High Water Table - Water Seeping In Through Basement Slab - General Discussion - Contractor Talk
Old 07-06-2020, 09:56 PM   #1
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,752
TheConstruct is offline
Old 07-06-2020, 10:03 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,714
Re: High Water Table - Water Seeping In Through Basement Slab
no mitigation plan from a geo-tech guy???...
griz is online now
Old 07-06-2020, 10:30 PM   #3
Oddly enough, one of my current clients is a geo tech but I can't see myself putting the money into a remedy. The mitigation plan involves a shop vac and a dehumidifier. It's our starter house. Mostly unfinished down there. Unusual circumstances with the river beside us being abnormally high for much longer than usual. Still need to b!tch about it though.
Old 07-06-2020, 10:35 PM   #4
Fire up the BBQ
griz's Avatar
did you know about the water table when you built?
any drainage installed?
griz is online now
Old 07-06-2020, 10:51 PM   #5
It's an old house, built in '53. No floor drains and no evidence of perimeter drains although I'm not sure. Downspouts drain into rock pits anyways.
This just started a few days ago so it's new to me. Installing a sump pump may be a good option. I think I'll talk to my geo tech client tomorrow.
Old 07-07-2020, 07:39 PM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,818
Put an interior drain tied into a sump-pump and let it keep pumping.
greg24k is offline
The Following 5 Users Say Thank You to greg24k For This Useful Post:
concretemasonry (07-08-2020), hdavis (07-07-2020), m2akita (07-08-2020), overanalyze (07-09-2020), TheConstruct (07-07-2020)
Old 07-07-2020, 11:11 PM   #7
hdavis's Avatar
Rewards Points: 3,084
Some old houses here have water seeping in all the time. They'll retrofit a sump pump, then use the existing floor as a drainage plain, and put a floor system in that has drainage grid built into the bottom of the sheets, if that makes sense.
hdavis is online now
greg24k (07-08-2020), TheConstruct (07-07-2020)
Old 07-08-2020, 04:39 AM   #8
General Contractor
greg24k's Avatar
Yes, most of them have rat slab, in some, you be lucky if it's 1" thick in places... The last house I did if you hit the slab with a hammer it will crack like ice, so if there is a high water table or moisture content it will bleed through the slab...
Especially around columns because of a point load on the soil, you get the sponge effect it brings water right to the top.
greg24k is offline
hdavis (07-08-2020)
Old 07-09-2020, 05:43 AM   #9
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 346
I get water in my basement during heavy rains. It comes in thru cracks in the walls and floor. I do have a sump pump that gets most of it out.
Recently I started coating the walls with a product called Drylock Premium (Lowes), we'll see how it works. I'm hoping to get the water intrusion to a minimum. I don't think i'll ever get it completely dry.
rjconstructs is offline
Old 07-09-2020, 06:19 AM   #10
General Contractor
greg24k's Avatar
I've seen that on the shelves... Please let us know how that stuff works.
I have seen in similar to your situations DryLok still showed signs of moisture bleeding through, maybe the Premium will solve that issue.
Thanks!
greg24k is offline
Old 07-09-2020, 12:09 PM   #11
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 2,041
https://www.flexsealproducts.com/shop/
rescraft is offline
The Following User Says Thank You to rescraft For This Useful Post:
Kowboy (07-11-2020)
Old 07-09-2020, 08:58 PM   #12
Rewards Points: 346
No thanks on the flexseal
Old 07-09-2020, 09:03 PM   #13
Rewards Points: 346
My bad, it's called Drylock Extreme. It takes 2 coats and if there are any leftover pin holes those have to be hit again.
