Heat Rash/severe Chafing On Inner Thighs? - Page 3 - General Discussion - Contractor Talk
Old 08-31-2012, 07:51 AM   #41
r4r&r's Avatar
Trade: Contractor
Re: Heat Rash/severe Chafing On Inner Thighs?
Originally Posted by BCConstruction
I get it real bad. Without doubt the best thing for it is A&D cream. I have tried everything the last 5 years and this stuff has completely stopped it.
Second that. I get what I refer to as swamp a$$ and when it gets real bad this is the only thing that gets rid of it. If it isn't too bad you can use jock itch or athletes foot spray as a treatment or preventative.
r4r&r is offline
Old 08-31-2012, 08:10 AM   #42
AmeliaP's Avatar
Trade: Masonry
Rewards Points: 1,624
AmeliaP is offline
Old 08-31-2012, 08:52 AM   #43
r4r&r's Avatar
Trade: Contractor
Sweat alot in 107.
r4r&r is offline
Old 08-31-2012, 09:35 AM   #44
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
its crazy how well it works. put it on in the morning where the issues are and your good all day no matter how bad it gets. it used to be so bad for me that i couldnt walk it hurt so bad. im only 180lbs and get it bad.
www.bcconstructionllc.com
BCConstruction is offline
Old 08-31-2012, 09:51 AM   #45
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
Just get a dress, or maybe a kilt?
http://www.constructiongear.com/blak...FQ-R7Qod-wIAtA
heat rash/severe chafing on inner thighs?-kilt.jpg
Aaron Berk is offline
Old 09-29-2013, 09:27 PM   #46
Box Builder
Morning Wood's Avatar
Rewards Points: 9,980
It's called chub rub around here. Lose some weight. :-)
Morning Wood is online now
Old 09-29-2013, 09:30 PM   #47
chewy's Avatar
Trade: Electrical Apprentice and Data Technician.
Rewards Points: 1,208
Buy some loose logger jeans and switch from undewear to jersey lounge shorts underneath them.
chewy is offline
Old 09-29-2013, 09:36 PM   #48
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
5 year old thread, but valuable info here.
You don't need to be heavy to get "The John Wayne". Frame a house in 100 degree heat with wet shorts and a wet tool belt for 8-10 hours a day. It can happen to anyone.
I use Desitin ointment when I know conditions will be ripe for the rub.
loneframer is offline
Old 09-29-2013, 10:02 PM   #49
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Loose weight until your thighs aren't smashed together chaffing each other all day..
ohiohomedoctor is offline
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
Morning Wood (09-30-2013)
Old 09-29-2013, 10:07 PM   #50
Fire up the BBQ
griz's Avatar
Rewards Points: 96
Thigh gap, sort a get the drift from the photo....
griz is online now
Old 09-29-2013, 10:10 PM   #51
GC/carpenter
Calidecks's Avatar
Rewards Points: 702
Wear shorts to work
Calidecks is online now
Old 09-29-2013, 10:39 PM   #52
CarpenterSFO's Avatar
Rewards Points: 2,044
Apparently heat rash can be fatal, because the O.P. never came back. Or maybe he had a mortal allergy to baby powder. One of life's mysteries.
- Bob
CarpenterSFO is offline
Old 09-29-2013, 11:15 PM   #53
JesseCocozza's Avatar
Rewards Points: 810
In the summer (the 10 months between February and December) I wear lightweight shorts, like running shorts with under amour boxers, it's the bunched up cargo shorts that give me the monkey butt. A good dose of gold bond powder after the shower clears it up by the time you wake up.
JesseCocozza is offline
Old 09-30-2013, 01:46 PM   #54
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 14,128
Originally Posted by BKFranks View Post
I know exactly what you need. The baby powder and carnstarch may work for a short time, but what you need is Glide. Runners use it to prevent chafing when running. It comes just like deodarant and you just whipe it on. It works perfect for this because it is what it is made for. You can get it at running stores, sports stores, etc. My wife uses it because she's a marathon runner.
http://www.bodyglide.com/
Ignore all other answers in this thread. This is the only correct answer.
Buy in bulk.
Easy Gibson is offline
Old 09-30-2013, 01:52 PM   #55
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,436
Buy in bulk.
Does that come in 55 gallon drums for fat people like me?
Inner10 is offline
Old 09-30-2013, 02:24 PM   #56
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
No but another product that might help does...
http://amzn.com/B005MR3IVO
Xtrememtnbiker is offline
Old 09-30-2013, 02:43 PM   #57
It really should.
It's the absolute best for this sort of thing. It's the only thing that makes moving in summer time possible for me. I don't do well in the heat.
The Following User Says Thank You to Easy Gibson For This Useful Post:
Inner10 (09-30-2013)
Old 09-30-2013, 04:21 PM   #58
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,691
Originally Posted by Tom R View Post
Maybe just a crazy guess here, - - but maybe you're slightly allergic to your laundry detergent, - - and then the rubbing aggravates it. Try a different brand and using a little less.
If you've got any irritation around your underwear wasteband, or on your shins (under the tops of your socks), that's a sign you're likely allergic to the laundry detergent or fabric softener. If so, stick with the fragrance-free ones and especially avoid all softeners (esp. the ones for the dryer). First hand knowledge, here.
MarkJames is online now
Old 09-30-2013, 05:10 PM   #59
ToolNut's Avatar
Trade: Painting & repairs
Rewards Points: 508
OMG that's sad I just realized I read every post in this thread, and I never had diaper rash.
ToolNut is offline
The Following User Says Thank You to ToolNut For This Useful Post:
whatsacubbard? (09-30-2013)
Old 09-30-2013, 08:33 PM   #60
whatsacubbard?'s Avatar
Trade: cabinetry design, installation.
Rewards Points: 75
I once thought of starting a new remodeling business called "Assless chaps construction". It would kinda be like a naked maid service, but after thinking it over, the clientail would most certainly be limited and quite possibly, not to my liking.
Now, I tell you this because it's the first time I've ever heard of a legitimate reason to actually wear them. Just saying.
whatsacubbard? is offline
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 Pool Construction & Enclosures 6 10-24-2007 09:33 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 HVAC 2 10-22-2007 09:13 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
