How Can House Wrap Serve As Air Seal With 1000 Siding Nails Piercing It? - General Discussion - Contractor Talk
Old 12-03-2019, 11:46 AM   #1
wootoot's Avatar
I am at sheathing stage and am trying to figure out the best way to air seal. Should I;
1) caulk internally everywhere, or -
2) rely on a super tight house wrap plan using tape over all joints, then 15lb felt using cap nails.
Either way, aren't the 10000 siding nails going to create 10000 little entry points for air to enter/escape?
Thanks
wootoot is offline
Old 12-03-2019, 11:57 AM   #2
Fishindude's Avatar
Trade: Industrial
Rewards Points: 998
Re: How Can House Wrap Serve As Air Seal With 1000 Siding Nails Piercing It?
If there is a nail in those holes the air can't pass thru.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Golden view (12-03-2019)
Old 12-03-2019, 12:00 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,081
Caulk and foam.
https://www.energyvanguard.com/blog/...an-Air-Barrier
MarkJames is online now
ScipioAfricanus (12-03-2019)
Old 12-03-2019, 12:01 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,048
I thought house wrap was supposed to have holes in it.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 12-03-2019, 12:24 PM   #5
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 744
House wrap is not an air sealer.
It's a vapor barrier.
Old 12-03-2019, 01:33 PM   #6
avenge's Avatar
Rewards Points: 34
You would think a GC would know that.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
Seven-Delta-FortyOne (12-03-2019)
Old 12-03-2019, 01:39 PM   #7
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,046
Actually I don't believe that is even true...I think most manufacturer's call them weather resistant barriers. A true vapor barrier goes on the warm side of a wall.
overanalyze is online now
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
donerightwyo (12-03-2019), Golden view (12-03-2019)
Old 12-03-2019, 04:48 PM   #8
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 130
A WRB can act as an air & water barrier if installed properly - nails don't matter unless you pull it out leaving a big hole --- vapor retarders / barriers is another can of worms, especially where to place them, what to use, etc...
http://thehtrc.com/category/home-rel...ing-insulation - ton of pieces for you on air sealing, etc...
SLSTech is online now
The Following User Says Thank You to SLSTech For This Useful Post:
BlueRidgeGreen (12-03-2019)
Old 12-03-2019, 05:58 PM   #9
Trade: Highwayman
Rewards Points: 744
Correct.
It doesn't block vapor, it allows vapor through it. It blocks water in its liquid form.
Hence WRB.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Golden view (12-03-2019), overanalyze (12-03-2019), SmallTownGuy (12-03-2019)
Old 12-03-2019, 06:06 PM   #10
fjn's Avatar
Trade: mason
Rewards Points: 11,196
Do a rain screen wall,the batten strips over the studs will solve that question + it is the much better system to employ.
fjn is offline
Old 12-03-2019, 06:36 PM   #11
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 252
Thanks
Short answer: No, not really.
Golden view is offline
Old 12-03-2019, 06:59 PM   #12
MarkJames's Avatar
Not all house wrap keeps out water, anyway.
I think some is just for covering the crappy sheathing job and making it look like progress.
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Golden view (12-03-2019), TheConstruct (12-03-2019)
Old 12-03-2019, 07:42 PM   #13
Box Builder
Morning Wood's Avatar
Rewards Points: 10,058
Vapor retarder.
Morning Wood is offline
Old 12-03-2019, 07:45 PM   #14
Box Builder
If you really want a bomb proof air sealing job with your sheathing you need to double sheathing the roof and walls using a rain screen. That way your air barrier and water resistant barrier on the walls and roof remains untouched and unbothered with roofing and siding replacement over the years.
Old 12-03-2019, 08:10 PM   #15
TheConstruct's Avatar
Rewards Points: 1,284
How air tight do houses really need to be? I think things are getting way out of hand with this pursuit, causing new issues that didn't use to exist, neccesitating new techniques and equipment to resolve them.
TheConstruct is offline
The Following 3 Users Say Thank You to TheConstruct For This Useful Post:
donerightwyo (12-03-2019), overanalyze (12-03-2019), Seven-Delta-FortyOne (12-03-2019)
Old 12-03-2019, 08:19 PM   #16
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 156
What's that new product (not foam) that can be fogged inside the semi-sealed structure and as it escapes out tiny cracks it seals all those tiny little gaps, replacing the time consuming task of caulking everything?
P42003 is offline
Old 12-03-2019, 08:20 PM   #17
Business Owner
P42003's Avatar
Rewards Points: 156
https://www.greenbuildingadvisor.com...ogy-for-houses
P42003 is offline
Old 12-03-2019, 08:36 PM   #18
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,874
All true. And the trend is going to continue.
SmallTownGuy is online now
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
Seven-Delta-FortyOne (12-03-2019), TheConstruct (12-03-2019)
Old 12-03-2019, 08:51 PM   #19
Trade: Highwayman
Rewards Points: 744
I think it's hilarious that in an effort to supposedly reduce energy consumption, you now have houses that are 100% dependent on 24 hour, electrically operated, whole-house ventilation systems, so your house doesn't rot from the inside, or suffocate you.
And what happens when the power goes out?
Talk about being dependent on the grid.
And these same super-sealed houses are impossible to build without a vast array of toxic, petroleum-based products, that can only be manufactured by a mega corporation.
And have ZERO recyclability at end of life.
The whole "green building" thing is just another scam. Another method of making corporations rich(er).
The Following 6 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Big Johnson (Yesterday), griz (12-03-2019), mrcat (12-03-2019), overanalyze (12-03-2019), SmallTownGuy (12-03-2019), TheConstruct (12-03-2019)
Old 12-03-2019, 09:07 PM   #20
Always Learning
That's the industry right now... creating problems they can sell solutions for...
