How Do You Keep You Compressor Running In The Cold? - General Discussion - Contractor Talk
Old 02-01-2013, 03:25 PM   #1
maleko's Avatar
Trade: carpentry
Rewards Points: 268
I'm never on a outside job in the winter but, this year I am.
When ever it's below freezing I can't get my compressor to run or stay running.
It's an Emglo tat uses oil. I'm assuming the oil is to thick due to the temp.
I have to use a small torch to heat it up to get it started but if its not running non stop it will not come on, it tries but always trips the breaker.
Do I need an oil less? Thanks
T
maleko is offline
Old 02-01-2013, 04:20 PM   #2
building Contractor
FHS's Avatar
Rewards Points: 160
Re: How Do You Keep You Compressor Running In The Cold?
My Hitachi is an oil bath compressor and it gets parked when the temp gets below freezing. Them I use my bigger and older Craftsman oil free.
I never tried changing to full synthetic oil to see if its any better.
Tim Fuchs Construction
FHS is offline
Old 02-01-2013, 04:27 PM   #3
kiteman's Avatar
Rewards Points: 16
Ran my Campbell- Hausfield oil- bath all day today. Started out at 5 f.High of 23. I've never had a problem with it being too cold to run. Icing downline maybe, but not at the compressor.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 02-01-2013, 04:29 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 60
I always use an oilless when its cold. I hear that some have had good luck changing the oil, but I have never tried it.
Easy Gibson
Warren is offline
Old 02-01-2013, 06:25 PM   #5
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Mine def slows down on start up when it's cold. Today it was -7 and it started up slow but it started. Perhaps put a little fan heater blowing on the crank case to bring the oil above freezing.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
knucklehead (02-01-2013)
Old 02-01-2013, 06:37 PM   #6
Sabagley's Avatar
Trade: General contractor
Rewards Points: 880
I run an Emglo also. When it is single digits it tends to pop the breaker also.
You need to use a heavy gauge cord and release the air from the tank when you start it up.
There is also a constant run switch that allows it to run without building pressure. That way it is not working against the air pressure and large draw at start up.
Sabagley is offline
Old 02-01-2013, 06:40 PM   #7
CraftyJT's Avatar
Trade: General Construction
Rewards Points: 75
what type of construction do you do? We don't have problems with ours..
http://www.rolair.net/products/spec_...K17.html#specs
however you have to have enough guys running air to support a compressor like that. store it in the tool trailer at night with a small protable space heater in there starts up about 3 pulls every mourning..also have and inline water separator and oiler filled with cold weather pneumatic oil..never have problems with anything freezing.
CraftyJT is offline
The Following User Says Thank You to CraftyJT For This Useful Post:
CanningCustom (02-02-2013)
Old 02-01-2013, 07:03 PM   #8
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
I don't have a trailer.
NKLHD
knucklehead is offline
The Following User Says Thank You to knucklehead For This Useful Post:
kiteman (02-01-2013)
Old 02-01-2013, 08:07 PM   #9
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,058
Mine stays in my heated trailer all the time.
Randy Bush is online now
Old 02-01-2013, 08:20 PM   #10
Box Builder
Morning Wood's Avatar
Rewards Points: 10,298
If you pull the pressure relief valve when you start it the motor won't run under load. That might do it, although pulling the pressure relief is probably not good for it. Who knows.
Morning Wood is offline
Old 02-01-2013, 08:32 PM   #11
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 60
We just use a heat bulb or regular bulb in a clamp light. Put it close to the cylinder and let leave it there all day and night. We use the big eletric Rol-air.
I can't compete with hacks.
donerightwyo is offline
The Following User Says Thank You to donerightwyo For This Useful Post:
Red Adobe (02-03-2013)
Old 02-01-2013, 08:52 PM   #12
Remodeling Professionals
buildenterprise's Avatar
Trade: New Construction and Remodeling Contractor
Rewards Points: 502
Stick one of these on the bottom of the "crankcase", they work great. Also, plug the compressor directly to an outlet whenever possible so there's no voltage drop.
http://www.amazon.com/Kats-24050-Wat...+engine+heater
buildenterprise is offline
Old 02-01-2013, 09:00 PM   #13
Geometrist
Warren's Avatar
Rewards Points: 60
Or, buy an oil less for the really cold days and not have to preheat the thing every day its cold. Maybe if you rarely work in the cold the heater thingy is ok though.
Easy Gibson
Warren is offline
Old 02-01-2013, 09:11 PM   #14
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,560
My compressor is the Makita 2400 It's an oil compressor
I use an electric space heater. a 1500 watt unit.
It is on 24/7
during work it is facing the compressor, In the evening it's under the hood of the telehandler so I can get it started in the morning.
It was -14F on Wednesday and the compressor worked fine all day.
Now the air lines froze on the other hand, but that's not the compressors fault
Usually my biggest problem is getting the air tools to fire when it's that cold
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
The Following 2 Users Say Thank You to JT Wood For This Useful Post:
donerightwyo (02-01-2013), Windwash (02-01-2013)
Old 02-01-2013, 11:59 PM   #15
kiteman's Avatar
Rewards Points: 16
Wow, -7 in Roanoke?
Actually, I seem to have more problems with the lines icing with the compressor heated than running it in the cold.
kiteman is offline
Old 02-02-2013, 12:07 AM   #16
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,290
Use a gas compressor it at least stays a constant idol.
Calidecks is online now
Old 02-02-2013, 12:19 AM   #17
kiteman's Avatar
Rewards Points: 16
Noisy $#@%&*?/(# gaspots.
kiteman is offline
The Following User Says Thank You to kiteman For This Useful Post:
Calidecks (02-02-2013)
Old 02-02-2013, 12:26 AM   #18
GC/carpenter
Calidecks's Avatar
I really have no business commenting on something I know nothing about. I digress
Old 02-02-2013, 12:35 AM   #19
kiteman's Avatar
Rewards Points: 16
If the only comments on here were from people who knew what they were talking about, the forum would be about 1/3 its size.
My self included.
kiteman is offline
The Following 6 Users Say Thank You to kiteman For This Useful Post:
Big Shoe (02-02-2013), Calidecks (02-02-2013), CanningCustom (02-02-2013), CarrPainting (02-05-2013), littlefred811 (02-04-2013), Mississippi (02-05-2013)
Old 02-02-2013, 11:45 AM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 506
Originally Posted by kiteman View Post
Wow, -7 in Roanoke?
According to the Farmer's Almanac, the low in Roanoke yesterday was 34 F yesterday.
Tinstaafl is offline
Cold sqft to Hot water sqft knothead Pressure Washing 6 02-22-2014 01:08 AM
Rol-Air JC10, Cold operating conditions, TBFGhost Tools & Equipment 19 01-25-2013 10:34 PM
Mason or cold chisel! What is the difference? sleeper Masonry 24 11-30-2012 04:51 PM
Outside cold air intake into cold air duct Cjeff HVAC 6 12-22-2010 04:25 PM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
