GIVEAWAY: Festool Helping Light The Way For Santa! - General Discussion - Contractor Talk
Old 12-07-2016, 02:46 PM   #1
Texas Strong
Cricket's Avatar
Trade: Administrator
Rewards Points: 11,934
GIVEAWAY: Festool Helping Light The Way For Santa!-giveaway.jpg
We are so excited to announce that we have partnered with Festool to giveaway a SysLite DUO Plus Work Light 769967 to TWO members!
To enter, simply reply to this thread with your response to the following question.
As a contractor, how do you deal with shorter days and lack of daylight on the jobsite during the winter months?
On December 22, 2016 we will do a random drawing to select TWO winners.
Added Note: Responses to this thread should be limited to entering the giveaway by responding to the posted question.
SysLite DUO-Plus Work Light 769967
Jobsite lighting is more than just putting light in a room. It is about truly seeing the surface you are working on in the correct color without hot spots in the center. The SYSLITE DUO is a hard-wired AC lighting solution with 8000 Lumens projecting an evenly diffused light over 180į with a color temperature of 5000 Kelvin. Being designed for the jobite the SYSLITE DUO is impact and water resistant meeting IP 55 standards for dust and water intrusion.
IP 55 rating against dust and water intrusion coupled with a robust and tough exterior shell and more than ample interior sealing and heat shielding helping to ensure a jobsite-ready and tough light for years to come. All backed by the Festool-exclusive Service All-Inclusive warranty.
Even and wide diffusion (180 degrees) with a color temperature of 5,000 Kelvin brings the closest thing to natural light to the jobsite. 8,000 Lumens of dark-shattering light is provided by two 40 LED banks (80 LED total) rated for 10,000 hours, over 5 years of work (250 days @ 8 hours per day).
Includes the following:
  • SYSLITE Duo
  • SYS TL 3 Systainer
Sponsored by: Festool USA
"Show respect even to people who donít deserve it, not as a reflection of their character, but as a reflection of yours."
Cricket is offline
Old 12-07-2016, 02:52 PM   #2
META's Avatar
Trade: General and Trades
Rewards Points: 7,088
Re: GIVEAWAY: Festool Helping Light The Way For Santa!
I try and start the day with just enough time to do set up during the darker period of the mornings, and begin install work during light.
If we are working late, we roll out the lighting.
META is offline
The Following User Says Thank You to META For This Useful Post:
Cricket (12-07-2016)
Old 12-07-2016, 02:54 PM   #3
Part-Time Wannabe
atypicaltexan's Avatar
Trade: Part-Time Carpentry, AV/Low Voltage Install
Rewards Points: 96
I use a cheap Husky LED portable work light, and I sometimes hold a Nitecore flashlight in my teeth
atypicaltexan is offline
The Following User Says Thank You to atypicaltexan For This Useful Post:
Old 12-07-2016, 03:19 PM   #4
Jager1's Avatar
Trade: Safety
Rewards Points: 2
I adjust the work day as much as possible or when I have to work in poor lighting I make sure reflective clothing is worn if proper lighting can not be made available. Providing the right lighting is the best outcome so the job can get done on time without delay.
Jager1 is offline
The Following User Says Thank You to Jager1 For This Useful Post:
Old 12-07-2016, 03:23 PM   #5
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 492
Lots of different lights, these new led lights are great! I think I may still have one of those old halogen lights I don't use much just to big and clumsy,
Never can have to much light!
This is a great light for portable!
ATTACH]352746[/ATTACH]
GIVEAWAY: Festool Helping Light The Way For Santa!-imageuploadedbycontractortalk1481142035.719907.jpg
Jonbuild is offline
The Following User Says Thank You to Jonbuild For This Useful Post:
Old 12-07-2016, 04:04 PM   #6
CharlieDelta's Avatar
Trade: Carpentry/Building/Remodeling
Rewards Points: 1,794
Staying ahead of the darkness is particularly important for me being that I am a one-man-show. When I can start the day early, as in setup and ready to start just after the sun comes up.
In the instances that things run late and I'm forced to work into the darkness, worklights are my best friends. I've even been known to use my truck headlights when I'm looking for those last few lumens.
CharlieDelta is offline
The Following User Says Thank You to CharlieDelta For This Useful Post:
Old 12-07-2016, 04:49 PM   #7
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 892
Start early. But seeing as how we are electricians, we usually just turn on the lights.
Sent from my SM-G900P using Tapatalk
TxElectrician is offline
The Following 3 Users Say Thank You to TxElectrician For This Useful Post:
Cricket (12-07-2016), DaVinciRemodel (12-08-2016), Jay hole (12-14-2016)
Old 12-07-2016, 04:56 PM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 354
We typically work outdoors, and only 8 hours per day. This time of year, starting at 730 can mean setting up in the dark though. On the really dreary days when we are punching out indoors, I will run one of those strings with the 6 sockets.
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Old 12-07-2016, 05:13 PM   #9
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
I just use clip on lights with a third hand/zipwall poles and garage door opener bulbs...those things take a whining and keep on shining!
