GIVEAWAY: PLS 3G Green Laser Level Kit! - Page 2 - General Discussion - Contractor Talk
Old 02-08-2019, 09:15 PM   #21
TimNJ's Avatar
Rewards Points: 4,464
Re: GIVEAWAY: PLS 3G Green Laser Level Kit!
Torpedo, 2', 4', 78" old technology digital, laser, and for precision my transit.
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
Cricket (02-08-2019)
Old 02-08-2019, 09:26 PM   #22
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,186
A few torpedoes, one is the DeWalt with the adjustable angle in it, and a plumbing one with slope measurements.
Several Stabila and Empire stick levels and a Jamber Set. And a beat up old no-name that is covered in mortar. It's my "Masonry" level.
A Stabila plate level.
A Bosch rotary laser with detector for shooting grade.
A Robo-Tools Transit. (Yes, I know how to use it, and still do a lot).
I just broke my Bosch cross-line laser. So if I don't win this, I'll be forced to buy the Bosch GLL 3-330 CG.
I do not, however, have a canal connected to the Nile.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 02-08-2019, 09:52 PM   #23
millhouse's Avatar
Rewards Points: 64
I have 2', 4' and 6' sticks. Also have an cheap rotary laser that rarely gets used - but is very useful when I need it.
millhouse is offline
The Following User Says Thank You to millhouse For This Useful Post:
Old 02-08-2019, 10:20 PM   #24
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 2,242
I have a Bosch optical level , a Bosch crosshairs laser, 4 Stabila R handle, couple of empires , various torpedo levels , line level , and a couple of plumb bobs .
Idothat is online now
The Following User Says Thank You to Idothat For This Useful Post:
Old 02-08-2019, 10:50 PM   #25
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,639
We use several whiskey sticks, I also have a cheap Bosch dot laser. And an old builders level..... oh and most importantly I use my eye!!!!
Jay hole is online now
The Following User Says Thank You to Jay hole For This Useful Post:
Old 02-09-2019, 12:18 AM   #26
back doors to hell put in
Irishslave's Avatar
Rewards Points: 2,618
Torpedo. 1', 2' a 28", 4', 6'-6" jamb level, 7'-12' stabila and 2 cheap semi accurate lasers
I think there's an old 18"er around with broken glass
Television is fake...The internet is real
Irishslave is online now
The Following User Says Thank You to Irishslave For This Useful Post:
Cricket (02-09-2019)
Old 02-09-2019, 01:09 AM   #27
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,254
My levels range from rotary levels to set elevations and post heights, to conventional stick levels. As it sits I've got, a torpedo, 16", 24", 32", 48", 72", 78", 96". The only level I don't own is a level such as the aforementioned PLS small laser. The green beam is particularly appealing.
Mike.
_______________
Calidecks is online now
Old 02-09-2019, 01:13 AM   #28
Stunt Carpenter's Avatar
Rewards Points: 1,728
I have a few sticks and two lasers. Been looking to upgrade my dreamy red line to a green with a better line thickness
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 02-09-2019, 07:48 AM   #29
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,048
Stabila torpedo, 32” and 78”
Empire 2’
Fatmax 4’ that’s only good for level, not plumb. I found that out the hard way so I blackened out the plumb vials. I don’t use this level at all, it’s going to be replaced with a stabila some day.
An old Big Johnson 6’er
A very old transit level that takes eons to set up.
PLS 4 with red laser which I love. I still can’t believe how long it can go on a set of batteries.
Big Johnson is offline
Old 02-09-2019, 08:22 AM   #30
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,844
I have one level. a 40 year old Macklanburg-Duncan 4 ft, solid mahogany. Still have the original plastic sleeve too.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 02-09-2019, 11:02 AM   #31
hrm's Avatar
Trade: gc
Rewards Points: 72
All I have is a cheap rotary laser. A PLS 3G would be a huge help.
hrm is online now
The Following User Says Thank You to hrm For This Useful Post:
Old 02-09-2019, 11:20 AM   #32
RichVT's Avatar
Rewards Points: 919
I have the Stabila jamber set of stick levels (all sizes from torpedo up the the 78") plus their extendable set. 2 three line laser levels. One has a "fuzzy" line and is not repairable. I finally got rid of my water level during the last shop clean out.
RichVT is offline
The Following User Says Thank You to RichVT For This Useful Post:
Old 02-09-2019, 11:48 AM   #33
nw3dogs's Avatar
Trade: Siding Contractor
Rewards Points: 2
Multiple stick levels and a DeWalt laser level. Makes my job much easier
Sent from my E6810 using Tapatalk
nw3dogs is offline
The Following User Says Thank You to nw3dogs For This Useful Post:
Old 02-09-2019, 01:17 PM   #34
tang's Avatar
Trade: Remodel contractor
Rewards Points: 437
I have a lot of stick levels. A Topcon I bought 25 years ago to do foundations, (very spendy at the time), and a Stanley $50 laser. Would love to win this beauty....
tang is offline
The Following User Says Thank You to tang For This Useful Post:
Old 02-09-2019, 01:52 PM   #35
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 3,906
I have five different levels and one PLS, It would be nice to add another one to my box of tools.
Thanks
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is offline
Old 02-09-2019, 01:56 PM   #36
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 94
6 service trucks all have laser levels, and 4' magnetic levels, We decided to put laser levels in all the trucks when we realized how much easier it is with lasers when installing these doors. (2 guys still holding on to their water levels)
GIVEAWAY: PLS 3G Green Laser Level Kit!-umass-outside.jpg
Kevin
www.BadcoDoors.com
Pearce Services is offline
The Following User Says Thank You to Pearce Services For This Useful Post:
Old 02-09-2019, 03:36 PM   #37
jengebretson2's Avatar
Rewards Points: 26
4 Stabila Sticks, 1 Sola Stick, 1 PLS 180 Red, 1 Leica Laser
Sent from my iPhone using Tapatalk Pro
jengebretson2 is offline
The Following User Says Thank You to jengebretson2 For This Useful Post:
Old 02-09-2019, 03:59 PM   #38
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 298
Between our two crews and myself we have 6 laser levels and about 17 bubble levels.
I actually happen to own the laser this giveaway is for and I think having another one would to keep it company would be great...
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Old 02-09-2019, 05:10 PM   #39
ksc1's Avatar
Rewards Points: 132
A dozen stick levels and a couple of plate levels.
ksc1 is offline
The Following User Says Thank You to ksc1 For This Useful Post:
Old 02-09-2019, 05:19 PM   #40
rblakes1's Avatar
Rewards Points: 3,118
I have one bosch laser and a few Stabila levels. Three bosch is decent but could stand to be upgraded. I use it for cabinets, wainscoting, and tile layout mostly
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Laser Level Accuracy mobiledynamics Tools & Equipment 1 11-05-2013 03:07 PM
Need help choosing the right laser level nymasterfloors Tools & Equipment 23 07-22-2011 07:21 PM
Best rotary self-leveling laser level doc7string Tools & Equipment 17 05-10-2010 02:29 PM
