The Joys Of Working On Your Own House - General Discussion - Contractor Talk
Old 11-15-2019, 05:09 PM   #1
fred54's Avatar
Trade: contractor
Rewards Points: 304
UGH. Could use some advice to keep me from jumping off the ledge.
Renovating the bathroom over the garage. Probably 25 years old. Had a 2" mud base down so I pulled a lot of weight out of it. Pulled the subfloor so I can replace it while also insulating from above and found a mess.
Floor joists are 2 x 8's spanning 10 feet except on one end they are notched and sitting on a nailer so they're basically 2 x 6's at this point.
I'll fix that by adding in some blocking to the main beam and put in some joist hangers.
2 feet in, running perpendicular is a 3" pipe, NOTCHED out of the bottom of 3 consecutive joists and then reduced to 2" holes through the next two for the shower drain. Surprisingly, it is solid as a rock and hasn't sagged a bit even after 20 years with all that concrete. I can't (won't) reroute the plumbing and I have no room below to beef anything up as the garage below is already less than 8 feet.
I'm thinking of just getting some 1/4" steel plate and sistering the joists with it. I've done it in the past with an engineers ok-he actually kind of made fun of me for the overkill.
Just wanted to vent. I've already rewired, found 3 separate junction boxes buried under sheetrock as well as one group of 3 wires just taped together and tucked under insulation. Hacks hacks hacks.
If anyone has any bright ideas, I'm all ears. If this were a client I'd probably stop all work and spec the whole thing out but I'm trying to avoid it.
Thanks for listening.
fred54 is offline
The Following User Says Thank You to fred54 For This Useful Post:
SmallTownGuy (11-15-2019)
Old 11-15-2019, 06:30 PM   #2
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: The Joys Of Working On Your Own House
Slap some ply on the sides and glue & screw.
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
hdavis (11-15-2019)
Old 11-15-2019, 07:04 PM   #3
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,240
Maybe one of these:
https://www.metwood.com/joist-reinforcers/
Philament is offline
The Following 2 Users Say Thank You to Philament For This Useful Post:
fjn (11-17-2019), SmallTownGuy (11-15-2019)
Old 11-15-2019, 07:26 PM   #4
hdavis's Avatar
Rewards Points: 2,854
Floor joists SPF, Doug Fir, SYP, ...?
hdavis is online now
Old 11-15-2019, 07:46 PM   #5
hdavis's Avatar
Bridging or solid blocking will help spread the loads across joists and stiffen it up.
Steel plate is obviously the strongest fix, properly done.
Old 11-15-2019, 09:24 PM   #6
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Try this http://instafooting.com/product-info-joist-repair-kit/
video of math and where to place it
kevjob is offline
The Following 5 Users Say Thank You to kevjob For This Useful Post:
fjn (11-17-2019), Golden view (11-16-2019), hdavis (11-15-2019), Philament (11-16-2019), rblakes1 (11-16-2019)
Old 11-16-2019, 07:38 AM   #7
rblakes1's Avatar
Rewards Points: 4,068
Wish I'd known about these a month ago, could've been handy on the bathroom I'm doing
-Rich
rblakes1 is offline
Old 11-16-2019, 08:24 AM   #8
MarkJames's Avatar
Rewards Points: 19,665
I was having trouble figuring out how to run a shower drain so I called my plumber at the time. He came in and gave me a "top notch" job across a couple joists like it was no big deal. I wanted to bust him in the head with some of that pipe.
Add some plate, and use the stiffest/thickest subfloor ply you can fit. I did that for a marble bathroom and it was solid as a rock.
MarkJames is offline
Old 11-16-2019, 12:27 PM   #9
A2Zcontracting's Avatar
Trade: General Building
Rewards Points: 208
I feel you. I have a laundry list of stuff i still need to do to my own house and plumbing and floor repairs are at the top of the list. Sux knowing i wont be able to pass the cost off to someone else to get the job done right but i hate doing hack work on my own stuff.
Got some pics of the joist situation? How close to the hangers are the notches? Im sure adding steel plates would be more than enough to keep it solid. Hell, it should be stronger than if the joists were never cut.
Sent from my LM-Q710.FG using Tapatalk
A2Zcontracting is offline
Old 11-16-2019, 01:10 PM   #10
Remodeling GC
kevjob's Avatar
Rewards Points: 412
-Rich
I keep one on hand just in case, had to use my spare this week, plumber had to drill 2" hole where top of hole was 1.5" from top of joist to keep pitch for tub drain in 2x8 joists. Drilled his hole, I put strap on and he kept going.
Maybe didn't "need" it but for $50.00 it is peace of mind.
kevjob is offline
Old 11-17-2019, 11:30 AM   #11
fjn's Avatar
Trade: mason
Rewards Points: 11,202
This may help.
https://www.finehomebuilding.com/pdf/021184090.pdf
fjn is offline
Old 11-17-2019, 12:32 PM   #12
fred54's Avatar
Trade: contractor
Rewards Points: 304
all good stuff fellas thanks a ton. I am off the ledge. The engineer video also enlightened me that the notch at the end of the beam is OK. Up north with my building department it was a no no so it was ingrained in my head. (I'd rather use joist hangers anyway, notching seems like more work for less strength and less control over twisting or separating but that notch at the end was bugging me.)
I'm going to use the engineered solution that will help me sleep better at night, especially since he claims it will work on even a heavily notched beam on a 12 or 16 foot span.
Long live the nerds.
I've already added a beam and footings under the main level of my house that was sagging 2 full inches due to being 60 years old and having a dirt crawlspace. My "retirement" to Nashville is becoming the hardest job I've ever had, I miss having a crew of young and capable workers.
The first bathroom took me 9 weeks. I used to to do a total gut and redo in 2 weeks. Amazing what having 11 less people does to a timeline.
Anyway, thanks again, wish I could give half as much as I get from this forum.
fred54 is offline
The Following 3 Users Say Thank You to fred54 For This Useful Post:
fjn (11-17-2019), hdavis (11-17-2019), SmallTownGuy (11-17-2019)
Old 11-17-2019, 02:30 PM   #13
fjn's Avatar
Trade: mason
Item # 6 in the article I posted had a recommendation I read about 20 years ago also. It stated that with solid blocking,they need to be in line as opposed to the typical offset usually used. Has anyone ever read an alternate article to refute that mindset ?
fjn is offline
Old 11-17-2019, 06:44 PM   #14
hdavis's Avatar
I haven't read an article, but up to 1" offsets are allowed on single top plate - rafter connections. That's a similar structural situation.
fjn (11-17-2019)
Old 11-19-2019, 04:43 PM   #15
Remodeling GC
kevjob's Avatar
Rewards Points: 412
Originally Posted by kevjob View Post
They are selling them on Amazon now https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
$39.99 plus $4.49 for shipping. It's about what I paid them directly in May.
kevjob is offline
