Kerosene Heater Questions - General Discussion - Contractor Talk
Old 01-29-2014, 05:50 PM   #1
90%-er
onmywayup's Avatar
Rewards Points: 2,450
Just bought a small kerosene heater for a walled off section of my pole barn. Supposed to be able to heat 1,000 square feet, so I figured it could easily warm up the 200 square foot room that I wanted to use as a warming station.
This room is in no way air tight, and I was under the impression that Kerosene burned "clean," but within a few minutes I had a hell of a smokey haze in the room and I put that thing out right away.
So I cut a hole in the roof of the room, and rigged up a real quick and dirty vent out of some very wide aluminum role that I had onhand. This effectively vented the smoke, but it also was sending about 60% of the heat out the hole, too.
I bought some of the kerosene alternative that Lowes sells, so is that crap the issue?
THis is my first foray into using one of these, so what am I missing?
onmywayup is offline
Old 01-29-2014, 06:55 PM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 182
Re: Kerosene Heater Questions
Initial smokiness from stuff used during manufacturer that needs to burn off would be my initial guess
Be warned though that when it is burning 100% properly one major byproduct is moisture, and if it isn't (not enough air, etc...) you can be looking at CO & other issues
Oh & you may also wish to check the manual to
SLSTech is offline
Old 01-29-2014, 06:58 PM   #3
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
Let me tell you first hand, these heaters emit huge amounts of warm, moist/ humid air, i have one in the place i am currently building and its causing quite a problem with the windows, skylight and doors sweating and icing.
I have not noticed any smoke or fumes ever.
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 01-29-2014, 07:04 PM   #4
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 358
turn the wick down as low as you can ..It will burn a little cleaner.
Never leave that fire hazard un watched .
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 01-29-2014, 07:08 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Your wick is probably too high.
Inner10 is offline
Old 01-29-2014, 08:12 PM   #6
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Make sure you're running k1 in there or prepare for the headaches..
ohiohomedoctor is offline
Old 01-29-2014, 08:16 PM   #7
SouthonBeach's Avatar
Rewards Points: 1,159
X3 on the wick too high.
SouthonBeach is offline
Old 01-29-2014, 08:19 PM   #8
Maybe TNT Rob will stop by to prove it is in fact way too low and outline that you cannot prove otherwise..
Old 01-29-2014, 08:28 PM   #9
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,196
I have the same unit you have and mine smokes a lot initially (first 5 10 min.) every time. Then its just heat with a little odor also humid like everyone else says.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
Mr Latone (02-02-2014)
Old 01-29-2014, 08:29 PM   #10
Also based on the pic its too close to combustible materials!
Old 01-29-2014, 10:39 PM   #11
90%-er
onmywayup's Avatar
Originally Posted by DaVinciRemodel View Post
Also based on the pic – it’s too close to combustible materials!
Thanks, that's just where I shoved it when I had to get it out of the way. I'm no MacArthur fellow, but I'm certainly bright enough not to burn down my pole barn.
Old 01-29-2014, 11:06 PM   #12
tyb525's Avatar
Trade: Remodeling and Carpentry
Kero always puts off CO no matter how clean it burns. It's usually not a problem, but in a tight house it can build up to be a problem. Pole barn should be fine.
Another reason ventless propane units shouldn't be used it a house IMO, they put off lots of moisture like kerosene.
I work for a GC, and I do woodworking as a hobby. I also cut most of my own lumber for that with a Woodmizer LT10 sawmill.
Dull tools cause accidents. Sharpen your tools before they get dull!
tyb525 is offline
Old 01-30-2014, 02:05 AM   #13
kiteman's Avatar
Rewards Points: 16
I remember these at my grandmother's house when I was a kid. There was just enough smell that you knew it was kerosene, but that's all.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 01-30-2014, 12:20 PM   #14
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
The flame should be around 1/2-3/4" high is all. Make sure the center adjustment inside the burner is centered, if it's off one side will be way high. Use good kerosene, and if the smell is bad they sell additives to change the smell.
In a 200 sf room they will burn you out of it. I use mine in a 24X24 garage and if its 20-30 out side it will be 80+ in a couple of hours. A little ventilation never hurts
1985gt is offline
Old 01-30-2014, 12:48 PM   #15
mako1's Avatar
Rewards Points: 1,094
I have had several of these.You really have to watch the height of the wick for it to burn good.The problem I had is that if I wanted to get something done in that area I did not want to wait 2 hours and burn fuel to do a 1/2 hr job.I bought a 175,000 btu salamander and can get my 24 X 26 garage from -0 to 65 degrees in about 15 minutes with diesel(which is cheaper) with less smell.
mako1 is offline
Old 01-30-2014, 12:54 PM   #16
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
Kerosene heaters can be OK once you learn how and where to use them.
When I met my wife, she lived in a leaning, shaking second floor apartment in CT directly on the Long Island sound where the window sills sprouted ever spring and the front door would not even close completely (and had no lock) because of the natural tilt. The wind would rock you to sleep and the kero heater was the only source of heat for 2 BR apartment. Talk about view and location!!! - No smell except from the Italian food below.
Her cat would curl up about a foot away and be content at all times regardless of the temperature of conditions outside, but you had to keep it toned down and run it for long periods.
If you run them properly at a lower level they do provide comfort. Somehow she learned to do it and hope she can to learn to drive well after over 20 years.
We lived in CT, Virginia Beach, northern MI and now in MN and every once in a while she wants to get a kero heater when it really gets cold.
Dick
concretemasonry is offline
Old 01-30-2014, 01:37 PM   #17
boman47k's Avatar
Rewards Points: 2,006
Ditto! This can make the thing smoke everything up and cover it in soot. Its like the wick is burning instead of the fuel. Seen it more than once.
If I fall dead, I hope I fall off a ladder, not this couch.
boman47k is offline
Old 01-30-2014, 01:56 PM   #18
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
It will burn the wicks up much faster. I just replaced the one in mine after 7 years of service.
I normally don't let anyone else light mine. My brother in law tried once about 2 weeks ago. We had the whole smokey garage thing happing. He thought he was going to start a fire and was pretty nervous about it. I "fixed" it and didn't tell him otherwise. Just told him he was real lucky. I doubt he tries to mess with it again.
1985gt is offline
Old 01-31-2014, 08:30 PM   #19
VinylHanger's Avatar
Rewards Points: 13,390
Those are great. Kerosene is expensive here though. I used to buy 2.5 gallons for 8 bucks which wasn't too bad. Now that same jug is almost 20 bucks.
Ours has been in retirement, but tomorrow we are pulling it out to use at the new place. It's drafty enough that the moisture shouldn't be a problem. Hopefully, the local fuel yard has bulk kerosene for much less.
VinylHanger is offline
Old 01-31-2014, 08:58 PM   #20
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Bulk should be much cheaper. I pay around 4.50 a gallon use to buy it at menards in the 2.5 gallon jugs when it was 9.99 now they are 18 or 19 for the same.
1985gt is offline
Water heater - on demand or tanked? G.C. Plumbing 2 09-06-2010 06:49 PM
California Framing Questions MTN REMODEL LLC Framing 33 09-04-2010 11:41 AM
