How Do I Repair A Puncture Hole In Stainless Steel Sink? - General Discussion - Contractor Talk
Thread Tools
Old 04-08-2015, 04:42 PM
Kycym's Avatar
Trade: Architect
Rewards Points: 18
Is there a way to repair a puncture hole (the size of the tip of a pencil) in a stainless steel sink without replacing the sink?
Kycym is offline
Old 04-08-2015, 04:47 PM
Fire up the BBQ
griz's Avatar
Rewards Points: 2,562
Re: How Do I Repair A Puncture Hole In Stainless Steel Sink?
yes, but it more than likely won't look very good.
hopefully this is in your own home and not that of a client....
bite the bullet and install a new sink...
griz is offline
Old 04-08-2015, 04:58 PM
GettingBy's Avatar
Rewards Points: 6,486
You could put a stainless rivet through the hole but then you'd have to put at least three more in, in a pattern that looks like it was intentional.
How much for new sink, labor & mat'ls?
How much for the fix above?
GettingBy is offline
The Following User Says Thank You to GettingBy For This Useful Post:
Roofcheck (04-08-2015)
Old 04-08-2015, 05:02 PM
dayexco's Avatar
Rewards Points: 824
if you don't care, JB Weld
dayexco is offline
The Following User Says Thank You to dayexco For This Useful Post:
dkillianjr (04-08-2015)
Old 04-08-2015, 05:12 PM
Kycym's Avatar
Trade: Architect
Rewards Points: 18
The sink is in my home. The hole is very small. Rivets would only draw attention to it as well as create more holes in the sink.
I was thinking something like in the line of soldering or similar process.
Kycym is offline
Old 04-08-2015, 05:23 PM
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 540
A highly experienced welder with a good portable Tig welder system.
Sinks are not very heavy gauge but it can be done. I have done it many times.
Hammer in the puncture, back with some heavy aluminium or copper ingot, very cool torch. Like I said not and easy thing to do.
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
1985gt (04-09-2015)
Old 04-08-2015, 05:34 PM
Kycym's Avatar
Trade: Architect
Rewards Points: 18
Thanks ScipioAfricanus.
Kycym is offline
Old 04-08-2015, 06:09 PM
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
Just as a preventative lesson for the rest of us, what caused the pin point hole?
--MATT
Add your Facebook Business Site to "THE LIST"
https://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is offline
The Following User Says Thank You to MattK For This Useful Post:
BlueRidgeGreen (04-08-2015)
Old 04-08-2015, 06:17 PM
MarkJames's Avatar
Rewards Points: 19,581
Drop-in or under mount? If it's a drop it, replacing it would be the way to got to get it done and get out. In your home? Then you have the luxury of messing around with epoxy first.
MarkJames is offline
Old 04-08-2015, 06:38 PM
hdavis's Avatar
Rewards Points: 2,480
Andy.
Any good sheet metal fabricator should be able to do it as well - they should have done welding for custom SS stuff.
hdavis is offline
Old 04-08-2015, 06:44 PM
charlie828's Avatar
Trade: Sort of retired GC, residential and commercial
Rewards Points: 213
Sounds like there is a good backstory here. Please tell us how the hole got there. Inquiring minds want to know.
charlie828 is offline
The Following User Says Thank You to charlie828 For This Useful Post:
Kowboy (04-08-2015)
Old 04-08-2015, 06:52 PM
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Keeyter is offline
The Following 5 Users Say Thank You to Keeyter For This Useful Post:
66 Shelby (04-09-2015), Chopsaw Chick (04-08-2015), Jake D (04-09-2015), Kowboy (04-08-2015), superseal (04-08-2015)
Old 04-08-2015, 06:55 PM
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Another option,take the sink out,turn it up side down and braze the hole. All you will see then is a tiny bit of brass.
fjn is offline
ScipioAfricanus (04-08-2015)
Old 04-08-2015, 07:29 PM
30 year novice
carzie's Avatar
Trade: Painting contractor "eh"
Rewards Points: 2,823
Seeing he's an architect my money is on his compass fell out of his shirt pocket when he was trying to open the window over the sink....next?
carzie is offline
Old 04-08-2015, 07:30 PM
30 year novice
carzie's Avatar
Originally Posted by Keeyter View Post
Mitey putty would be better
carzie is offline
Old 04-08-2015, 07:34 PM
MattK's Avatar
Mighty Putty! RIP Billy Mays...
--MATT
MattK is offline
Old 04-08-2015, 07:35 PM
Box Builder
Morning Wood's Avatar
Rewards Points: 10,390
Tig weld it for sure. Stainless is pretty easy to weld. Only problem is you may end up with some rusting around the repair. The heat from the weld can do that to stainless sometimes. Find someone with a portable 110 tig machine that is really good. It should literally be like one dab and done.
Morning Wood is offline
Old 04-08-2015, 07:37 PM
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 13,561
If it's just to fill the hole then back the hole up with a pc of metal and bang the hole closed from the other side. The put a dab of silicon on the backside. Put a pc of tape on the front side to prevent the silicon from squeezing through.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 04-08-2015, 07:42 PM
MarkJames's Avatar
Glue a spoon onto the hole...permanently. If you have kids, nobody will notice.
The Following 3 Users Say Thank You to MarkJames For This Useful Post:
j_sims (04-08-2015), superseal (04-08-2015), walkinplate (04-09-2015)
Old 04-08-2015, 07:48 PM
Kowboy
Kowboy's Avatar
Trade: Countertops
Rewards Points: 8,978
Replace the sink. Use a Hercules Universal Sink Harness.
Kowboy is offline
Thread Tools
Rate This Thread
How to drill thru an armored building? ssnapier Welding & Steel Trades 48 03-16-2013 11:13 PM
A Visitor from Paint / a plumbing question / bathtub backs up from sink JTemple Plumbing 24 02-12-2013 07:33 AM
Signs made from Stainless Steel Dyer Sandblasting 15 12-24-2012 08:52 AM
stainless steel screws the best option for a picket fence? Spike7 Decks & Fencing 10 09-04-2012 10:04 PM
