How Are You Guys Handling Mold Remediation - General Discussion - Contractor Talk
Old 04-05-2014, 09:48 AM   #1
jacselee's Avatar
Rewards Points: 204
I bid a project for a guy and on the scope of work was mold removal. I got a professional mold company to do the bid.. they came in at 2400.00
I know there is no special license required. Is this something I can or should do myself in order to get my overall bid lower?
jacselee is offline
Old 04-05-2014, 01:07 PM   #2
Stoneyard's Avatar
Trade: Journeyman Carpenter
Rewards Points: 249
Re: How Are You Guys Handling Mold Remediation
Use 35% food grade hydrogen peroxide. Mix it down to 4% by a ratio of 1 part HP and 10 parts water. Spray liberally. Nothing kills mold better than HP. Its an anti viral ,anti bacterial, kills mold and fungus on contact and is 100% non-toxic to humans unlike bleach and toxic commercial chemicals. Just be careful with the 35% food grade it will burn your skin on contact. Been using this for years its truly amazing and inexpensive.
Stoneyard is offline
Old 04-05-2014, 02:18 PM   #3
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
Isn't water the last thing you want to spray on mold? I've heard this from a mold remediation contractor.
NINZAN STUDIO is offline
Old 04-05-2014, 03:41 PM   #4
Ex-Framer
Needles's Avatar
Trade: Finish Carpenter
Rewards Points: 1,682
I use a product called moldstat plus.
Removing the mold and killing the mold is only one part of fixing the problem. Mold spores are everywhere. After removal the affected area it needs to dry out. Finding the source of the what is making the area wet is necessary. Also any wood that isn't being removed should be cleaned and/ or sanded. Then encapsulated with a mold encapsulation "paint".
Needles is offline
Old 04-05-2014, 05:06 PM   #5
maurice plouffe's Avatar
Trade: siding, weatherization
Rewards Points: 26
We just had a company come in blasted with dry ice. Kills the mold on contact. No moisture added, given an air purity test.
maurice plouffe is offline
Old 04-05-2014, 06:24 PM   #6
Stoneyard's Avatar
Rewards Points: 249
That can be true if its just water but its not. http://h2o2uses.com/mold-and-mildew-remediation
Old 04-05-2014, 07:03 PM   #7
intersound2005's Avatar
Trade: Builder
Rewards Points: 56
I did a job with mold in it during tear out & I did took care of mine with white vinegar. Kills 85% first time on contact, then a second application knocked it right out. Bleach also will work.
Do not treat mold, or work around mold, without wearing proper respirators with appropriate filters.
You can have a sample tested to see if it is the infamous black mold, (stachybotrys) which is very hazardous to your lungs and can cause permanent damage if not handled properly. Not all mold that is black is stachybotrys, but still toxic nevertheless.
intersound2005 is offline
Old 04-05-2014, 08:06 PM   #8
90%-er
onmywayup's Avatar
Rewards Points: 2,104
Look into renting an Ozone Generator (lots of rental shops carry them). We flip houses that have mold oftentimes. Set that Generator up for 24 hours in the affected area, and you'll see your mold turn to a fine white powder that can be scraped off and re sealed with oil based Killz. WEAR A GOOD RESPIRATOR. Not a good time to be a cheapskate with safety gear here.
The ozone penetrates deeper than the surface. Kills spores.
Respirator, Respirator, Respirator.
onmywayup is offline
Old 04-05-2014, 10:51 PM   #9
Head Light Bulb Changer
66 Shelby's Avatar
Trade: Renovation/Home Repair
Rewards Points: 216
I wouldn't mess around with doing it yourself. If you're bidding a job that has a defined mold removal clause, you're setting yourself up for an expensive lesson in 'profit'. Hire a pro, mark it up 5% if you're that concerned about cost, and let them take the responsibility for any missed mold and dry out (It WILL continue to grow if you miss some and it's still wet). Mold remediation is one of those things that will bite your ass hard if you screw it up. JM2C.
66 Shelby is offline
The Following User Says Thank You to 66 Shelby For This Useful Post:
fjn (04-07-2014)
Old 04-06-2014, 11:21 AM   #10
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 82
Don't take this the wrong way, but you shouldn't be doing mold work if you don't know anything about it. You can and will lose your a** , not to mention odds are your liability insurance most likely doesn't cover you to do that type of work.
NJGC is offline
Mold remediation certification/license? Lockbox General Discussion 1 01-30-2013 09:54 PM
Mold Remediation lifestooshort81 Remodeling 6 11-29-2012 07:03 PM
Mold remediation Kostyan General Discussion 17 09-17-2009 07:54 PM
