How To Cap Off 8" Concrete Block Wall - General Discussion - Contractor Talk
Old 09-19-2008, 08:45 PM   #1
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 5,482
Ive never done this before so not sure whats out there for it. At a apartment building the front wall of the building is up above the roof by about 3'. It has a shed roof on it, its like the old building you see on the main street in old towns where it has just a flat wall on the front.
The problem is the building has some kind of mexican look, has some concrete arches and alot us stupid stuff up there that is crumbling and needs to go.
I want to flatten the top of that wall out and take 1 row of block off the top. Ill have to cap the top of it with something. Anyone have a good idea on what to use? Ill try to get a pic of the place up.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 09-19-2008, 09:00 PM   #2
Tom R's Avatar
Rewards Points: 2,036
Re: How To Cap Off 8" Concrete Block Wall
Sounds like a parapet wall and all depends on what look you/and the customer are trying to achieve.
12" wide slabs of stone sound nice to me, - - and also alternating the height sounds even better.
Tom R is offline
Old 09-19-2008, 09:07 PM   #3
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
I thought parapet wall as well but his description is throwing me off a bit. I think its something else because he said front wall
rbsremodeling is offline
Old 09-19-2008, 09:14 PM   #4
Tom R's Avatar
Front wall, side wall, rear wall, - - no difference that I ever heard of . . .
a quick search finds this . . .
http://www.masonryconstruction.com/i...ticleID=465282
Tom R is offline
Old 09-19-2008, 09:15 PM   #5
EVIL GENIUS
I think it is called a parapet wall, its about 3' above the roof, its only the fron wall of the building.
U.S. Coast Guard
Old 09-19-2008, 09:19 PM   #6
I stand corrected. They only refer to side walls as parapet walls here. Because buildings are on the sides an the object is to prevent fire etc, from spreading to the adjacent buildings. But that is what the building departments here refer to parapets walls here and that is normally their function. I learned something today
Old 09-19-2008, 09:20 PM   #7
Snow Man's Avatar
budget , budget , budget ?/?/?
Snow Man is offline
Old 09-19-2008, 09:23 PM   #8
Teetorbilt's Avatar
In another place and time we'd seat booze bottles in mortar and then come back later and bust off the tops with a chain.
Seriously, you want to try to match the wall to the building. For a south western/spanish look a simple rounded concrete cap might suffice. With a barrel tile roof on the house, barrel tiles on top of the wall look good, expensive but good.
Albert Einstein
Teetorbilt is offline
Old 09-19-2008, 09:27 PM   #9
Originally Posted by Teetorbilt;498901[B
]In another place and time we'd seat booze bottles in mortar and then come back later and bust off the tops with a chain[/B].
They still do that here. It keeps the neighborhood thugs from coming on the roof and breaking in through the roof's access panel. along with the adt wireless sensor of course
Old 09-19-2008, 09:39 PM   #10
Railman's Avatar
Trade: Railing
Rewards Points: 1,219
In your area, the reason it's probably crumbling is due to constant freeze/thaw cycles, as do we south of you in Cincinnati.
I recently went through something similar on my shop that I bought a few years ago. It was built with 12" block with 3' or so high wall above the roof around the perimeter, with 4x16 solid caps. After many freeze thaw cycles, the cap developed cracks in the cap, & caused all sorts of leaks. I reset, & trimmed some of the caps, & then braked an aluminum cap from .032? x 24" alum coil stock, & installed with 1/4" fasteners & adequate urethane caulk at the seams. I made the lths in the ball park of 10 depending on the lentgth of the runs. It looks good, & solved all of the leak problems.
Joe
Railman is offline
Old 09-19-2008, 09:43 PM   #11
Back to the original post, Here we use metal capping/flashing
Old 09-19-2008, 10:15 PM   #12
Snow Man's Avatar
in english that would mean help me , he is the fella in home dumpster asking a min. wage helper where the lubricating jelly isle is located. . lmfao
Snow Man is offline
Old 09-19-2008, 11:25 PM   #13
EVIL GENIUS
Its my dads building so CHEAP.
We want to loose the mexico look and cap it with something green. the building has a 42" metal waynes scotting around the bottom so that will be green too and the rest of the building beige.
U.S. Coast Guard
Old 09-19-2008, 11:57 PM   #14
Teetorbilt's Avatar
Another idea, planter boxes filled with whatever your local low maintenance flora is.
Albert Einstein
Old 09-20-2008, 06:10 AM   #15
Tom R's Avatar
Boy, did you butcher that one. I believe it would be w-a-i-n-s-c-o-t-i-n-g, - - all one word (and sometimes spelled with two t's). Not trying to criticize you, - - just for your info . . .
Tom R is offline
Old 09-20-2008, 06:37 AM   #16
genecarp's Avatar
CONCRETE 12''x 2''x 3' pourem then installem
genecarp is offline
Old 09-20-2008, 06:49 AM   #17
Cdat's Avatar
WTF, are you doing here? Shouldn't you be getting drunk or something meaningful?
Cdat is offline
Old 09-20-2008, 06:59 AM   #18
genecarp's Avatar
my troops will be rolling in any minute for the last 4 hr push. just i few minutes of relaxing and chatting about the business that i just cant seem to get enough of. 100 people showing up at 2pm, it should be interesting!!!!!!
genecarp is offline
Old 09-20-2008, 07:18 AM   #19
Gene I totally understand. This place is like therapy for me. I thought I was strange and out there. I realize it's just a contractor thing
Congrats and I hope it last forever and enjoy the cruise.
Block basement wall bed joint crack BreyerConstruct Masonry 4 02-14-2008 09:48 AM
Concrete Revetment Wall Price Q. Trencher Concrete & Paving 5 04-01-2007 09:32 AM
Concrete wall materials??? RCguy Landscaping 0 03-23-2007 01:41 PM
Water seepage thru concrete foundation wall Rrooster Construction 17 11-24-2006 01:05 PM
Low (12" or so) brick garden wall questions bindersbee Masonry 8 04-27-2006 07:31 PM
