Installing Ledger Board On Stucco Home - General Discussion - Contractor Talk
Old 05-20-2014, 09:45 PM   #1
jacselee's Avatar
Rewards Points: 204
planning to build a deck on a stucco home. Originally i was planning to attach the structure to the home, but realized i would have to break up the stucco, put the ledger on, do all my flashing stuff and then repair the stucco.
Too much work
would you just free stand the deck?
jacselee is offline
Old 05-20-2014, 09:55 PM   #2
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
Re: Installing Ledger Board On Stucco Home
good stuff
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 05-20-2014, 10:28 PM   #3
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 14,524
Definitely free standing deck. Set it off the house quite a ways too. This way you'll only have to disturb the stucco in the small areas you anchor the posts from the rope bridge that will allow access from the back door to the deck.
Figure two lags with eyes at the ends of them on the top and bottom of the bridge harness. Make sure you use galv lags though so some PITA inspector doesn't come breaking your balls about it.
Easy Gibson is offline
The Following User Says Thank You to Easy Gibson For This Useful Post:
Fouthgeneration (05-21-2014)
Old 05-20-2014, 10:35 PM   #4
avenge's Avatar
Rewards Points: 34
Omg!
avenge is offline
Old 05-20-2014, 10:44 PM   #5
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,244
Use spacers and keep the ledger away from the stucco.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
aptpupil (05-22-2014)
Old 05-21-2014, 02:38 AM   #6
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,251
Diamond Saw in a Zee(1/2" hemmed leg in stucco,vertical 1/2" plus deck board depth, out 1 7/8" over ledger to drip edge) angle tin flashing ~ 1/2" deep, fill grove with 50 yr sanded caulk, inbed flash, recaulk and wedge with lead wedges if neccessary.
I use vertical peices of cedar lath(stapled to house side of ledger) to space the ledger board out an 1/4" on each side of the anchors under the flashing to allow it to dry out.
Is the stucco on some cheesy soft insulation preventing tightening the through bolts/all thread studs to the rim joist or footing?
Fouthgeneration is offline
Old 05-21-2014, 03:11 AM   #7
Gary H's Avatar
Rewards Points: 2,342
Jlc mag had a story on a freestanding deck on a house that was brick and they didn't want to anchor though that into the rim joist.
Or 4th generation's post above is a good example if you want to cut it in.
Gary H is offline
Old 05-21-2014, 06:22 AM   #8
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
We just take the time to cut it in and flash it. We don't usually need to repair it if you take the time to do it right.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
greg24k (05-21-2014)
Installing a fireplace insert in older home. combuilder Remodeling 3 01-29-2011 01:39 PM
How to Safely Pressure Wash Your Home. PressureWashE Pressure Washing 1 07-02-2010 05:50 AM
Rubber membrane behind ledger on stucco? Woodcrafter74 Decks & Fencing 6 01-31-2006 08:27 PM
