Interior Condensation Causes And Solutions - General Discussion - Contractor Talk
Old 07-04-2020, 07:12 PM   #1
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Siding, & Additions
Rewards Points: 15,454
So this is my sister's house near Memphis, TN
There is a condensation issue on the hallway wall (highlighted below, yellow line is roughly the hallway area)
Only in that portion of the house.
Area is near a room addition, and a bathroom where the paint is peeling and blistering.
I'm assuming the addition section of roof was framed over the old roof.
Bathroom has no fan and window can't open. However that bathroom is not used much.
I am doing the roof Thanksgiving week and will do as much ventilation upgrade as possible. Currently there is gable vents and plywood soffit
Mom says the condensation is dirty. This has to be a ventilation issue right?
Sent from my SM-G988U using Tapatalk
A&E Exteriors is online now
Old 07-04-2020, 07:14 PM   #2
Re: Interior Condensation Causes And Solutions
Forgot pics.https://cloud.tapatalk.com/s/5f011b4a...2433680263.mp4
Old 07-04-2020, 08:44 PM   #3
Kingcarpenter1's Avatar
Trade: GC carpenter
Rewards Points: 8
Can’t tell in pic how the brick to roof is flashed. Could be a siding to brick issue maybe both. Check weepholes & slab exposure & drainage.
Kingcarpenter1 is online now
Old 07-04-2020, 09:07 PM   #4
Originally Posted by Kingcarpenter1 View Post
Canít tell in pic how the brick to roof is flashed. Could be a siding to brick issue maybe both. Check weepholes & slab exposure & drainage.
The tar is holding out the water. Condensation is at the other side of the house. This is not a rook leak
Old 07-04-2020, 11:44 PM   #5
Old 07-05-2020, 04:00 PM   #6
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 202
Ducts in the attic? On a crawl space?
Mostly written for winter months but many of principles remain... http://thehtrc.com/2015/faq-window-w...densation-iced
Find the humidity & stop it.
SLSTech is offline
The Following 2 Users Say Thank You to SLSTech For This Useful Post:
A&E Exteriors (07-05-2020), hdavis (07-05-2020)
Old 07-05-2020, 09:42 PM   #7
hdavis's Avatar
Rewards Points: 2,934
A quick, easy, and cheap first step is to get a non-contact thermometer and read temps on ceilings and walls. Something like a leaking AC supply boot in the attic can make a cold area. Combine that with a high humidity area, and you get condensation.
The original house had ventilation blocked off in that area when the addition was put on. That wouldn't help anything.
hdavis is online now
Old 07-05-2020, 09:51 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 2,694
are any of those addition walls are wrapped in visqueen??...
griz is online now
Old 07-05-2020, 11:00 PM   #9
I have no idea. I guess I need to fly down and find out.
Old 07-05-2020, 11:07 PM   #10
House is slab on grade.
Old 07-05-2020, 11:20 PM   #11
Fire up the BBQ
griz's Avatar
you may need to do exploratory surgery...
WRB/Visqueen?
are the walls insulated?
i know you don't think it's a roof leak...but????
gutter/window leaking?
hard to guess until you are boots on the ground.
good luck...
griz is online now
Old 07-05-2020, 11:53 PM   #12
WRB/Visqueen?
good luck...
I agree with you, it's all a guessing game till I get there.
I know it isn't a roof leak as the water is on the wall rain or no rain
The Following User Says Thank You to A&E Exteriors For This Useful Post:
griz (07-05-2020)
Old 07-05-2020, 11:54 PM   #13
I think SLS and HDavis are onto something with the ductwork
Old 07-06-2020, 05:44 AM   #14
META's Avatar
Trade: General and Trades
Rewards Points: 7,896
Is there a noticeable pattern, time of day and/or seasonal fluctuation to the condensation?
META is offline
Old 07-06-2020, 05:51 AM   #15
I am not entirely sure. Mom says it's always there
Old 07-06-2020, 05:58 AM   #16
META's Avatar
I am aiming towards a temperature issue, aka an insulation discrepancy or disparity between rooms and/or sections of home.
META is offline
The Following User Says Thank You to META For This Useful Post:
A&E Exteriors (07-06-2020)
Old 07-06-2020, 08:10 AM   #17
Correction. House has a crawlspace.
The Following 2 Users Say Thank You to A&E Exteriors For This Useful Post:
hdavis (07-06-2020), META (07-06-2020)
Old 07-06-2020, 10:49 AM   #18
Ductwork is in the crawlspace.
Old 07-06-2020, 11:05 AM   #19
META's Avatar
Is there an isolated brick wall internally?
META is offline
Old 07-06-2020, 11:22 AM   #20
hdavis's Avatar
Can't tell. This is all surface temp and humidity. If your sister gets a non contact thermometer, she can map out surface temps across ceilings and walls, random for cold spots. Pretty easy, pretty fast, and no real skill involved.
I've bought non-contact thermometers for as little as $15. Just do all the readings quickly and remember it won't be the most accurate, but for finding cold spots a cheap one works fine.
