How To Check Existing Foundation? - General Discussion - Contractor Talk
Old 06-08-2009, 05:16 PM   #1
MindfulDesign
MindfulDesign's Avatar
Trade: Designer
Question
Im working on a small remodeling job and for the permit weve been asked to verify if one of the walls has an existing footing below. Does anybody know how to check it? Do we need to drill into the floor? Are there some other ways to test something like that? What do usually inspectors do to check it during inspection? Any help appreciated here!!!
MindfulDesign is offline
Old 06-08-2009, 05:19 PM   #2
DJ9222's Avatar
Trade: Mason Contractor
Rewards Points: 150
Re: How To Check Existing Foundation?
dig a hole on the outside.....
DJ9222 is offline
Old 06-08-2009, 05:23 PM   #3
willworkforbeer's Avatar
Trade: home remodeling
No, no. He needs to drill a 2" hole through the floor every 12"
willworkforbeer is offline
The Following 3 Users Say Thank You to willworkforbeer For This Useful Post:
DJ9222 (06-08-2009), Magnettica (06-08-2009), MindfulDesign (06-08-2009)
Old 06-08-2009, 05:26 PM   #4
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Call inspector set up where he wants you to verify and dig hole
Ball busting post
naptown CR is offline
The Following User Says Thank You to naptown CR For This Useful Post:
Old 06-08-2009, 05:43 PM   #5
MindfulDesign
Trade: Designer
The wall is interior so we can't DIG a hole! But I guess will have to do the drilling... Thanks!!!
Old 06-08-2009, 05:46 PM   #6
Remember, 2" hole every 12"
Old 06-08-2009, 05:47 PM   #7
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
I love this guy
rbsremodeling is offline
Old 06-08-2009, 05:58 PM   #8
Originally Posted by rbsremodeling View Post
I love this guy
Old 06-08-2009, 06:05 PM   #9
Kent Whitten's Avatar
Rewards Points: 2,040
Is there a sump pump?
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 06-08-2009, 06:11 PM   #10
I’m working on a small remodeling job and for the permit we’ve been asked to verify if one of the walls has an existing footing below. Does anybody know how to check it? Do we need to drill into the floor? Are there some other ways to test something like that? What do usually inspectors do to check it during inspection? Any help appreciated here!!!
Since you are the only one
who can see the situation,
why don't you try to paint a word
picture here?
Playing twenty questions isn't likely
to get you any help.
neolitic is offline
Old 06-08-2009, 06:29 PM   #11
even just plain old advice from industry experts!
Old 06-08-2009, 06:34 PM   #12
Crock's Avatar
Trade: Fan of Bodger
Rewards Points: 250
Get a can of safety orange spray paint and paint "footing beneath" on the concrete floor next to the wall and show the inspector your discovery.
Crock is offline
The Following 3 Users Say Thank You to Crock For This Useful Post:
B.K (06-08-2009), DJ9222 (06-08-2009), rbsremodeling (06-08-2009)
Old 06-08-2009, 06:36 PM   #13
Yes, but not in this particular house.
Old 06-08-2009, 07:11 PM   #14
B.K's Avatar
Rewards Points: 75
Hahaha! You Reeka!!!!
You laugh because I'm different...........
I laugh cause I just farted!
B.K is offline
Old 06-08-2009, 07:13 PM   #15
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Your breaking up concrete pal, good luck
Chris
Chris Johnson is offline
Old 06-08-2009, 09:42 PM   #16
DJ9222's Avatar
Rewards Points: 150
Taking odds on the chances of there being a footing under the wall...lol 100 to 1...
DJ9222 is offline
Old 06-09-2009, 06:23 AM   #17
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
Actually seeing the footing under the wall........priceless!
Seriously, mindfuldesign, as a designer, you know to check if the wall is a bearing wall. If it is, assume a footing, verify everything. If it is not a bearing wall, assume no footing, verify everything. If it needs to be a bearing wall, assume no footing, verify everything.
As Chris said, you are breaking up concrete or using a latrine shovel in the crawl space.
__________________________________________________ ___________
I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET?
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline
Old 06-09-2009, 07:45 AM   #18
General Contractor
greg24k's Avatar
Rewards Points: 8,100
Here is one way
greg24k is offline
Old 06-09-2009, 09:49 AM   #19
Moderator
Double-A's Avatar
Assuming this is a slab on grade or a filled slab foundation, you're going to have to break concrete and dig.
Inspectors would have checked the plans and the dirt work prior to allowing concrete to be poured. That is how they would check it during construction. Now that the concrete is poured, your only option is to dig down and expose the footing for them to see.
If there isn't, then you're looking at a great deal of work to put one under it.
Good luck.
"My clients wishes are the center of my attention." -- David Guido, a contractor in Woodstock, N.Y.
New York Times, July 20, 2006
Double-A is offline
Old 06-09-2009, 10:09 AM   #20
JonM's Avatar
Rewards Points: 1,242
How much money you got?...
JonM is offline
Foundation Underpinning - How To? ChrisFlooring Concrete & Paving 7 06-25-2009 10:23 PM
Tying into existing roof Milhaus Framing 9 11-06-2008 12:03 PM
Anyone have experience with Thoroseal to waterproof bsmt foundation? Jim S. Construction 1 08-26-2008 10:53 AM
foundation repair odellconstruct Concrete & Paving 3 04-01-2008 09:58 PM
paycheck stub carm File Swap 2 06-29-2007 08:34 PM
