Insulating Cold Air Returns - General Discussion - Contractor Talk
Old 12-31-2018, 01:26 AM   #1
Stunt Carpenter's Avatar
Rewards Points: 1,318
Hey Guys,
I’m in the process of finishing my basement and before I hang drywall I am going to be installing with mineral wool insulation.
My question is what the best practice is when the joist bays are being used as cold air return. I have two joist bays in the hallway off the main rec room that are essentially straight runs up into two of the second floor bedrooms.
Thanks
Stunt Carpenter is online now
Old 12-31-2018, 02:59 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 660
Re: Insulating Cold Air Returns
if you are going to insulate a joist bay to use as a cold air return, imo, you will need to isolate the return from the insulation to:
1) cut down on the coefficient of friction
2) eliminate any possible noise/whistling
3) eliminate any bits of insulation getting sucked into the system
i've seen insulation at the top of the return & bottom.
not sure if there is a right way. hvac guys chime in here.
also above or below, another way is to install a rectangular duct.
if no duct used the bay was sprayed with a heavy coat of paint to smooth it out, reference #1 & #2 above.
griz is offline
Old 12-31-2018, 08:29 AM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,430
If they are entirely in conditioned space now that the basement is getting finished, I don't see a reason to insulate them. Possibly smooth them out as Griz mentioned. We have to line them in metal here now.
Half of all people are below average.
Golden view is offline
Old 12-31-2018, 01:20 PM   #4
That’s what I figured. A lot of work to box it in for just some sound proofing
Old 12-31-2018, 01:21 PM   #5
It’s always been conditioned space. Referring to insulation for sounds dampening
Old 12-31-2018, 05:28 PM   #6
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 12
Joist bays can not be used as returns at least based off any modern code
Insulation can be used for soundproofing but more importantly to help stop condensation issues - if you have no worries about that then no worries. If not insulation depends on the ducts being used & there are a ton of threads on here about that. Best thing though is make sure all those ducts are sealed good
SLSTech is offline
Old 12-31-2018, 05:33 PM   #7
It’s how all the cold air returns in everyone house I have every worked on have been. From $300,000 spec homes up to 2mil customs. Plastic pan in unfinished basements and just drywall on both sides of a wall for the rest
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
donerightwyo (12-31-2018)
Old 12-31-2018, 07:19 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 2,288
Don't put insulation in it, it just turns into a dust magnet and you can't really blow it out in the future.
Inner10 is offline
Old 01-04-2019, 12:18 AM   #9
Thanks for all the advice.
I ended up making a box of drywall so to speak so that I could insulate the bottom on the joist bay without having insulation in the cold air return.
Cold floor Old Truck Flooring 8 01-25-2011 12:28 PM
Direct vent water heater thru Cold Air Return? remoguy Plumbing 1 01-02-2011 12:00 AM
Outside cold air intake into cold air duct Cjeff HVAC 6 12-22-2010 04:25 PM
very cold outside air from cold air return ?? slawek HVAC 3 12-24-2008 09:30 AM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
