How Do I Remove The Sprinkler Head Trim (ceiling Tile Replacement) - General Discussion - Contractor Talk
Old 02-12-2019, 01:16 PM   #1
rservices's Avatar
Rewards Points: 376
I need to replace some stained ceiling tiles in a commercial kitchen.
Usually, the chrome trim piece around the base of the sprinkler head slides off, this one does not. The chrome flange at the end of the sprinkler head appears to be blocked by a bolt that holds on to the head.
I've only seen this style once before and gave up on it and cleaned the ceiling tile, unfortunately, there are several which need to be replaced.
Any suggestions???
How do I remove the sprinkler head trim (ceiling tile replacement)-spinkler.jpg
rservices is offline
Old 02-12-2019, 01:20 PM   #2
rblakes1's Avatar
Rewards Points: 2,932
Re: How Do I Remove The Sprinkler Head Trim (ceiling Tile Replacement)
Any suggestions???
The ones I've seen just unscrew
rblakes1 is offline
Old 02-12-2019, 01:29 PM   #3
rblakes1's Avatar
Can you poke your head into the ceiling? Or sacrifice one if the tiles to see how it goes together.
I can't make out the brand from the photo, but you could always contact the manufacturer
rblakes1 is offline
Old 02-12-2019, 04:23 PM   #4
rustyjames's Avatar
Rewards Points: 1,646
I only breezed over it but this might be helpful:
https://www.qrfs.com/blog/48-how-to-...t-escutcheons/
rustyjames is offline
Old 02-12-2019, 09:10 PM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,176
Good article above.
Looks like you take a snips to what's there --- add the retrofit pcs. I've done a couple, but of the cone + escutcheon type ---orig construction.
Have some sprinkler stops with you --- alternating wood blocks and a sprinkler head water stop tool, it's like a vise grips.
A couple of large towels, trash can --- wrap the busted head with the towels --- twist when sopped --- tail towards the trash can.
Access to riser room --- the FD will be there before you can call them off. Or put alarm system out of service for a bit.
...part of the above is if things get messy...
Steve
We Fix Houses is offline
The Following User Says Thank You to We Fix Houses For This Useful Post:
asevereid (02-13-2019)
Old 02-13-2019, 01:09 AM   #6
rblakes1's Avatar
You might want to tell whomever you are doing the work for to contact their sprinkler company and coordinate with them
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
TheConstruct (02-13-2019)
Old 02-13-2019, 04:18 AM   #7
VinylHanger's Avatar
Rewards Points: 9,646
Hit it with a big hammer. It'll come right off.
VinylHanger is offline
Old 02-13-2019, 10:57 AM   #8
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,225
And the spraying water will clean the panels. Win-win!
rescraft is online now
Old 02-13-2019, 04:59 PM   #9
rustyjames's Avatar
It's fascinating how much nasty looking water can flow out of one of those heads by the time the main gets shut off.
The Following 2 Users Say Thank You to rustyjames For This Useful Post:
rrk (02-13-2019), SmallTownGuy (02-20-2019)
Old 02-13-2019, 09:10 PM   #10
rrk's Avatar
Rewards Points: 1,366
Once the flow switch activates the FD is coming, out of service or not
Best bet is to call in sprinkler company or have lots of insurance for the clean up
rrk is online now
Old 02-13-2019, 09:11 PM   #11
rrk's Avatar
You should see the aftermath of a halon system going off and the cost of cleanup is astronomical
rrk is online now
The Following 2 Users Say Thank You to rrk For This Useful Post:
rustyjames (02-13-2019), TxElectrician (02-20-2019)
Old 02-13-2019, 09:34 PM   #12
When putting the alarm out service the alarm co. will not call the FD for the duration of the time out. May get local bldg alarms however.
This is how its done for NFPA annual.
Steve
Old 02-20-2019, 04:11 AM   #13
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 1,266
Hit it with a big hammer. It'll come right off. <img src="http://img.contractortalk.com/smilies/jester.gif" border="0" alt="" title="Jester" class="inlineimg" />
Beat me to it!
madrina is offline
Old 02-20-2019, 07:44 AM   #14
rrk's Avatar
Not necessarily it depends on the system, many systems will have the flow switch or tamper switch go directly to the monitoring desk or the FD in addition to tripping the building alarm. Some FDs will even respond to trouble conditions at the FACP. And some forget and respond if it trips well after telling them not to because they think you forgot to call back.
rrk is online now
Old 02-20-2019, 03:58 PM   #15
finisher65's Avatar
Trade: Drywall/carpentry
Rewards Points: 44
We always go through the bldg. engineer, when possible, to shut down the alarm system which includes the alarm monitoring company notifying the local FD when necessary. They know the procedure & whether or not the FD needs to be notified.
finisher65 is offline
Know Your Tile Type tilecleaningTX General Discussion 0 11-21-2012 04:15 PM
Wall tiles in shower ? #1 Handyman Tiling 14 06-25-2012 09:45 PM
Tile trim mitre roo Tiling 3 05-28-2012 01:16 AM
TCNA handbook/ Floor to ceiling tile install HandyHails Tiling 9 09-14-2010 01:18 PM
Funny Craigslist ad for paint work... Splinter Painting & Finish Work 14 06-10-2009 05:43 AM
