking noise when you step in that area. Upon investigation, I found the big gap (don’t even know if that’s causing the squeak but it needs to be fixed). And when someone steps on that section, you can see the ledger in that area flex down.
micro123 is offline
Old 06-30-2019, 08:24 PM   #3
back doors to hell put in
Irishslave's Avatar
you could try to draw it in with a couple more bolts and plates or large washers, but it's only as good as what's behind it. A thru bolt of significant size would be best
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site.
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
TheConstruct (06-30-2019)
Old 06-30-2019, 08:26 PM   #4
Stunt Carpenter's Avatar
Rewards Points: 1,924
I would add some pressure to the outside edge of the deck when you try and pull it in. Just a simple spring brace would help things move more
https://builddaley.com/
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 06-30-2019, 08:31 PM   #5
micro123's Avatar
Trade: Framing
Rewards Points: 50
I drove a ledgerlok in just to see if it moved even a tiny bit.
Didn’t budge.
I’m thinking that it was built this way (evidenced by the fact that the joists are nailed to the beam, and there is no Evidence of them having moved at all)
So driving a larger bolt into the ledger may snug the ledger against the house, but it may also simply pull the joists off of the ledger (on that side - because they’re nailed to the beams).
micro123 is offline
Old 06-30-2019, 08:46 PM   #6
TheConstruct's Avatar
Rewards Points: 1,168
It would be interesting to see what it looks like to put a long straight edge right under the ledger along the wall there. If it was built that way I'd bet there is a big bump there. If the deck rim joist is straight I think it's safe to assume it was.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
Irishslave (06-30-2019)
Old 06-30-2019, 08:52 PM   #7
Tom M's Avatar
Rewards Points: 4,738
DDT's with threaded rod OR Place a carriage bolt in the ledger with a washer planned so a single ddt can grab it on a joist and then crank it in.
Not sure if this is a factor but Many times with sliding doors the rim joist loses the benefit of a wall, plates, floor and associated weight above it to resist wiggling away
Tom M is online now
The Following 2 Users Say Thank You to Tom M For This Useful Post:
Irishslave (06-30-2019), Tinstaafl (06-30-2019)
Old 06-30-2019, 09:04 PM   #8
I'd want to 100% sure it needs to suck in before doing it or you'll just be putting a lot of work into creating another problem. if it doesn't need to suck in you may want to slide some straight shims up behind it and suck it in with another lag or two. it may fix the squeak if there is some flex happening there on the existing lag.
Rio (06-30-2019)
Old 06-30-2019, 09:06 PM   #9
micro123's Avatar
Trade: Framing
Rewards Points: 50
Yep rim joist is straight.
Sliding glass door right above it. Interesting.
micro123 is offline
Old 06-30-2019, 09:08 PM   #10
micro123's Avatar
Trade: Framing
Rewards Points: 50
I can’t be sure it “needs” to, but I’m not super comfortable leaving a gap there. Especially because when someone walks there, I can visually see the ledger bounce down and then back up.
micro123 is offline
Old 06-30-2019, 09:12 PM   #11
That's why I'm thinking you need to pack the gap with something like a rip of 2x4 at the end and maybe one 12" in at whatever thickness it needs to be so the ledger can still be sucked tight even if it isn't against the rim joist. Assuming it doesn't need to move of course...
Old 06-30-2019, 09:45 PM   #12
Tom M's Avatar
Possibly cupped from day one.
Tom M is online now
Old 06-30-2019, 11:44 PM   #13
GC/carpenter
Calidecks's Avatar
Rewards Points: 22,498
Temp up the joists pull that section out and reinstall a thicker ledger. You may need to cut a few joists back to get maybe a doubler in there or a 3x. Then hanger it off.
Mike.
_______________
Calidecks is online now
greg24k (07-01-2019)
Old 07-01-2019, 12:55 AM   #14
Dirtywhiteboy's Avatar
Rewards Points: 11,680
Yupp^^^^ CaliDecks has the answer^^^
Dirtywhiteboy is offline
Calidecks (07-01-2019)
Old 07-01-2019, 10:36 AM   #15
fjn's Avatar
Trade: mason
Rewards Points: 10,952
Or,you can use these code compliant accouterments.
https://www.finehomebuilding.com/200...ment-for-decks
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
greg24k (07-01-2019), SmallTownGuy (07-01-2019)
Old 07-01-2019, 12:16 PM   #16
hdavis's Avatar
Rewards Points: 1,088
Ledger attached with nails? I can't imagine through bolts doing this...
hdavis is online now
Old 07-01-2019, 03:13 PM   #17
micro123's Avatar
Trade: Framing
Rewards Points: 50
Staggered nails spaced about 3" apart it looks.
micro123 is offline
Old 07-01-2019, 03:15 PM   #18
micro123's Avatar
Trade: Framing
Rewards Points: 50
Mike.
_______________
But that will cost more than the $200 they want to pay
micro123 is offline
Old 07-01-2019, 03:21 PM   #19
micro123's Avatar
Trade: Framing
Rewards Points: 50
That's just a holddown?
Are you saying to use it to pull the ledger in tigher or to simply support that end laterally?
micro123 is offline
Old 07-01-2019, 03:51 PM   #20
Tom M's Avatar
Yeah they're called ddt's deck tension ties they will draw.
You could even use hold Downs and through bolt
Tom M is online now
micro123 (07-01-2019)
