GIVEAWAY: SHARP 9,000 BTU Ductless Mini Split From ComfortUp - General Discussion - Contractor Talk
Old 06-09-2016, 12:02 PM   #1
Texas Strong
Cricket's Avatar
Trade: Administrator
Rewards Points: 12,084
GIVEAWAY: SHARP 9,000 BTU Ductless Mini Split From ComfortUp-cu-forum.jpg
We have partnered with ComfortUp to give away a SHARP 9,000 BTU Ductless Mini Split Heat Pump System 22 SEER.
To enter this drawing, respond to the following question.
Where will you use your mini split? (garage, basement, home addition, workshop, “man cave”, etc)
On June 28, 2016 we will do a random drawing from the responses in this thread to select the winner.
Added Note: Responses to this thread should be limited to entering the giveaway by responding to the posted question.
GIVEAWAY: SHARP 9,000 BTU Ductless Mini Split From ComfortUp-forum-comfortup.jpg
The Sharp 9,000 BTU Mini-Split Air Conditioner and Heat Pump System is wall mounted and features unique airflow control to provide heating and cooling for quick and easy comfort with a SEER rating up to 22.0. It includes Sharp's original Plasmacluster Ion Technology, an air purifying system that actively removes airborne mold and viruses, sanitizing the air in the entire space. Inverter technology on all models offers best in class efficiencies with a variety of finely controlled functions working to keep the room at desired comfortable temperatures.
Features & Benefits:
  • Multi Space Function - This function adjusts the airflow and air direction to reach the set temperature quickly in several rooms, and then circulates the air to maintain the temperature.
  • Inverter-Controlled Operation - This function enables quick-cooling operation while limiting fluctuations in temperature and reducing power consumption.
  • Full Power Mode - In this operational mode, the air conditioner works at maximum power to rapidly cool or heat the room.
  • Computerized Dry Mode Operation - The indoor fan motor and the compressor are controlled by the microcomputer to maintain room humidity without dropping the room temperature.
  • Auto & 3-Step Fan Speed Settings - The air conditioner can be set up with an automatic fan speed, or the user can choose from three manually set fan speeds (HIGH/LOW/SOFT)
  • Auto Restart Function - Following recovery from a power shutoff, the unit will automatically restart with the same settings as before the power was cut.
  • Auto Changeover - During Auto Mode operation, the unit will automatically switch between heating and cooling modes to maintain a comfortable room temperature.
  • Winter Cool Function - This function enables cooling operation during the winter season at outside temperatures as low as 14, or down to 5 (Great for Server Rooms & Indoor Gardens)
  • 5º F Auto Cutoff - To protect itself from damage due to freezing, the unit automatically stops when the outdoor temperature drops below 5º F.
Sponsored by: ComfortUp
Ductless mini split heat pump systems, air conditioners, heating & cooling, ETAC & PTAC, HVAC Parts & Accessories from LG, GREE and other top HVAC brands.
"Show respect even to people who don’t deserve it, not as a reflection of their character, but as a reflection of yours."
Cricket is offline
The Following User Says Thank You to Cricket For This Useful Post:
Sir Mixalot (06-27-2016)
Old 06-09-2016, 12:16 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,888
Re: GIVEAWAY: SHARP 9,000 BTU Ductless Mini Split From ComfortUp
I would put it in my shop office. Be a nice little retreat to sit in the AC for lunch and paperwork.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Cricket (06-09-2016)
Old 06-09-2016, 01:00 PM   #3
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
In our basement! It all started when my wife and I put our bedroom in there and let the kids shack up in the rest of the house. Every year, she stays on my tail about getting one to put in there so she can stop going to the spare bed. I keep saying "soon babe, soon".
illbuildit.dd is offline
The Following 2 Users Say Thank You to illbuildit.dd For This Useful Post:
Cricket (06-09-2016), ScipioAfricanus (06-09-2016)
Old 06-09-2016, 01:43 PM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 116
I'm thinking about building a doghouse (seriouly) for my Saint. It would need AC. This doghouse would be like a full size room. That would be perfect!
Calidecks is offline
Old 06-09-2016, 01:45 PM   #5
Capra aegagrus
Tinstaafl's Avatar
This would be perfect for our kitchen area. We're currently using an 8,000 BTU window unit that struggles a bit on really hot days. The extra cooling would take care of that, with the bonus of freeing up that window.
