Insulation Question.... - General Discussion - Contractor Talk
Old 11-20-2018, 06:30 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 3,756
Replaced a shutoff and drain valve at a beach house today. The main is 1' out in the yard and in the ground maybe 24".
The drain has been dripping for years and the supply line shutoff just started leaking.
I have a cavity probably 10" x 12" that extends down to where it hooks up with the main supply line.
Fiberglass insulation was there before. I'm wondering if blown in insulation would be better? I'd shove some heavy plastic down to keep it off the dirt and any moisture, then fill the cavity with blown in up to where the access door will be....and fiberglass stuffed in from there up another 2'.
Yes...no?
Thanks.
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is online now
Old 11-20-2018, 06:40 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 3,062
Re: Insulation Question....
i wouldn't use the blown in just for the hassle in removing it if you ever had to.
maybe wrap some batt(s) in a big garbage bag and stuff them in there.
i suppose the blown in stuff in a garbage bag would work also.
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
KAP (11-20-2018), Rio (11-21-2018), Robie (11-20-2018)
Old 11-20-2018, 06:43 PM   #3
hdavis's Avatar
Rewards Points: 4,408
I only use rock wool in areas that may become wet. Maybe foam, but insects love it unless it's used for foundation insulation, then it's treated.
hdavis is offline
The Following 5 Users Say Thank You to hdavis For This Useful Post:
P42003 (11-21-2018), Rio (11-21-2018), Robie (11-20-2018), rustyjames (11-22-2018), Tom M (11-20-2018)
Old 11-20-2018, 06:47 PM   #4
Robie's Avatar
Should the batts be stuffed down tight or not?
― Will Durant
Robie is online now
Old 11-20-2018, 07:26 PM   #5
Tom M's Avatar
Rewards Points: 13,124
Roxul would be the deal.
https://www.rockwool.com/products/roxul-safe/#Overview
Tom M is online now
The Following 4 Users Say Thank You to Tom M For This Useful Post:
hdavis (11-21-2018), Rio (11-21-2018), Robie (11-20-2018), rustyjames (11-22-2018)
Old 11-20-2018, 07:33 PM   #6
hdavis's Avatar
They just have to fill the cavity completely. Line the sides of the cavity leaving extra out the top, then fill with rock wool. As a practical matter, some of it is going to get compressed placing around pipes. You just have to get it snug.
Seal up the top of the plastic when you're done. You're just trying to keep water draining to the outside walls.
hdavis is offline
Robie (11-20-2018)
Old 11-20-2018, 08:39 PM   #7
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,834
As far as I understand compressing batts reduces the r value, but if you stuff it to capacity I'm sure itll make up for that loss. Some spots are impossible not to compress it a bit so its sort of moot.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
Robie (11-20-2018)
Old 11-21-2018, 07:39 PM   #8
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
I agree with HDavis regarding STONE wool (mineral wool):
"Water Repellent"
"ROCKWOOL stone wool is water repellent yet vapor permeable"
"The long-term R-value of stone wool is unaffected by moisture over time, due to the inherent drying potential of the product"
"Completely resistant to rot, mildew, mould and bacterial growth—contributing to a safer indoor environment"
** My thought is since it is water repelling and vapor permeable that it would be more likely to pass a small drip and allow it to evaporate out before freezing.
P42003 is offline
The Following 3 Users Say Thank You to P42003 For This Useful Post:
hdavis (11-21-2018), Rio (11-22-2018), Robie (11-21-2018)
Old 12-06-2018, 11:40 PM   #9
Robie's Avatar
Got everything taken care of...stuffed full of "Rockwool"...R-30...sealed all places air could come in and made a new panel for the front. Lip on the inside for the door to seal against and overlay frame on the outside for more weather protection.
Now if they remember to tighten the female hose connector when they drain the house...things should be good.
They won't.
― Will Durant
Robie is online now
hdavis (12-07-2018)
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Remodel Insulation Question brendanstl Remodeling 10 07-07-2010 07:39 PM
Insulation Blower? MEL Insulation 7 11-25-2009 12:07 AM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Insulation question. Rich Turley Remodeling 14 06-11-2006 02:21 PM
