Hand Nails Vs Gun Nails - General Discussion - Contractor Talk
Old 09-18-2015, 06:50 AM   #1
professional
hrdwrkr's Avatar
Trade: home remodeler
Rewards Points: 358
I read up on building info at night before going to sleep (yes I am an exciting guy). I noticed codes pertaining to using 10d , 16d , & 20d nails respectively. I am guessing those codes were developed many years before guns. In side by side comparison the gun nails dont look anywhere as strong as the hand nails.
I realize you can frame an entire house with gun nails and the inspector will never notice, they just look at the structure of the framing, Ive never seen any inspector say anything about nails.
I know using the guns cuts the time in half( I actually figured it out on a job once,but Is this an issue for you?
hrdwrkr is offline
Old 09-18-2015, 07:03 AM   #2
Box Builder
Morning Wood's Avatar
Rewards Points: 10,246
Re: Hand Nails Vs Gun Nails
I hear your argument. But, nowadays you have to take into account steel qualities. With all the crap being made in china I bet there are some low quality gun and hand nails out there. I think some gun nails are actually stronger than hand nails. Joist hanger nails for instance.
Morning Wood is online now
Old 09-18-2015, 07:08 AM   #3
General Contractor
greg24k's Avatar
Rewards Points: 8,478
There is a Hitachi framing nail gun which can take a 3 1/2" nail. Most Engineers will substitute 3 1/4" nail (since its the most common nail size for framing) in lieu of 3 1/2".
greg24k is offline
Old 09-18-2015, 09:25 AM   #4
hdavis's Avatar
Rewards Points: 1,556
This is like any other element used in building. If it isn't called out in the code, there should be a manufacturer's report stating it meets the code / standard and under what conditions.
I haven't seen a code official question the use of gun nails - partly because I believe they know the manufacturers have gone through getting approval, plus it's a low risk item.
I won't mention some people will leave empty structural screw boxes lying around when an inspector comes through....
hdavis is offline
Old 09-18-2015, 09:45 AM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 410
In my world gun nails & guns are a constant source of aggravation.
Framers miss specs on nails and that virtually every gun driven fastener must be finished with a hammer so there is not over penetration.
Residential, guns can be a convenience and may save labor, but I've been on a crew where we were side by side with us hand banging vs a nail gun crew and we beat them. Just depends....
griz is offline
fjn (09-19-2015)
Old 09-18-2015, 09:48 AM   #6
hdavis's Avatar
Here's the gun nail document.
http://www.bostitch.com/xhtml/litera...v_Dec_2011.pdf
hdavis is offline
Old 09-18-2015, 09:51 AM   #7
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 82
I fail to see how it's at all possible for a hand banging crew to come close to a crew with guns that would be pretty unreal. Unless maybe the crew with guns was using paslodes......than I believe it.
Sent from my SAMSUNG-SM-G870A using Tapatalk
NJGC is offline
Old 09-18-2015, 09:55 AM   #8
hdavis's Avatar
Just depends....
X2 on that. Remodeling, sometimes you can't really get room to swing a hammer, and other times you can't get a gun in at all.
hdavis is offline
Old 09-18-2015, 10:01 AM   #9
hdavis's Avatar
If the crew is gun driving short then hand banging to get the correct drive, switching back and forth takes a lot of time. I have to do this working alone at times. Gun a section, then go back over it all to do the final drive. Toe nailing studs on a reno where you can't stand a wall would be a pretty common example, or any toe nailing.
hdavis is offline
Old 09-18-2015, 10:05 AM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 410
Well it's plenty possible and has happened more than once.
This was pure production framing by a very experienced crew.
Maybe with the constant use of guns and the belief that they are always faster & more efficient today's framers are just not as fast at hand nailing as we were in the olden days.
griz is offline
The Following 6 Users Say Thank You to griz For This Useful Post:
66 Shelby (09-18-2015), Calidecks (09-18-2015), greg24k (09-18-2015), kiteman (09-18-2015), SmallTownGuy (09-18-2015), Texas Wax (09-18-2015)
Old 09-18-2015, 10:26 AM   #11
General Contractor
greg24k's Avatar
I agree with Griz, most guys on the framing crews today couldn't drive a 10p nail with a hammer if their life depended on.