Tinstaafl is online now
Old 06-09-2016, 01:47 PM   #6
Problem Solver
archtimb's Avatar
Trade: Building Maintenance & Operation
Rewards Points: 72
In my Wife's sewing room!
Happy Wife...you know the rest.
archtimb is offline
The Following User Says Thank You to archtimb For This Useful Post:
Old 06-09-2016, 01:49 PM   #7
VinylHanger's Avatar
Rewards Points: 320
Probably my kids room or the Master bedroom. It's where people are most of the time.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 06-09-2016, 01:56 PM   #8
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Shop, Garage, anywhere a little extra is needed, actually any room in the front of the house...would love to test it against that southern exposure...I'm in
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
Old 06-09-2016, 02:17 PM   #9
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
I'm currently building a 10x12 two story play house for my kids in the back yard.
It's about 85% recycled materials (pallets and torn down play structures), and I'm currently waiting on a coffee shop remodel to get a few windows.
A mini split wold make an excellent addition to the comfort level of the play house for my 9 children.
Aaron Berk is offline
The Following User Says Thank You to Aaron Berk For This Useful Post:
Old 06-09-2016, 02:27 PM   #10
Easyfier of Complexitries
digiconsoo's Avatar
Trade: Framing Components
Rewards Points: 1,552
In the office, which is landlocked inside the shop/warehouse
We have a small unit that is noisy, and installed poorly .
But it works......kinda.
So I haven't made it right, low on the honey do list.
A new unit would be sufficient motivation.........probably.
Originally Posted by hdavis View Post
It's probably better you write about something where you aren't functionally ignorant, you're just embarrassing yourself.
Originally Posted by tipitop View Post
Trump is lucky he didn't mess with me.
http://www.digiconsoo.com
digiconsoo is offline
The Following User Says Thank You to digiconsoo For This Useful Post:
Old 06-09-2016, 02:31 PM   #11
tgeb's Avatar
Rewards Points: 24
I would install that beauty in my Garage/workshop. 22' X 36' with 10' walls. It gets really hot in there and really cold in there.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Old 06-09-2016, 02:47 PM   #12
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,246
I have the pad poured for a nice little shop/garage and was thinking of heat/cooling it with a heat pump because I didn't want any combustion appliance in there with sawdust. This would be perfect
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
Old 06-09-2016, 03:19 PM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
9 kids... Give it to this guy I think he could use it!
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
The Following 6 Users Say Thank You to Inner10 For This Useful Post:
BlueRidgeGreen (06-11-2016), Cricket (06-09-2016), Deckhead (06-11-2016), EricBrancard (06-09-2016), jlhaslip (06-25-2016), Xtrememtnbiker (06-09-2016)
Old 06-09-2016, 03:23 PM   #14
MarkJames's Avatar
Rewards Points: 94
I would have it installed into a one bedroom basement apartment. I'm tired of installing the window unit every year.
MarkJames is offline
Old 06-09-2016, 03:50 PM   #15
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 2
For sure in my garage. We fully insulated it when we built it 20 years ago, but it has never had a permanent heat source. AC would be incredible.
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Old 06-09-2016, 03:57 PM   #16
rustyjames's Avatar
Rewards Points: 28
That would certainly be the ticket for my work shop
rustyjames is offline
The Following User Says Thank You to rustyjames For This Useful Post:
Old 06-09-2016, 04:50 PM   #17
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
I would use it in my basement room, ie, my wife's sewing room.
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
Old 06-09-2016, 05:20 PM   #18
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
to be honest i think i would donate it to Habitat,I have what I need..
Tom Struble is offline
Old 06-09-2016, 05:23 PM   #19
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 452
I'd install it in my living room. I have a regular unit in an ugly sleeve.
Lunicy is offline
The Following User Says Thank You to Lunicy For This Useful Post:
Old 06-09-2016, 05:30 PM   #20
mako1's Avatar
Rewards Points: 1,094
In my camper for sure.Mine when out and those original ac units made in Switzerland for campers are more than I can afford right now.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
mini split unit comes precharged? chillypilgrim HVAC 8 01-09-2016 08:42 PM
VFD - running a Blum mini press? PrestigeR&D Electrical 7 05-25-2013 08:47 AM
Mini split leaking water JackP23 HVAC 1 04-19-2013 06:53 PM
Mini split New const. glkirk HVAC 3 04-15-2012 11:07 AM
