How Can I Do This Without Getting Squished? - Page 2 - General Discussion - Contractor Talk
Old 07-03-2014, 11:37 PM   #21
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: How Can I Do This Without Getting Squished?
I'd probably add strapping the upper joists to the upper beam, near the posts, so that when you put in the temp walls (small ones only near the posts?) the joists lift the beam and take the weight off the posts. Without live load there shouldn't be a problem with that.
I don't think there's any way around putting beams under the bottom deck and lifting. I'd get a house mover to do it. All in a day's work for them. Expensive, but a fraction of the cost of re-building.
As everyone else says, I'd sure be careful about the connection to the house. Lifting the outboard end a couple inches could easily be enough to strip the wood around a lag screw - all you need to do is pull a lag through the ledger 1 thread's distance, and it's done. That seems more risky to me than any of the lifting/shoring stuff.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
shanekw1 (07-03-2014)
Old 07-03-2014, 11:56 PM   #22
Love me some Concrete
brhokel606's Avatar
Rewards Points: 4,125
Be prepared to do alot of foundation work, that site might make it necessary.
I know I'm crazy...I love concrete
brhokel606 is offline
Old 07-04-2014, 12:12 AM   #23
AustinDB's Avatar
Rewards Points: 22
With all the engineering and house mover/lifter costs, does it make this project more appealing to demo and rebuild from the ground up?
AustinDB is online now
Old 07-04-2014, 12:20 AM   #24
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Originally Posted by shanekw1 View Post
I am hoping to not have to do much footing work under there.
My span tables say that I should be good to go if I go to a 4 ply 2x12 for a beam.
But are the piers sized properly for that load? Doubtful. If they couldn't get the beam spans right I sure as hell ain't going to trust their piers.
RobertCDF is offline
The Following 2 Users Say Thank You to RobertCDF For This Useful Post:
Rio (07-04-2014), shanekw1 (07-04-2014)
Old 07-04-2014, 12:25 AM   #25
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Damn you.
"Industry without art is brutality"
shanekw1 is offline
Old 07-04-2014, 07:07 AM   #26
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 2
This is so frightening of an idea that I want to do it one day.
Maybe not on this behemoth, though.
Not sure why this would scare you. Obviously you need to analyze the house connection and provide plenty of cables or braces. We do quote a few structural repairs. Being creative has really helped on more than one occasion.
Warren is online now
Old 07-04-2014, 09:11 AM   #27
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Maybe frightening was the wrong word.
Ingenious or outside the box then.
shanekw1 is offline
Old 07-04-2014, 09:24 AM   #28
jb4211's Avatar
Rewards Points: 2,306
I knew what you meant.
If you were truly frightened, you would've walked and not even posted.
Jon
jb4211 is offline
Old 07-04-2014, 09:25 AM   #29
jb4211's Avatar
I've seen your work and I'm betting you already know the solution but wishing there was an easier way that you haven't thought of.
Nope
Jon
jb4211 is offline
The Following User Says Thank You to jb4211 For This Useful Post:
Old 07-04-2014, 11:18 AM   #30
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Didn't read through all the replies, so forgive me if this has already been offered.
I would bolt a piece of heavy steel angle through the lower part of the 6x6 posts and lift the weight off of the beam with hydraulic jacks from the footing below.
Once lifted to desired height, prop down from the second floor beam to insure that there is a backup to the jacks. Remove jacks and post down to footing from angle.
Now support first floor joists as necessary and remove/replace beam.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
Old 07-04-2014, 11:22 AM   #31
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
here's my input
Do you have tools and equipment for lifting structure
at least 7 bottle or screw jacks.
#1 check structural connections.Safety 1st, while underneath this bone crusher
#2 dig all new footings for proper spacing.
#3 temporary wall between 1st & 2nd deck
#4 jack & support deck away from all footing locations
block & support for safety & structural integrity
#5 remove beam and replace existing footings
#6 new post , beams , & beam to beam post for 2nd floor.
DONE BY NOON. GOOD LUCK, PRICE HIGH.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
The Following User Says Thank You to jaydee For This Useful Post:
Old 07-04-2014, 11:39 AM   #32
Needles's Avatar
Trade: Finish Carpenter
Rewards Points: 1,682
Nobody here work with shoring towers? Might want/have to pour some temp support pads. Maybe some cribbing would work. Definitely may want a engineer's plan for the shoring.
http://www.safway.com/PDF/ORN1512.pdf
Have used these systems to form and pour cast in place bridge beams. Using these would make that child's play
Needles is offline
Old 07-04-2014, 11:46 AM   #33
I'm The BOSS
jaydee's Avatar
Shoring towers for a 10 x 50 deck ?
There's only six bearing points to ground, (it looks like)
Just, think it through, it's not that much weight, It's a deck......
Facebook
jaydee is offline
Old 07-04-2014, 11:55 AM   #34
Needles's Avatar
I know the cost of erecting probably 2 towers most likely one. Would trump pouring pads and building temp walls. What you don't know how to build shore towers? Build on cribbing 2-3 man hours max. Maybe you need a background check?
Needles is offline
Old 07-04-2014, 12:09 PM   #35
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
4 bearing points to the ground.
shanekw1 is offline
Old 07-04-2014, 02:08 PM   #36
I'm The BOSS
jaydee's Avatar
If that question is to me.
cribbing, Enough for 4 or 5 x 9 ft tall. how much is that $$$$
if I was doing it.
The job is done already, w/o shoring towers.
But, that's just stupid me , ...
Facebook
jaydee is offline
Old 07-04-2014, 02:12 PM   #37
I'm The BOSS
jaydee's Avatar
even easier, you'll be fine.
shoring towers or not......
Facebook
jaydee is offline
Old 07-05-2014, 01:02 PM   #38
Needles's Avatar
if I was doing it.
Crib the shores, use the screws on the shore legs to support and raise the structure. I am done before you.
Needles is offline
