Joist Reinforcing Strap - Page 2 - General Discussion - Contractor Talk
Old 05-15-2019, 08:54 PM   #21
hdavis's Avatar
Rewards Points: 2,494
Re: Joist Reinforcing Strap
Originally Posted by fjn View Post
It's tough to believe every once and awhile a monkey will fall out of a tree..........'cause they are real good climbers.
To rephrase, the screw spacing I see looks fine.
hdavis is offline
Calidecks (05-15-2019)
Old 05-16-2019, 09:24 AM   #22
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Originally Posted by rrk View Post
That was about 5 years ago and specifically about collar ties and roof rafter to ceiling joist connections. Too many nails destroys the wood fibers and weakens the wood.
Thank you ! The collar tie connection was what I thought was used as an example. I have struck out trying to pull that up in their archives. If it would not be a long search for you,I'd be appreciative if you could post up access to it.
fjn is offline
Old 05-16-2019, 09:29 AM   #23
fjn's Avatar
Trade: mason
By the way Rio,what is a stud shoe ?
fjn is offline
Old 05-16-2019, 09:49 AM   #24
hdavis's Avatar
Stud shoe is used to reinforce a stud when you have to run pipes through them.
hdavis is offline
The Following 3 Users Say Thank You to hdavis For This Useful Post:
fjn (05-16-2019), Rio (05-16-2019), Tom M (05-20-2019)
Old 05-16-2019, 11:54 AM   #25
Designer/Contractor
Rio's Avatar
Rewards Points: 524
I was thinking something like a combination of the two systems that Kevjob posted so in addition to being a strap on the bottom it would also go up the sides like a stud shoe does with a stud. That way there'd be double support.
Rio is offline
Old 05-16-2019, 01:08 PM   #26
Remodeling GC
kevjob's Avatar
Rewards Points: 396
The metwood one is like a stud shoe for joists but has limits of span etc...
kevjob is offline
Old 05-16-2019, 01:13 PM   #27
Remodeling GC
kevjob's Avatar
Rewards Points: 396
It might not be but just by looking at the photo it really looks like those have a pretty big diameter (because of their head size) and there really are a lot of them.
I was thinking something similar to a stud shoe would work really well.
They are these from Simpson https://www.homedepot.com/p/Simpson-...E&gclsrc=aw.ds
kevjob is offline
Old 05-16-2019, 01:35 PM   #28
hdavis's Avatar
The metwood ones are fully engineered for the application. There is no need for a strap with them, they cover 3 sides.
hdavis is offline
Old 05-16-2019, 02:18 PM   #29
Designer/Contractor
Rio's Avatar
Rewards Points: 524
The metwood photo shows a C section and it's not going under the member, it's going to the outside.......
Rio is offline
Old 05-16-2019, 03:00 PM   #30
Remodeling GC
kevjob's Avatar
Rewards Points: 396
There is also the Z shape to install flange over and or under joist.
kevjob is offline
The Following 2 Users Say Thank You to kevjob For This Useful Post:
hdavis (05-16-2019), Rio (05-16-2019)
Old 05-16-2019, 03:03 PM   #31
Remodeling GC
kevjob's Avatar
Rewards Points: 396
I have the report if anyone is interested. Email me at [email protected]
Can't upload too big, 13 pages
kevjob is offline
hammer7896 (05-20-2019), Rio (05-16-2019)
Old 05-16-2019, 05:35 PM   #32
hdavis's Avatar
I've only considered the z shape. The c has no lateral stiffness.
hdavis is offline
Old 05-19-2019, 07:27 PM   #33
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
I used the metwood one last year. It’s the same 2 piece bracket regardless of it you run it in C or Z configuration. I wish they would change the screws because they use a small square drive bit that really likes to slip. Otherwise it’s a nice product.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
hdavis (05-20-2019)
Old 05-20-2019, 09:29 AM   #34
fjn's Avatar
Trade: mason
Originally Posted by EricBrancard View Post
I used the metwood one last year. Itís the same 2 piece bracket regardless of it you run it in C or Z configuration. I wish they would change the screws because they use a small square drive bit that really likes to slip. Otherwise itís a nice product.
Wow ! Welcome back,you were missed on this forum. Stick around !
fjn is offline
EricBrancard (05-20-2019)
Old 05-20-2019, 06:06 PM   #35
Rewards Points: 986
Thanks, just visiting.
Old 05-20-2019, 06:12 PM   #36
fjn's Avatar
Trade: mason
Make it permanent you have input of value !
fjn is offline
Old 05-20-2019, 06:53 PM   #37
Tom M's Avatar
Rewards Points: 8,254
Those stud shoes are fairly new to the code and I'm surprised it such a loose citation. Studs could carry point loads from the second floor under long spans.
I don't recall seeing much on the Simpson book either as far as limitations.
I tend to think too many screws weaken the wood but I have sat in Simpson seminars and they show video of max performance and they perform as they claim
Tom M is offline
hdavis (05-21-2019)
balloon framing floor joist HELP Drywallchic Framing 26 07-31-2018 01:44 AM
Joist Hangers On Band Joist philcav7 Decks & Fencing 18 03-29-2014 12:52 PM
? Curbless shower with wood floor joist sycamorebob Tiling 8 11-04-2012 10:18 AM
Floor joist squeak problem MuttMutt Flooring 9 05-12-2012 01:17 PM
Replacing rotted rim joist entry door...first timer! r1dannyzx Carpentry 22 04-20-2011 04:06 PM
