How To Unsolder A Copper Time Capsule? - General Discussion - Contractor Talk
Old 08-31-2019, 05:27 PM   #1
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,834
Did some work today on prepping a building to be bricked up. It had a small portion of symbolic brick on it along with a cornerstone that was taken down.
Behind it was a little surprise.... a copper box all soldered up.
Any suggestions on opening it without torching the inside?
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
META (09-19-2019)
Old 08-31-2019, 05:35 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,981
Re: How To Unsolder A Copper Time Capsule?
Cut it.
The torched it closed, so why do you think you can't torch it open?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
CScalf (08-31-2019), Golden view (08-31-2019), pinwheel (08-31-2019)
Old 08-31-2019, 05:42 PM   #3
480sparky's Avatar
Originally Posted by Leo G View Post
Cut it.
'They' knew what was in it. I don't have x-ray vision.
Old 08-31-2019, 05:47 PM   #4
LRG WoodCrafting
Leo G's Avatar
"They" used a large soldering iron to put it together.
https://youtu.be/u74jjvA0-mg?t=65
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-31-2019, 05:59 PM   #5
avenge's Avatar
Rewards Points: 302
Pretty sure torching it won't hurt human remains.
avenge is online now
Old 08-31-2019, 06:52 PM   #6
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 478
Yup, soldering iron for sure. This will not burn the paper inside (if any) where a torch might.
Andy.
ScipioAfricanus is offline
Old 08-31-2019, 08:11 PM   #7
spazman
spazman's Avatar
Trade: floorcovering installer
Rewards Points: 114
Wow! Really cool find. Are you going to try and find out when the building was built? Maybe you can find out something about it on micro film at the library. An old newspaper article might list what’s inside. Might be worth checking out before you attempt to open it.
spazman is online now
The Following User Says Thank You to spazman For This Useful Post:
Rio (09-01-2019)
Old 08-31-2019, 08:28 PM   #8
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Rewards Points: 748
band saw that biotch open
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 08-31-2019, 08:35 PM   #9
480sparky's Avatar
Originally Posted by spazman View Post
Wow! Really cool find. Are you going to try and find out when the building was built? ......
Pretty easy to do. My dad and I built it in 1987.
CScalf (08-31-2019)
Old 08-31-2019, 08:52 PM   #10
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 484
That's what I was thinking.
pinwheel is online now
Old 08-31-2019, 08:56 PM   #11
480sparky's Avatar
MELTING solder is easy.
Getting molten solder to flow INTO a joint is easy.
Getting molten solder to flow OUT of a joint is....... not so easy.
Or haven't y'all ever soldered copper before?
Old 08-31-2019, 09:07 PM   #12
pinwheel's Avatar
Rewards Points: 484
Gravity & compressed air is your friend.
Old 08-31-2019, 09:10 PM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
No truer words actually. You need to add solder to unsolder.
I'd chisel it open.
Inner10 is online now
Old 08-31-2019, 09:11 PM   #14
tjbnwi's Avatar
Rewards Points: 4,636
Solder sucker.
tjbnwi is online now
Old 08-31-2019, 09:13 PM   #15
Inner10's Avatar
Originally Posted by tjbnwi View Post
Solder sucker.
I haven't touched mine since I got my hands on Chem-Wik.
Old 08-31-2019, 09:33 PM   #16
LRG WoodCrafting
Leo G's Avatar
Yes, I made a 2' x 2' x 2' copper box. I know how to sweat.
Melt a corner. Lift an edge and pull while continuing to melt the lead.
Or cut it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 08-31-2019, 09:36 PM   #17
tjbnwi's Avatar
TMI
Old 09-01-2019, 05:57 AM   #18
builditguy's Avatar
Rewards Points: 2,132
In the time it took to read these responses, I could have cut it open.
builditguy is offline
Old 09-01-2019, 06:00 AM   #19
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
just do it...
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
fjn (09-01-2019)
Old 09-01-2019, 06:20 AM   #20
John the Builder
...or get Popeye to do it. He didn't need no steenkin soldering copper, or can opener or nuttin' man !
CScalf (09-01-2019)
