Header Size - General Discussion - Contractor Talk
Header Size
Old 08-10-2009, 06:05 PM   #1
bekshirebuilder's Avatar
Trade: building, remodeling contractor
Header Size
I'm trying to determine if there is a way to get an adequate header in a limited space. Local structural engineers charge a huge fee for this, so I'm hoping to find a solution without one. I need to create a 6' -1.5" opening supporting a roof and 16' ceiling joists 16" o.c. and a 40 lb. live load in a 12' 2x4 wall. The problem is that there is only 4.5" from bottom of opening to bottom of double top plate. Obviously, wood is inadequate. Is there a steel/wood combo or steel beam that would work in this space? Any feedback is welcome.
bekshirebuilder is offline
Old 08-10-2009, 07:32 PM   #2
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
Re: Header Size
I'm intrigued. I know this is going to get kicked into the DIY section, but why do you only have 4 1/2" for a header? Sounds like you need to rethink the area where the door or window will be placed.
Josh
hhicontracting.com
HandyHails is offline
Old 08-10-2009, 07:37 PM   #3
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
Re: Header Size
I agree.Sounds like there should be more room to put in a bigger header.
7' ceilings perhaps?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 08-10-2009, 08:09 PM   #4
framer
steves's Avatar
Trade: framing
Rewards Points: 150
Re: Header Size
No way of telling for sure, we have had to put headers on top of the walls and hung the ceiling off the header.
steves is offline
Old 08-10-2009, 08:12 PM   #5
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,794
Re: Header Size
Get a shorter window perhaps, I think that a steel tube could fit the bill but you will still need it to be engineered.
I could do the calcs. for you for $500.00 (in advance) but I won't sign or guarantee a damn thing.
Andy.
ScipioAfricanus is offline
Old 08-10-2009, 08:13 PM   #6
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 335
Re: Header Size
Sounds like he actually has 7.5 inches if he can cut out both top plates. I bet a double LVL and a steel flitch would probably carry that. Throw that suggestion to your engineer to be sure.
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Deadhead Derek (08-11-2009)
Old 08-10-2009, 08:32 PM   #7
Pompass Ass
bwalley's Avatar
Re: Header Size
Don't your plans have to be sealed by a P.E. or and Architect?
Even if they don't are you really going to go by what you read on the internet?
bwalley is offline
Old 08-10-2009, 08:35 PM   #8
Professional Instigator
rbsremodeling's Avatar
Rewards Points: 2,000
Re: Header Size
Liquid nail header formula Home depot Isle 5 3 shelf from the bottom.
rbsremodeling is offline
The Following 2 Users Say Thank You to rbsremodeling For This Useful Post:
bwalley (08-10-2009), Deadhead Derek (08-11-2009)
Old 08-10-2009, 08:54 PM   #9
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Re: Header Size
Local structural engineers charge a huge fee for this, so I'm hoping to find (some cheap solution on the internet that might result in a structural failure and kill someone....but who cares....I saved a HUGE ENGINEER FEE) a solution without one.
I added the red. So lets start.
You KNOW the situation requires some form or engineering input - its that pesky thing called cost that is bothering you.
By that definition..... you = hack.
I will say this real plainly. Do things right, or don't do anything at all.
wallmaxx is offline
The Following 9 Users Say Thank You to wallmaxx For This Useful Post:
bwalley (08-10-2009), carpentershane (08-10-2009), Deadhead Derek (08-11-2009), mikec (08-10-2009), nEighter (08-11-2009), platinumLLC (08-10-2009), rbsremodeling (08-10-2009), ScipioAfricanus (08-10-2009), SLSTech (08-10-2009)
Old 08-10-2009, 11:58 PM   #10
jtpro's Avatar
Trade: Construction Assistant Superintendant/Remodeler
Re: Header Size
In a case like this you must first establish the co-tangent.
Once determining the co-tangent divide it by the co-sequent.
The remainder will give you the load aberrance.
I CAN NOT STRESS THIS ENOUGH…..CARRY the Ought!!!!!
Once the remainder has been established or in this case the “sequent” we add the 4.5” and end up with the non variable of TREE-FIDDY!
Put that on your plans and get your inspector to sign off DONE DEAL!
Let us know how it turns out!
jtpro is offline
The Following User Says Thank You to jtpro For This Useful Post:
genecarp (08-11-2009)
Old 08-11-2009, 12:21 AM   #11
Code Nerd
Deadhead Derek's Avatar
Trade: Historic Preservationist / Furniture Maker
Rewards Points: 250
Re: Header Size
www.cnn.com
Dateline: Berkshires, NY
Local handyman found dead under collapsed home...
www.darkstarltd.net
Hand-crafted Traditional Masonic Furniture
and Coffins
Deadhead Derek is offline
Improper Header Size greg24k Framing 9 03-27-2009 07:18 PM
Is this an incorrect header Maplehead Carpentry Picture Post 10 10-06-2008 06:54 AM
Header Size TriadMaint Framing 9 04-01-2006 08:18 AM
Header Size TriadMaint Carpentry 6 02-03-2006 09:03 AM
Header size deisel_22 Framing 13 10-15-2005 06:06 AM
