Laying Out A Radius With An Obstruction At The Origin. - General Discussion - Contractor Talk
Old 07-05-2015, 05:44 PM   #1
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Hey all.
I have been racking my brain for quite a while now and i still have not been able to figure out a way to layout this curve. As you can see the centre of the radius is behind a column that is already built so swinging it with a tape measure is sort of out of the question. I will use the total station if i have to but i was hoping to be able to learn the manual way of doing it (if there is one).
I experimented with shifting the point and reducing the radius but no go.
Plus the square return wall has no dimensions, it is all based on intersections..
Any advice is helpful.
Laying out a radius with an obstruction at the origin.-screen-shot-2015-07-05-6.40.21-pm.png
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 07-05-2015, 07:27 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 281
Re: Laying Out A Radius With An Obstruction At The Origin.
Nick:
Can you lay it out somewhere else and make a plywood template?
Easy Gibson
Warren is online now
The Following 4 Users Say Thank You to Warren For This Useful Post:
Builderbob 72 (07-05-2015), griz (07-05-2015), JesseCocozza (07-06-2015), Sir Mixalot (07-06-2015)
Old 07-05-2015, 07:30 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,484
Originally Posted by Warren View Post
Nick:
That's what I would do and then line it up with a few reference points that you can make on site.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 07-05-2015, 08:46 PM   #4
Forming and Framing
FramingPro's Avatar
What i had planned to do was make my plywood plates to the specified radius, nailed down the one side that i could measure too (left side in picture) , and strike the arc as far as i could and twist the loose end of the template to that. My only concern is that being able to only measure a 1/4 of the way on the radius could mean that it could potentially go out... Then again it can't possibly go off that much in 10 or 12' plus, there is no dimension on the plan.. nobody will check
Im looking forward to forming this, it will not only be round but also sloped at the same pitch as the future garage ramp. The ramp on this job is going to require some very funky formwork..20' tall in some spots!
Old 07-05-2015, 11:55 PM   #5
Railman's Avatar
Trade: Railing
Rewards Points: 583
There have been several great threads on this subject. Try a search for circle chord.
Here is a great excel spreadsheet to calculate out the coordinates that I linked in one of them:
http://home.comcast.net/~ronzu2/Wood...rc_layout.html
You will need to download the excel template calculator.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
CarpenterSFO (07-06-2015)
Old 07-06-2015, 04:14 AM   #6
Forming and Framing
FramingPro's Avatar
I was thinking of that formula do to do it with coordinates, i am not sure it will work because i do not have the end point of the curve where it turns into the straight wall.. therefore i cannot figure out the length of the arc.
The Following User Says Thank You to FramingPro For This Useful Post:
Metro M & L (07-06-2015)
Old 07-06-2015, 09:43 AM   #7
Railman's Avatar
Trade: Railing
Rewards Points: 583
Ok...I think I finally got what your trying to do!
Oops!... I had a bad solution!
Railman is offline
Old 07-06-2015, 11:37 AM   #8
GettingBy's Avatar
Rewards Points: 6,486
Originally Posted by FramingPro View Post
Hey all.
If this is part of circle as viewed from above, on paper you can bisect a scaled down version of this curve in at least two places to find the circle center, then the radius length, then the whole circle.
Then you have to account for the ramp.
I recommend making a large three dimensional model of this thing from shoebox cardboard, to check your work. Use toothpicks, tape, paper clips, glue, etc.
Take it a step at a time.
Officially this is called Descriptive Geometry and the method for doing this was once a State Secret.
I'm sort of up on this lately because there is a way to extract cube roots by visualizing a cube within a cube, along with several rectangles.
I could not visualize this thing so I made a model from paper. So now all I have to do is recall what this three-dimensional thing looked like.
You can do it, we can help!
GettingBy is offline
Old 07-06-2015, 04:20 PM   #9
GettingBy's Avatar
Scaling up from your drawing, the radius of the ramp viewed from above is 3.9 meters so the circumference is 12.3 m.
A protractor gives the angle as 50 deg so the length of the ramp viewed from above is 12.3 x 50/360 = 1.70 m.
Cut a piece of masonite 1.7 m long and draw a triangle on it with angles arctan 0.075 (= 4.29 deg), 90 and 90-4.29 deg. This is the ramp laid out flat.
Bend the masonite to a 3.9 radius. This is your ramp.
Placing the ramp relative to the shaded rectangle takes some more doing.
Old 07-06-2015, 08:50 PM   #10
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 710
Just demo that column out of there, layout the ramp, put column back.
www.gebcon.com
tgeb is online now
Old 07-08-2015, 07:37 AM   #11
maninthesea's Avatar
Trade: High Pressure Air
Rewards Points: 30
could you bend a pipe to an arc to fit just outside the column then lay out from the pipe?
maninthesea is offline
The Following User Says Thank You to maninthesea For This Useful Post:
Railman (07-08-2015)
Old 07-08-2015, 08:51 AM   #12
hdavis's Avatar
Rewards Points: 7,394
Here's one manual way - normally used when your framing square will do:
Place two nails (spikes, whatever) into the surface at two opposing points that will be on the circle. Place your square over the nails, and keep it in contact with the nails as you slide it around forming the arc of a circle that's traced out by the tip of the framing square.
For a big circle like you have, it's easiest to put a series of nails in along a (not quite complete) smaller circle that gets you out past the column (ideally same radius that gets you to the furthest point of the column, but that's getting picky), then use a loop of something that doesn't stretch too much and trace the final arc. Try string if you want, but it's imprecise.
hdavis is online now
Old 07-11-2015, 10:46 PM   #13
AGullion's Avatar
Rewards Points: 1,422
Make a template , cut it like a donut , then split it in 1/2 , then place it around the column .
AGullion is offline
Old 07-11-2015, 11:19 PM   #14
pritch's Avatar
Trade: superintendent
Rewards Points: 691
If you have access to a total station use it and be done with it. But there is a way to lay out circles with a theodolite sitting on the radius of the circle. I haven't used it in a while and would have trouble finding my notes just now, but if you want it, I'll try to find the formula.
My dad gave me concrete tools for my 18th birthday. 37 years later and I still haven't come up with a mean enough way to get him back.
pritch is offline
Laying treads... Rich D. Masonry 16 10-01-2013 02:46 PM
Batter in a radius curb Elyrain Concrete & Paving 1 09-20-2010 05:38 PM
radius rafter question FramingPro Framing 6 08-25-2010 06:28 PM
top rail radius sorethumbs Decks & Fencing 11 08-05-2009 12:31 AM
Matching a Radius TakePride General Discussion 15 10-29-2008 06:23 AM
