How To Grind Stucco For Exterior Casing? - General Discussion - Contractor Talk
Thread Tools
Old 07-16-2015, 09:11 AM
tipitop's Avatar
Trade: carpenter
Rewards Points: 4,139
I had to grind stucco around a door 1/4 down and 2 and 1/2 wide so exterior casing (3 1/2 hardy board) can lie flat above stucco and door frame. Both 7” concrete grinder wheel and tried to use in same way how you would grind steel. Like little angled holding grinder and grinding with edge or wheel. Didn’t work wheel. Spend like 3 hours and didn’t go deep enough and made so much dust that was worried someone will call police at me. What is right way? I found at internet diamond wheel, evidently in this case small one, but holding it flat against stucco not at an angle?
tipitop is offline
Old 07-16-2015, 11:58 AM
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Re: How To Grind Stucco For Exterior Casing?
What u talkin bout Willis
Eaglei is offline
Old 07-16-2015, 01:49 PM
dsconstructs's Avatar
Trade: Remodel Contractor
Sounds like the door should have been ordered with 1/4" wider jamb. I'd much rather add that much to the jamb with a little filler trim piece than grind all that stucco down.
If you were using thicker trim, I'd say to use a table saw to remove that much from the back of the trim where it meets the stucco, kind of a fat "L" shape.
But again, no way I'd grind that much out of the stucco.
dsconstructs is offline
Old 07-16-2015, 06:56 PM
tipitop's Avatar
Trade: carpenter
I will do so. I thought to do so but homeowner had “better” idea.
tipitop is offline
Old 07-16-2015, 09:48 PM
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Best case scenario is to have the stucco return to the jamb. We try to not have trim on the outer part of the jamb because it usually is a maintenance nightmare and also looks better.
CrpntrFrk is offline
Old 07-18-2015, 10:22 PM
AGullion's Avatar
Rewards Points: 1,422
The stuff we get into sometimes . Heavens. Good advice given .
AGullion is offline
Thread Tools
Rate This Thread
The proper way to flash a stucco dormer? mastersplinter Roofing 6 06-17-2018 05:10 AM
Synthetic Stucco Repair....Grrr lukachuki Masonry 15 12-23-2012 10:48 AM
Stucco with mold Ohio painter Painting & Finish Work 5 08-10-2012 08:22 PM
Stucco on wallpaper... The best solution for residential buildings. aulona Wallpaper 10 07-23-2012 02:30 PM
Ext stucco job RUCKER Painting & Finish Work 0 06-17-2012 03:45 PM
