Installing A Jeld Wen Metal Clad Exterior Door - General Discussion - Contractor Talk
Old 11-26-2019, 12:07 AM   #1
alancontractor's Avatar
Trade: electrician
Rewards Points: 18
I'm in the process of installing a Jeld Wen metal clad exterior door and I've run into a problem. The distance between the flange that runs around the edge of the door to the inside edge of the door is 4.5". The wall is 3.5" thick and the drywall is 0.5" thickness which means the door will extend past the drywall by 0.5". Has anyone dealt with this problem and how? I can either add a 0.5" thick trim around the door which may look terrible or I can add a 0.5" shim and extend the door out so that the door is flush with the interior drywall. If I do that then stuccoing the outside wall might be a problem. Any help would be appreciated. Pictures would be great. Thanks
alancontractor is offline
Old 11-26-2019, 12:12 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 204
Re: Installing A Jeld Wen Metal Clad Exterior Door
Order a jamb the correct width.
griz is online now
WarnerConstInc. (11-26-2019)
Old 11-26-2019, 12:14 AM   #3
Trade: electrician
Rewards Points: 18
I talked with Jeld Wen and this is the correct jamb for the job. They offer to smaller widths.
Old 11-26-2019, 12:15 AM   #4
Trade: electrician
Rewards Points: 18
They offer no smaller widths
Old 11-26-2019, 12:22 AM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 204
Exactly why you can custom order doors and jambs.
griz is online now
Old 11-26-2019, 12:32 AM   #6
Trade: electrician
Rewards Points: 18
I'll check with them tomorrow, but I don't believe they offer custom.
Since I already have the door have you dealt with this problem before
Old 11-26-2019, 01:37 AM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 204
fur the inside out.
griz is online now
Old 11-26-2019, 01:49 AM   #8
CPMKW's Avatar
Trade: GC PM
Rewards Points: 352
The wall is only 4" total? No exterior sheething or finish? What is happening here...
Set the inside flush. Make the outside work with trim.
Sent from my Pixel 4 using Tapatalk
CPMKW is offline
The Following User Says Thank You to CPMKW For This Useful Post:
TheConstruct (11-27-2019)
Old 11-26-2019, 02:29 AM   #9
Trade: electrician
Rewards Points: 18
No exterior sheeting. The existing outside wall is just tar paper and wire mesh to hold the stucco. From the outside edge of the door to the flange it is 1 3/16". So if I make the inside flush using a 1/2" shim on the flange then the outside distance will increase to
1 11/16". So adding outside trim might be an option or maybe a could float out the stucco wall
Old 11-26-2019, 02:46 AM   #10
VinylHanger's Avatar
Rewards Points: 11,292
If the jamb is too wide, just trim the interior and add a filler strip between the wall and the trim.
Is it normal to not have sheeting when doing stucco? What gives you the sheer strength?
Sent from my SM-N975U using Tapatalk
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 11-26-2019, 02:52 AM   #11
Trade: electrician
Rewards Points: 18
Since the door is part of a remodel I decided the simplest solution is to double up the drywall on the new interior wall and add another sheet of 1/2" drywall to the existing wall in order to solve the problem. It will only take a couple of sheets to double up the existing so that the new and existing wall will be flush with each other.
The Following 2 Users Say Thank You to alancontractor For This Useful Post:
TheConstruct (11-27-2019), TimNJ (11-26-2019)
Old 11-26-2019, 09:20 AM   #12
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,794
When I run into this I either custom order the jamb or I custom size it myself really not that hard to do. Pretty common to have to do on older houses.
Randy Bush is online now
Old 11-27-2019, 06:46 AM   #13
builditguy's Avatar
Rewards Points: 1,742
I have seen this in mobile homes. (called modular in some places)
The walls are thin.
You said the jamb is 4 1/2", but it is really probably 4 9/16". Standard jamb thickness. (I know we are only talking about 1/16", but that is the correct thickness)
I would install the door like normal. It will stick out, on the inside, an extra 1/2". Then use 1/2" x 3/4" parting stock, under your interior trim. It will look fine. Most likely, nobody will ever notice.
