Hanging Porch Swing From A Beam Held By Joist Hangers One Each End - General Discussion - Contractor Talk
Old 07-06-2019, 03:49 PM   #1
micro123's Avatar
Trade: Framing
Rewards Points: 50
If I was framing this from scratch, it would go a lot different. But I need to work with what I can get to on this remodel, so looking for any input.
I wish that I could notch the center beam (red color in the photo) into the side wall, or place on top of the current walls, but its not possible.
A porch swing with a max of 800 pounds will hang from it.
I guess I just don't love trusting joist hangers on both ends of a support. I've always built things from the advice of "if all man-made fasteners disappeared, would it still hold?" and this doesn't pass that test.
Thoughts?
https://i.imgur.com/MOAc3ng.jpg
micro123 is offline
Old 07-06-2019, 04:01 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,724
Re: Hanging Porch Swing From A Beam Held By Joist Hangers One Each End
wouldn't be so worried about the hangers as i would be the load on the 2x8 beam.
what is the span of the 2x8 & grade of lumber?
span of 2x10's?
and there is nothing wrong with "man made fasteners"....
they are a way of life for us out west and we don't think twice about them.
perhaps different mind set where hardware is not so prevalent in the design or codes.
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
greg24k (07-12-2019), Rio (07-06-2019)
Old 07-06-2019, 04:06 PM   #3
micro123's Avatar
Trade: Framing
Rewards Points: 50
span of 2x10's?
Probably #2.
Span is only 8 feet on the double 2x10's.
It's an outdoor entrance way.
I was thinking double 2x8's spanning inbetween and the span is only 6 feet.
I can't imagine there would be much deflection there.
You know how it is - when someone ingrains something in your head when you're learning the trade, it sticks with ya.
micro123 is offline
Old 07-06-2019, 05:02 PM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 1,056
Just looked in the Simpson catalog, a double 2x8 hanger like a LUS28-2 has an allowable floor load of 1,315 lbs........... they are very strong.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
hdavis (07-06-2019)
Old 07-06-2019, 05:31 PM   #5
micro123's Avatar
Trade: Framing
Rewards Points: 50
Yep, I pulled out the load table too. (Thank you for checking as well)
Just wanted some reassurance!
micro123 is offline
Old 07-06-2019, 06:28 PM   #6
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Jesus Jenny, the old folks in town would hand the wooden porch swings from the 2x4 porch rafters without a moments concern.
SmallTownGuy is offline
The Following 3 Users Say Thank You to SmallTownGuy For This Useful Post:
griz (07-06-2019), onmywayup (07-07-2019), TxElectrician (07-06-2019)
Old 07-06-2019, 06:41 PM   #7
Fire up the BBQ
griz's Avatar
yea true but,.......
if something happened, swing fell down, they could just say what swing we don't remember putting it up....
griz is online now
Old 07-06-2019, 06:44 PM   #8
Mordekyle's Avatar
Rewards Points: 5,966
Beam on top of the joists?
Mordekyle is offline
Old 07-06-2019, 09:53 PM   #9
micro123's Avatar
Trade: Framing
Rewards Points: 50
Haha. I prefer not to have that liability!
micro123 is offline
Old 07-06-2019, 11:15 PM   #10
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,496
I'd be more concerned about the lack of braces due to a live load on that. Especially swinging.
Mike.
_______________
Calidecks is offline
hdavis (07-06-2019)
Old 07-06-2019, 11:45 PM   #11
hdavis's Avatar
Rewards Points: 1,032
Definitely needs bracing front to back and side to side.
I have no idea how a swing gives an 800 lb point load in the center instead of 2X 400 lb loads closer to the ends of the beam.
I've done something similar, but went with an a-frame style with 2X12 for the legs and chain to attach to. Even a 2X4 us good enough as a spreader when you attach at what would be your beams over the posts.
I was using 16' long legs, so I used strong backs on 2X4s for them.
hdavis is offline
Calidecks (07-07-2019)
Old 07-07-2019, 12:05 AM   #12
GC/carpenter
Calidecks's Avatar
Yup, then the 2x4 is only needed to keep the A-frames together and from spreading.
Mike.
_______________
Old 07-07-2019, 12:07 AM   #13
micro123's Avatar
Trade: Framing
Rewards Points: 50
Mike.
_______________
You guys are talking about bracing the wall on each side?
It’s not going anywhere haha.
micro123 is offline
Old 07-07-2019, 12:12 AM   #14
GC/carpenter
Calidecks's Avatar
Itís not going anywhere haha.
No, bracing the swing structure. braces for lateral movement. We call them knee braces where I come from.
Mike.
_______________
Old 07-07-2019, 12:13 AM   #15
micro123's Avatar
Trade: Framing
Rewards Points: 50
Perhaps my drawing was not very good.
This isn’t a swingset.
I need to install a joist between two walls, in order to support a porch swing.
The walls are solid and they have a double 2x10 beam in both of them.
I’m simply talking about the safest way to attach the joist that will run from Wall A to Wall B and will hold the swing.
My thought was to simply use joist hangers to hold the joist between Wall A and Wall B.
However, I typically prefer to run joists on TOP of the beam for best support, so I wanted to make sure that a joist hanger can not only support the dead load, but also the swinging motion.
micro123 is offline
The Following User Says Thank You to micro123 For This Useful Post:
hdavis (07-07-2019)
Old 07-07-2019, 12:15 AM   #16
GC/carpenter
Calidecks's Avatar
Your drawing reflects posts and beams.
Mike.
_______________
Old 07-07-2019, 12:15 AM   #17
micro123's Avatar
Trade: Framing
Rewards Points: 50
No bracing the swing structure. braces for lateral movement. We call them knee braces where I come from.
Mike.
_______________
Ahh, I gotcha.
So you’re talking about running a knee brace from under the hanger to the joist that’s is holding the swing.
micro123 is offline
Old 07-07-2019, 12:17 AM   #18
GC/carpenter
Calidecks's Avatar
Ahh, I gotcha.
So youíre talking about running a knee brace from under the hanger to the joist thatís is holding the swing.
Not neccessary, if those walls are solid. I thought it was just posts and beams. That does however depend on what's holding the walls together.
Mike.
_______________
hdavis (07-07-2019)
Old 07-07-2019, 12:18 AM   #19
micro123's Avatar
Trade: Framing
Rewards Points: 50
Ahh, I gotcha.
Mike.
_______________
I appreciate your guidance Mike. Thank you.
micro123 is offline
Old 07-07-2019, 11:11 AM   #20
hdavis's Avatar
Just hangers, like Mike says.
hdavis is offline
