How Much Prep Work Do You Do? - General Discussion - Contractor Talk
Old 03-07-2019, 02:21 PM   #1
AustinDB's Avatar
Rewards Points: 1,004
Have 4300sf of engineered to glue down on slab in a new construction.
Some parts are filthy and others not as bad but I prefer grinding than manually scraping it.
Is there a standard protocol for higher end installs when it comes to floor prep?
The entire house was set for 1/2 flooring and they have 5/8...the builder is having a small profile painted to match. Would a Crane make clean cuts to slip flooring under or would the cut edge need touched up?
Done plenty of floor jobs but not this large
AustinDB is offline
Old 03-09-2019, 11:22 PM   #2
rblakes1's Avatar
Rewards Points: 2,654
Re: How Much Prep Work Do You Do?
Man I really hope you're not going to try to grind 4300 sf with that little guy.
I have a friend who does concrete coatings, he's under $2/sf. I've had him prep slabs for me before.
The small profile is like a shoe molding? I'd make sure I had lots of sharp blades for undercutting door jambs and what not
-Rich
rblakes1 is offline
Old 03-10-2019, 12:59 AM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,418
Hahah
After about 200 feet he will figure out that he needs a bigger tool
You can rent a machine from home depot or anywhere else that will knock it out
Windycity is online now
The Following 2 Users Say Thank You to Windycity For This Useful Post:
fjn (03-10-2019), rblakes1 (03-11-2019)
Old 03-13-2019, 09:11 PM   #4
Repede Emil's Avatar
Trade: Flooring contractor
Rewards Points: 4
You should remove any loose glue plaster paint etc. The cleaner the surface the better is the bond between flooring ang glue. Also fill in low spots with self leveling material. A flat subfloor is just as important.
Repede Emil is offline
The Following User Says Thank You to Repede Emil For This Useful Post:
onmywayup (03-13-2019)
asking for more money elbud433 Construction 286 03-21-2018 08:47 AM
Work Experience Question mnamos Contractor Licensing 1 05-13-2015 11:23 PM
Scope of work CarpenterSFO General Discussion 20 11-03-2014 08:27 PM
High Horses and "Ironing Boards" for Detail Work basswood Finish Carpentry 47 06-15-2010 06:31 PM
