How Many Actually Involve A Structural Engineer On Projects - General Discussion - Contractor Talk
Old 07-19-2012, 04:55 PM   #1
rdr8887's Avatar
Rewards Points: 250
What about when you are moving a load bearing wall? What about something simple like building a deck? What about a Deck with a roof over it? What about resizing a window?
These are all instances where I could see using one. But how many really do? I'd take out the window and maybe a simple deck because I can follow the codes which dictate construction. But maybe even that is wrong?
I would rather pay someone else to carry the design liability. I'm not an engineer and don't like to act like one either. I can do a little bit of structural analysis myself....but I don't like the idea of carrying that risk. Many times, I get flack for my thinking.
Are there any others like me? I mean, if you don't, are you really comfortable with the risk?
Just curious to hear your thoughts....
I can do anything your bank account will allow....
rdr8887 is offline
Old 07-19-2012, 05:00 PM   #2
Ash@OTL's Avatar
Trade: remodeling/ home repair
Rewards Points: 160
Re: How Many Actually Involve A Structural Engineer On Projects
Your thinking is right. So far Ive only consulted a engineer on 1 project. I had to have a drawing and a stamp to pass framing inspection. Im glad I did. No worries that way. The engineer drew up a plan way more efficient than what I had in mind.
Ash@OTL is offline
Old 07-19-2012, 05:17 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 642
Just depends on the SOW and if the plan checker will buy the plans as drawn.
Most everything out here now requires a wet stamp at time of submittal to building separtment.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
ROVACON (07-19-2012), TimNJ (07-20-2012)
Old 07-19-2012, 05:17 PM   #4
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
I have an engineer stamp all my structural plans – even stuff like adding or enlarging a window. I don’t on decks – seems that basic span charts work for the building department and nothing has crashed… yet!
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
Old 07-19-2012, 05:20 PM   #5
rdr8887's Avatar
Rewards Points: 250
If something was to fail, the inspectors and plan reviewers won't be liable. At the end of the day I'll be stuck holding that bag. They might get a slap on the wrist.
rdr8887 is offline
Old 07-19-2012, 05:23 PM   #6
rdr8887's Avatar
Rewards Points: 250
Span tables are good. They tell me everything I need to know. What about when a roof is added. Would you then consult an engineer?
rdr8887 is offline
Old 07-19-2012, 05:30 PM   #7
hdavis's Avatar
Rewards Points: 2,124
I don't have any problem with liability from structural engineering in most cases. Things like multifamily require stamped drawings around here. For the rest, I only get concerned if it's a structural repair and the building has some other structural issues in my opinion that could interact with the repair. I don't worry too much about the rest. Claims only come off of failures of one kind or another and I've seen enough to have a good idea what might fail. People can sue you even if you had nothing to do with a fail - it's a free country. I don't get too worked up about it.
hdavis is online now
Windwash (07-19-2012)
Old 07-19-2012, 05:47 PM   #8
Yes!
I don't think I get too worked up about it. It's just SOP for us to have plans stamped. I do most of the designs - I carry "Errors & Omissions" but why not have your work checked before it's built? The customer pays for it.
In reality I should have my decks checked also.
Old 07-19-2012, 06:52 PM   #9
hdavis's Avatar
Yes!
Probably because I'm anal about it. I'll design a few different ways and check a few different ways. It'd just annoy me to have to sit down with the guy that has a stamp and explain to him why he's wrong. I've had to do this on ones which required engineering stamps a couple times - I'll do a full design and let the engineer do his full design. I can only catch his mistakes if I've already designed it and analyzed it.
Old 07-19-2012, 06:59 PM   #10
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 190
Wow, you must be some kind of wicked cool engineering genius.
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
slowsol (07-19-2012)
Old 07-19-2012, 07:15 PM   #11
The engineer I use and I have been together for almost 15 years now. I rarely need to explain anything to him. He usually stamps my drawing and sometimes adds a detail for me (read as “over-builds”). It’s collaboration.
Andy.
Ouch!
Old 07-19-2012, 07:26 PM   #12
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Nearly every deck we build is engineer stamped. I've gotten so used to it I think i'll use him even when not "required".
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
hdavis (07-19-2012)
Old 07-19-2012, 07:35 PM   #13
General Contractor
greg24k's Avatar
Rewards Points: 8,478
I can see SE being involved on a huge complex structure where design calls for large spans, wind loads, tension loads,etc... Most residential construction dont need a structural engineer, Because architect can design homes using most common load factors and conventional framing details in the region were they did 100 + homes without any issues...not to mention most Architects I worked with, they use stractural engineers only if they come across a complex design, etc just to make sure the design they designed and components they incorporated will support loads in question.
I have seen a few basic residential additions were SE was a friend of the family or someone they knew who helped them design the addition or some other construction project, and it was way over designed, and it almost doubled the cost of lumber, etc. and if any Architect would design the same thing, it would be done using basic conventional lumber, and it would work just the same.
greg24k is offline
jkfox624 (07-19-2012)
Old 07-19-2012, 07:57 PM   #14
hdavis's Avatar
Andy.
No, but thanks for the complement
Old 07-19-2012, 08:02 PM   #15
hdavis's Avatar
I my case, I've worked with the same engineer twice - every other time it's been someone else, including architects. I could just have an engineer go over my design, tweak it and stamp it, but since there really isn't a long term relationship, I'd rather hand it off and catch any of his errors.
Old 07-19-2012, 08:28 PM   #16
hdavis's Avatar
Anything steel gets a stamp, IMO.
Old 07-19-2012, 08:49 PM   #17
Design/Build
EmmCeeDee's Avatar
Trade: Design/Build
Rewards Points: 660
Much of what we build is non-typical so we go to a SE pretty regularly for unusual conditions, complex framing etc. We can handle most calculations; span tables, headers etc, but know when to defer to the experts.
In school I was taught that wood calculations have a safety factor of 3 built in. So whatever the span tables say, the load a given member is actually capable of carrying is three times that. This is to compensate for the knots, checks etc that occur in the material.
EmmCeeDee is offline
The Following User Says Thank You to EmmCeeDee For This Useful Post:
hdavis (07-19-2012)
Old 07-19-2012, 10:15 PM   #18
RobertCDF's Avatar
Yup, even though it shouldn't... But oh well, I'm sure my engineer likes my money (rarely does he have to change anything on my designs) mostly easy stuff for him.
hdavis (07-19-2012)
Old 07-19-2012, 10:56 PM   #19
Tscarborough's Avatar
Rewards Points: 1,460
It is all about risk assumption. I have to suggest it, but not require it, but my risk profile is low because I sell it not install it. If you are comfortable about your risk exposure, go for it.
Tscarborough is offline
Old 07-20-2012, 07:03 AM   #20
DavidC
DavidC's Avatar
Rewards Points: 2,006
I've used an engineer only a handful of times. Basically, I take what I'm planning on doing to the permit office and review with the inspector. Trusses come with the engineers stamp from the manufacturer, span tables normally are good for rafters, beams, etc.
Except for in the city, we aren't required to permit decks without roofs. But when you add a roof, it's called a porch. Then the floor framing requires inspection also, so I don't follow why they make the distinction.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Transition from Residential Remodels to Commercial projects CBalbarin Business 2 02-24-2010 11:52 AM
Deciding to take on very large projects. Techie Business 8 07-21-2009 08:20 AM
Anybody want some landscaping projects (in ND?) BluestoneInc Landscaping 0 07-06-2009 11:20 AM
Associate Engineer - Peter Brett Associates UK Exemplar Help Wanted or Looking For Work 0 10-05-2006 08:22 AM
