GoPro Stair Brackets??? - General Discussion - Contractor Talk
Old 11-07-2008, 01:33 AM   #1
curapa's Avatar
Trade: Carpentry / Fencing / Decks
I was just browsing this site when I noticed the GoPro stair advertisement to the side of the screen. http://www.goproconstruction.com/
I was curious if anyone had tried this crap? I fail to see the point.....
www.ParkerFenceandDeck.com
curapa is offline
Old 11-07-2008, 09:03 AM   #2
Remodeling GC
kevjob's Avatar
Rewards Points: 2,134
Re: GoPro Stair Brackets???
for DIY and hacks who can't figure out rise and run.
kevjob is online now
Old 11-07-2008, 09:15 AM   #3
JonM's Avatar
Rewards Points: 1,242
I would think, if you were really a "pro", you wouldn't need those expensive things.
JonM is offline
Old 11-07-2008, 10:12 AM   #4
Bodger's Avatar
Rewards Points: 2,024
Seems like I have been seeing these kinds of things for years around the big box store, specifically aimed at DIY's for deck stairs. You're right, if you know how to calculate rise and run, know where to add and subtract for finish treads and can nothc a stringer or rout grooves and dadoes in a stair carriage, what he hell would you bother with these things for.
Training wheels.
Bodger is offline
Old 11-07-2008, 10:58 AM   #5
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 3,924
Ok lets say 2 yrs down the road you need to move something down the stairs - your buddy slips and drops it on the tread and it cracks (you did sheetrock under the stairs) how do you replace the tread?
It is now screwed from underneath.....Hmm
kevjob & jonm Got it right Pros dont use crap like that. = my.02
Snobnd is offline
Old 11-07-2008, 11:59 AM   #6
curapa's Avatar
The thing is, you still have to find your riser height by doing the math. All the brackets do is keep you from cutting the stringer, you still have to know where to line up the marks on the brackets, you still have to cut the top and bottom of the stringer.
I see products like this from time to time and just wonder whether the person that invented the item really thinks it's a good idea or if they just want to money for their BS product?
curapa is offline
Old 11-07-2008, 12:04 PM   #7
Carpenter
RizzoMaryland's Avatar
My stairs are recessed into a skirt board, glued and screwed from underneath anyways. How would YOU replace these stairs?
No different from the example you gave.
"An idea is salvation by imagination"
Frank LLoyd Wright
RizzoMaryland is offline
Old 11-07-2008, 04:28 PM   #8
mikec's Avatar
Trade: Boss
Rewards Points: 510
ever see those pre cut stair stringers at big orange? Must work great for any height deck!
mikec is offline
Old 11-07-2008, 04:31 PM   #9
Bodger's Avatar
I've seen those and always scratched my head in wonderment (is that even a word?). So I guess you get a half riser at grade for a deck if you aren't lucky on the math.
Bodger is offline
Old 11-07-2008, 04:37 PM   #10
DavidC
DavidC's Avatar
Rewards Points: 2,006
Nah, you just put where you feel it's right. Then serve your guests double shots. They'll look fine.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 11-07-2008, 04:49 PM   #11
Bodger's Avatar
I remember seeing Tom SIlva and Norm Abrams do that very repair years ago on TOH. But I can't recall how they did it. Probably using some fancy $25,000 piece of equipment that was donated to Norm for promotional purposes.
Bodger is offline
Old 11-07-2008, 05:11 PM   #12
Snobnd's Avatar
Curapa- Info was only example shown in the website. If its a skirtboard - you dont need brackets! Right?
I was only talking about top mount.......My bad
Snobnd is offline
Old 11-07-2008, 05:46 PM   #13
Carpenter
If the nosing of the tread is broken or cracked, then you can use a dowel plug of the same species to reattach it. It works really well once the glue is dry.
Frank LLoyd Wright
Old 11-07-2008, 07:03 PM   #14
rbeck3@ec.rr.co's Avatar
Trade: framer-inside/outside trim- asphault roofing/remoldeling
Rewards Points: 25
YOU just might need to call a carpenter.
passingwindII
rbeck3@ec.rr.co is offline
Hickory Stair Treads dokuhaku Flooring 66 11-20-2008 12:20 AM
varathane stair treads more traction? surferal Flooring 0 09-28-2008 07:58 PM
SS Ledger Brackets, real or fantasy? orson Decks & Fencing 8 09-26-2008 08:03 PM
stair help ravi2patel Finish Carpentry 9 09-13-2008 02:58 PM
minimum stair requirement, broken back te12c02w Carpentry 12 04-28-2008 06:32 PM