If it had standard brickmould on the exterior, you could remove the brickmould, cut the jamb down and then re-install.
I wouldn't. If you do that, it would be difficult to install a storm door. You may live in an area that doesn't need or use storm doors, but I don't know.
builditguy is offline
The Following User Says Thank You to builditguy For This Useful Post:
Old 11-27-2019, 07:37 AM   #14
Box Builder
Morning Wood's Avatar
Rewards Points: 10,090
No exterior sheathing? Like has been said just add 1/2 backer to the outside edges of you interior trim. It will look totally fine and is the best option. Doubling up the drywall sounds kind of like a WOS idea. The whole scenario though is going down that route.
Morning Wood is online now
The Following User Says Thank You to Morning Wood For This Useful Post:
SmallTownGuy (11-27-2019)
Old 11-27-2019, 09:24 AM   #15
Randy Bush's Avatar
The walls are thin.
I guess I am just not following why it would be such a problem cutting the jamb down . Pulling the brick mold and reinstalling is not going to make it hard for installing the storm door. I can't tell you how many times I have done this. And everything worked out just fine. I carefully disassemble the jamb , run it through the table saw and put back together. Lots of times I even buy the door without the brick mold on because I know I am going to have to resize.
Old 11-27-2019, 10:27 AM   #16
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,938
Originally Posted by alancontractor View Post
I'm in the process of installing a Jeld Wen metal clad exterior door and I've run into a problem. The distance between the flange that runs around the edge of the door to the inside edge of the door is 4.5". ..
What strange land do you live in Alan? Is it DIYsylvania?
Hereabouts we call that "flange" brickmold or casing.
SmallTownGuy is online now
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
avenge (11-27-2019), Randy Bush (11-27-2019)
Old 11-27-2019, 11:36 AM   #17
Trade: electrician
Rewards Points: 18
The exterior is stucco installed directly on the 2x4 structure with tar paper and chicken wire in order to match up with the existing stucco. This is considered a shear wall with 180 pounds per foot strength.
Correction the jamb is 4 9/16". If I use 1/2" x 3/4" parting stock around the door then I need to do this for the front door and windows to get everything to match up. Which is an option but that is really the only option. If the jamb is flush with the wall then I have unlimited options for molding, that is why I thinking about doubling up the drywall. It's a toss up decision.
I can't cut down the jamb since it is wrapped in metal. If it was all wood then it would be simple to cut it down. I called it a flange because that is the part that is sticking out from the casing that gets mounted to the exterior 2x4 structure.
Any thoughts on using a sill pan underneath the door. The house is in San Diego and the flooring is concrete. I don't see a need for a sill pan but maybe a sheet or two of tar paper to isolate the concrete from the metal frame sill.
Old 11-27-2019, 12:36 PM   #18
Randy Bush's Avatar
Made a lot more sense now but with the added information. Cladded door, nail fin/ flange, snap on brick molding? I would still put a pan under it. . You don't want water cooling coming in under the door, tar paper doesn't seal it up.
Sent from my KYOCERA-E6790 using Tapatalk
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 11-27-2019, 01:34 PM   #19
Trade: electrician
Rewards Points: 18
I was planning on applying tar paper on top of the concrete and then adding caulking on top of the tar paper and then sit the door in the calking. So the sill would be completely sealed from moisture and isolated from the concrete.
In my application I don't see the need for a pvc or metal sill pan. If the flooring was wood instead of concrete then maybe yes. Also the likelihood of water getting underneath a metal clad door is slim. Though a wood door that has rotten away at the corners is a possibility.
Old 11-27-2019, 01:45 PM   #20
If you aren't using a pan, seal directly to the concrete. The tar paper will let moisture and drafts under it. Or maybe use a rubber sticky flashing that will help seal out drafts. Then seal to that.