Experienced crew will eat a 50LB box of 10D nails before you blink, or experienced sheeting crew will nail plywood using sinkers before you blink without a miss, in comparison to a framing crew today with guns who can hit a stud for s^*t without putting 100 nails in one stud to make sure they didn't miss
In the 80's we did everything by hand, framing, sheathing, roofing, trim work, etc.
Sure it's faster with a gun, but is it better? I would have to give some serious thought on that to make a comparison.
greg24k is offline
The Following 4 Users Say Thank You to greg24k For This Useful Post:
66 Shelby (09-18-2015), Calidecks (09-18-2015), griz (09-18-2015), Texas Wax (09-18-2015)
Old 09-18-2015, 10:45 AM   #12
txgencon's Avatar
Rewards Points: 450
If an inspector can't tell the difference between hand nailing and gun nailing, he's probably not going to red tag much of anything.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
The Following 2 Users Say Thank You to txgencon For This Useful Post:
greg24k (09-18-2015), griz (09-18-2015)
Old 09-18-2015, 10:48 AM   #13
NJGC's Avatar
Rewards Points: 82
Maybe the guns are slower on the west coast...
NJGC is offline
The Following 2 Users Say Thank You to NJGC For This Useful Post:
Dirtywhiteboy (09-19-2015), Framer53 (09-18-2015)
Old 09-18-2015, 11:06 AM   #14
avenge's Avatar
Rewards Points: 110
What's a hand nail? Those boxes of rusty metal sticks I have?
avenge is offline
Old 09-18-2015, 11:52 AM   #15
hdavis's Avatar
Some gun nails use the same approved nailing pattern as hand drives, others don't Once it's in the wood, nobody is going to pull one out and check diameter to see if it meets or not. If someone specd what fasteners to use, they might check the purchase records to make sure what they specd was what was bought.
hdavis is offline
Old 09-18-2015, 12:00 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 410
On school jobs the Engineer & Inspector must see and approve the nail before use.
Biggest issue comes up nailing shear wall & sheathing. Nail can not break top veneer. Gun is set to leave nail 1/4" or so proud then hand driven flush.
West coast guns are just as fast as anyone elses....
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
fjn (09-19-2015), hdavis (09-18-2015)
Old 09-18-2015, 12:09 PM   #17
hdavis's Avatar
I was thinking residential - commercial guys get a lot more headaches. Makes for less corner cutting, though.
hdavis is offline
Old 09-18-2015, 06:43 PM   #18
builditguy's Avatar
Rewards Points: 1,934
Wow. This is something I have actually thought about.
Started out with hand nails. Now I don't even have 16d cc in the truck.
A couple differences. With air nails, there are alot more nails, nailed, than by hand drive. Guys will just tap alot more times than drive by hand.
I know this from personal experience. Even I put in more nails with pneumatic than by hand drive.
I also know the air nails hold better than hand drive. Try to pull them out. It's not easy.
As a side note, the house across the street just got re-roofed. I remember when I worked as a sub doing the roof. The General required all staples in the felt to be 1/2" apart. All nails in singles required 7 hits per nail.
My elbow hurts today.
builditguy is offline
Old 09-18-2015, 07:07 PM   #19
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
4 of the toes on my left foot agree with your assessment.
Mine hurts every day, and I put down my Vaughn and picked up a air gun in the mid 80s.
SmallTownGuy is offline
Old 09-18-2015, 08:37 PM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 322
Been a while since you pulled a 60 year old 20D spike, eh?
One thing hand nailing excels at is pulling framing members together. A gun slams that thing in so fast the wood doesn't have time to move and get all cuddly with its mate.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
66 Shelby (09-18-2015), fjn (09-19-2015)
Deck Screws vs Joist Nails subybohn Decks & Fencing 105 06-25-2018 06:54 AM
Ramset .27 caliber shots and nails WarriorWithWood Contractor Swap 0 06-05-2013 12:31 AM
Drive nails with an excavator. tgeb Excavation & Site Work 10 01-08-2012 10:05 PM
