GIVEAWAY: PLS 3G Green Laser Level Kit! - Page 3 - General Discussion - Contractor Talk
Old 02-09-2019, 05:47 PM   #41
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 60
Re: GIVEAWAY: PLS 3G Green Laser Level Kit!
I regularly use a torpedo, 2', 32", 4', 6'. Things that come along once in a while: bucket/hose, plate level, lasers, and a plumb bob.
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Cricket (02-09-2019)
Old 02-09-2019, 07:16 PM   #42
AustinDB's Avatar
Rewards Points: 1,532
I have a stable of stabila's and use the 78" often for tile work. Once in awhile I'll pull out a dewalt laser for laying out lines for tile work.
AustinDB is offline
The Following User Says Thank You to AustinDB For This Useful Post:
Old 02-09-2019, 08:30 PM   #43
Sparky540's Avatar
Trade: Electric
2 torpedoes, a digital angle finder for pipe bends, and a two footer
Sparky540 is offline
The Following User Says Thank You to Sparky540 For This Useful Post:
Old 02-10-2019, 08:07 AM   #44
larry228's Avatar
Trade: residential remodeling
Rewards Points: 8
My red laser has replaced most levels for interior work. I still carry 2' and 4' stick, the 6' stick rarely leaves storage.
A green laser has been on my wish list for a long time, the improved visibility would be appreciated
larry228 is offline
The Following User Says Thank You to larry228 For This Useful Post:
Cricket (02-10-2019)
Old 02-10-2019, 11:10 AM   #45
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & wel
Rewards Points: 5,482
depends on what I can find when I need it, I keep a 4ft in my truck, a 7ft in the garage, and probably a few 2 footers laying around. Anything under 2ft gets lost all the time so I have no idea where they are.
For laser levels I have a cheap piece of junk thats better then nothing.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
The Following User Says Thank You to Michaeljp86 For This Useful Post:
Old 02-10-2019, 11:34 AM   #46
hdavis's Avatar
Rewards Points: 1,110
A few string levels, half a dozen torpedo levels, 3 2 footers, 1 32", 3 4footers, 2 80 inch. Rotary laser.
hdavis is offline
Old 02-10-2019, 01:55 PM   #47
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
I keep in my tool pouch a torpedo level, on the truck I have a 2 foot level and a 4 foot level also a six foot, then I have a magnetic torpedo on the truck but I have a 4 foot magnetic I keep in storage for metal stud framing, also on the truck I have a laser plumb bob for framing and a laser torpedo level I use for lay out, tile int walls etc before pinging a line then I have 4 or 5 string line levels for fence work and block and a 4 foot masonry level for block work, I also have a post level (really a plumb c/k), last but least I have a self leveling rotary laser.
Jez I never thought about how many ways I have to c/k for level and plumb, back in the 90's when I was a crew chief we would use a digital level called a "smart level" to set up suspension and steering I think we will see more and more of these in construction not only to read a level but also to shoot a laser line
Still "Shakin" the tree boss
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
Old 02-10-2019, 02:00 PM   #48
Donohue Const's Avatar
Rewards Points: 1,722
mostly stick levels
2' through 8'
keep a torpedo in my pouch
only laser I have is a rotary transit level
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
The Following User Says Thank You to Donohue Const For This Useful Post:
Old 02-11-2019, 10:36 AM   #49
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 438
I still use levels of all kinds in my work.
I often have to figure out and diagnose problems with existing homes in part using levels so that my engineer can come up with a solution.
I use everything from a torpedo level to 6' level to a laser level, not as nice as this one though.
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
Cricket (02-11-2019)
Old 02-11-2019, 10:42 AM   #50
joed's Avatar
Rewards Points: 6
I have several stick levels. 1 foot, 2 foot and 4 foot. One is magnetic to stick to steel poles.
joed is offline
The Following User Says Thank You to joed For This Useful Post:
Old 02-11-2019, 01:02 PM   #51
Lettusbee's Avatar
Rewards Points: 1,480
I have about 10 stabila stick levels, a milwaukee plumb dot and a PLS redline laser. Also a David White Transit.
I'm ready to graduate to green lasers.
Lettusbee is offline
The Following User Says Thank You to Lettusbee For This Useful Post:
Old 02-11-2019, 03:10 PM   #52
Electrical Contractor
C'est Moi's Avatar
Trade: Electrical
Rewards Points: 550
We have a laser but it only does one direction so this would be a nice improvement. Thanks for the opportunity especially since I don't post here alot.
C'est Moi is offline
The Following User Says Thank You to C'est Moi For This Useful Post:
Old 02-11-2019, 03:57 PM   #53
dayexco's Avatar
Rewards Points: 636
always used spectra physics or leica.
would use new green light to level up my rv
dayexco is online now
The Following 2 Users Say Thank You to dayexco For This Useful Post:
Cricket (02-11-2019), tgeb (02-11-2019)
Old 02-11-2019, 04:08 PM   #54
GEERECON's Avatar
Trade: Residential remodeling
Rewards Points: 16
A whole bunch of cheap levels and a couple years ago I invested in a Stabila plate and jamber set.
I have several less expensive red laser levels, none that are my " go to's".
I sure would like to try a green laser
GEERECON is offline
The Following User Says Thank You to GEERECON For This Useful Post:
Old 02-11-2019, 05:43 PM   #55
manchesterspark's Avatar
Trade: Electrical
I have and use A red laser , 2- 4 foot stick levels, 2- 2 foot stick levels, a 6 foot stick level, and multiple torpedo levels.
A green laser would be fantastic addition
manchesterspark is offline
The Following User Says Thank You to manchesterspark For This Useful Post:
Old 02-11-2019, 06:39 PM   #56
J.C.'s Avatar
Rewards Points: 232
I have 6 or 7 different length stick levels, a few torpedo levels, a red beam laser level, a collection of line levels and I think I have a water level around here somewhere but I never use it.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
The Following User Says Thank You to J.C. For This Useful Post:
Cricket (02-12-2019)
Old 02-11-2019, 06:42 PM   #57
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,522
I pretty much just have different length stick levels, did have a water level sometime back they are interesting to use. A laser level would be nice and make my job easier on some of the chopped up houses I work on where the siding need to match up on different levels.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 02-11-2019, 06:43 PM   #58
Lady Dreamer's Avatar
Trade: Roofing and General Contracting
Rewards Points: 896
Yeah you found the right spot!! Lol
Lady Dreamer is offline
The Following User Says Thank You to Lady Dreamer For This Useful Post:
Old 02-11-2019, 08:44 PM   #59
paul100's Avatar
Rewards Points: 60
4 sticks, one manual adjusted laser level and a water level.
paul100 is offline
The Following User Says Thank You to paul100 For This Useful Post:
Old 02-11-2019, 09:16 PM   #60
META's Avatar
Trade: General and Trades
Rewards Points: 7,040
I have a variety of levels. I've been using the same PLS5 for about 15 years. I also have a Stabila 12' plate level and a variety of 24", 48" and 72" bar levels. I also recently purchased a Hilti PM 2LG green line laser.
I like the PLS5 for vertically plumbing points, but the red laser is harder to see in daylight.
The Hilti PM 2LG with green line does both band and laser point.
META is online now
The Following User Says Thank You to META For This Useful Post:
Laser Level Accuracy mobiledynamics Tools & Equipment 1 11-05-2013 03:07 PM
Need help choosing the right laser level nymasterfloors Tools & Equipment 23 07-22-2011 07:21 PM
Best rotary self-leveling laser level doc7string Tools & Equipment 17 05-10-2010 02:29 PM
