I Need Info. - General Discussion - Contractor Talk
I Need Info.
Old 07-24-2010, 06:53 PM   #1
trophyhunter1's Avatar
Trade: clark paint and drywall
I Need Info.
I need some help from a pro .
my home has a lot of moisture under it .
we have put in new duct work with 3 inch R-8 in and it is still sweeting what do i need to do next ?
I have floor vents in place.
trophyhunter1 is offline
Old 07-24-2010, 07:32 PM   #2
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Re: I Need Info.
I think you will be alright here. You seem legit to me.
I am not a ventilation expert by no means. But we will need to know more about your situation.
How many square feet of space?
How tall is the crawl space?
How many square feet of cross ventilation is in place?
Does you site drain away from the building?
Does your downspouts dump next to the building?
ya know that kinda stuff
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Scribbles (07-24-2010)
Old 07-24-2010, 07:40 PM   #3
Re: I Need Info.
drain is good never had any water standing under or around house.
i have 1750 sq feet heat and cool.
4 and 5 block hi craw space.
Old 07-24-2010, 07:55 PM   #4
Gus Dering's Avatar
Re: I Need Info.
I am assuming the ducts are in the crawl space.
Are there foundation vents around the perimeter of the house? If so how many and how many square feet are each one worth?
What about the downspouts? Is there a way to pipe those away from the house?
Originally Posted by Scribbles View Post
I try to help and ya make me look like a dum-arse agian, lol
You will know when I am jabbing at you. You will be in a much worse mood than you are now.
The Following 2 Users Say Thank You to Gus Dering For This Useful Post:
Scribbles (07-24-2010), tgeb (07-24-2010)
Old 07-24-2010, 08:03 PM   #5
Re: I Need Info.
down spout are away from house.
i have 9 vents in craw space they are the auto vents
8 by 16 inch vents.
Old 07-25-2010, 09:55 AM   #6
Florida GC
olligator's Avatar
Rewards Points: 250
Re: I Need Info.
I have a vision of exposed ductwork in this crawlspace, is this the case?
Is the ground in the crawlspace covered with a moisture barrier? Perhaps there is a way to contain all the ductwork with a moisture/vapor barrier after they're strapped to the floor joists? This way the ductwork becomes part of the conditioned space of the home while staying sealed off from the humid, unconditioned crawlspace. My 2cents.
______________
If you're not a Gator, you're Gatorbait!
olligator is offline
Old 07-25-2010, 10:06 AM   #7
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: I Need Info.
It's hard to say without more info. Pictures would help.
But basically, don't insulate the floor joists, have a VB on the ground, covered either with stone or concrete, heat the crawl space. Insulate the crawl space walls. Cover with tyvek.
Mine is exactly like this and no problems in 15yrs.
katoman is offline
Old 07-25-2010, 10:18 AM   #8
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,534
Re: I Need Info.
That is fancy, around here most are just dirt, filth form a 100 years and a few dead critters.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 07-25-2010, 10:21 AM   #9
katoman's Avatar
Trade: carpenter
Re: I Need Info.
Thanks. The common mistake is people insulate the floor. Heat the space, let the heat rise, also helps keep your floor warm.
katoman is offline
Old 07-25-2010, 10:28 AM   #10
jb4211's Avatar
Rewards Points: 2,306
Re: I Need Info.
Is there anyway you can attach some pictures. Not being able to see what your situation it's difficult to help.
Jon
jb4211 is offline
Old 07-25-2010, 10:58 AM   #11
Gus Dering's Avatar
Re: I Need Info.
8 by 16 inch vents.
I don't think you have quite enough square footage of foundation vents. I'm not saying that you need more to solve you trouble either. Around here you need to have 1 square foot of cross ventilation for every 125 - 150 square feet of floor space above. You would need at least 11 feet but if you have trouble getting good cross ventilation you may benefit from more. You only have 8 sq feet now and we don't know if that is evenly spaced around the house or not.
There are humidity controlled fans that you can place under there that come on when the humidity hits a designated level. That would increase the air exchange dramatically. But When the relative humidity is just as high outside as under the house moving the air would seem insufficient.
Fact remains, we need more info and pictures. And a real expert wouldn't be bad either.
Old 07-26-2010, 06:40 PM   #12
Re: I Need Info.
Vapor barrier, insulate, seal, condition.
Next!
neolitic is offline
Old 07-26-2010, 06:54 PM   #13
Re: I Need Info.
I have someone coming tomorrow to start drying the craw space out .
and then we are going to blast off the mold.
then try to find why it is getting so much moisture in the craw space.
some one told me to seal up all vents and put down new Vapor barrier .
if any one know any thing i need to try please let me know.
thanks
Old 07-26-2010, 08:25 PM   #14
jb4211's Avatar
Re: I Need Info.
Are the ducts insulated?
jb4211 is offline
Old 07-26-2010, 08:48 PM   #15
Re: I Need Info.
Yes we put new ones in this last week with 3 inch in.
Old 07-26-2010, 09:50 PM   #16
Gus Dering's Avatar
Re: I Need Info.
thanks
6 mill vapor barrier neatly installed and taped under the house is a must. As many have mentioned.
I don't think you should close off your foundation vents. Just think about it. Where is this moisture supposed to escape from? This is the primary function of the foundation vent and is why you are required to have them. You need more air exchange not less.
Info and help on 3 phase wiring cwatbay Electrical 1 05-25-2010 03:42 PM
Sending someone your info M. A. Hansen Co Site Feedback and Suggestions 2 02-08-2010 11:58 PM
Where to find General Contractor requirement info for certain state? kdub1777 General Discussion 4 12-11-2009 08:23 PM
Looking for some info about the Virginia area J.R.Tile Tiling 2 10-21-2009 11:12 PM
TCE: Turbo Construction Estimator Upgrade Info johnkirk Technology 0 04-27-2009 06:42 PM