GIVEAWAY: Festool Helping Light The Way For Santa!-img_1367a.jpg
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
Cricket (12-07-2016), dibs16 (12-07-2016)
Old 12-07-2016, 05:38 PM   #10
dibs16's Avatar
Rewards Points: 490
Been on a job for 3 mo ths 7-330 everyday no matter what. Its crazy not having to worry about things like this.
BUT we are remodeling 150 baths 6 at a time and the lighting is absolutely horrendous. Keeping track of lights between carpenters, plumbers, electricians, painters, and demo guys gets absolutely nuts.
Great tip on the garage opener bulbs definitely implementing some of those asap
Sent from my SM-G935P using Tapatalk
Anthony
dibs16 is offline
The Following User Says Thank You to dibs16 For This Useful Post:
Old 12-07-2016, 06:09 PM   #11
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
I'm so used to being inside units and dark places using artificial light that sunlight plays little part in anything I'm involved in.
MechanicalDVR is offline
The Following User Says Thank You to MechanicalDVR For This Useful Post:
Old 12-07-2016, 06:11 PM   #12
Stunt Carpenter's Avatar
Rewards Points: 2,748
I try to work indoors through the winter more because of the cold.
For when I work outside I have the big Milwaukee m18 light and a few flood lights on the back of the trailer.
https://builddaley.com/
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 12-07-2016, 06:33 PM   #13
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
I have a ridged set up long cord with plug in's, bulb holders with a cage to protect the bulb and the dumb ass that want to grab it, i buy rough service bulbs.
i also have a couple of tri-pods with halogen bulb lights, i use to cook drywall mud, they are to hot to work under.
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
Old 12-07-2016, 06:50 PM   #14
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,492
We try and adjust our schedule if we can. Usually keep to 8-9 hours a day so it isn't terrible. We have the string of temp lights for interior and a couple of big halogens for outside. In a pinch there is always truck headlights...lol!
overanalyze is offline
Old 12-07-2016, 07:53 PM   #15
cvtsf's Avatar
Rewards Points: 228
I adjust my start time 30 minutes, clean-up in the twilight--even on the winter solstice there is still 9 1/2 hours of daylight in the Bay Area
cvtsf is offline
The Following User Says Thank You to cvtsf For This Useful Post:
Old 12-07-2016, 08:55 PM   #16
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Considering that a lot of our work is interior remodeling, it's not usually an issue as there is power and lights. We use the M18 Flood Lights a lot and I'm planning to get a Duo light if I don't win this one.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
Old 12-07-2016, 09:08 PM   #17
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Certified Building Contractor
Rewards Points: 1,458
Done the halogen thing, junk. Just blew the budget on all new Milwaukee M18 tools and am looking at the stand up lights, but at only 2500 lumes and doing winter time concrete pours. Some times the headlights have to come on and everyone knows how hard it is to finish concrete in the dark. Every little area looks like a huge ripple in your floor until you see it the next day and its all flat as a pancake. Some professional lighting like this would make a world of difference.
Builders Inc. is offline
The Following 2 Users Say Thank You to Builders Inc. For This Useful Post:
Cricket (12-07-2016), Stunt Carpenter (12-07-2016)
Old 12-07-2016, 10:01 PM   #18
weaselbub's Avatar
Trade: Finger Lakes Acoustics
Rewards Points: 12
String up temp. lights like a Xmas tree! Happy holidays to everybody from contractortalk world! I could've used that light when my brother and I sanded this busted up ceiling last week
Sent from my SM-S820L using Tapatalk
weaselbub is offline
The Following User Says Thank You to weaselbub For This Useful Post:
Old 12-07-2016, 11:43 PM   #19
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 352
Hard to stay motivated this time of the year when it's dark and cold. I try to adjust my day to be working in the daylight as much as I can. I also do mostly interior work this time of the year so I use a variety of lighten depending on the job. Longer jobs I have string lights that I use. Otherwise I have a couple smaller lights you plug in that use a standard LED bulb. Have some halogens laying around somewhere but don't use them much at all. Was looking at some LED jobsite lights the other day but they are pretty expensive. Will pick one up sometime in the future.
platinumLLC is offline
The Following User Says Thank You to platinumLLC For This Useful Post:
Cricket (12-08-2016)
Old 12-07-2016, 11:46 PM   #20
Frank Castle's Avatar
Rewards Points: 618
I've been know to use the old over the vanity bathroom fixture I removed on a scrap 2x4 stand with a sacrificial extension cord when I stayed on a job longer than originally planned.
Otherwise, I just use a basic halogen work light when planning on working into the dark.
Come on big money -- Daddy needs a new work light!
Adapt, Improvise, Overcome.
Frank Castle is offline
The Following User Says Thank You to Frank Castle For This Useful Post:
Festool fan club thread BCConstruction Tools & Equipment 7334 05-21-2020 07:25 AM
Light duty TxElectrician Health & Safety 3 08-04-2012 01:04 PM
Long run to light a tennis court VAviaCo Electrical 9 06-13-2012 07:52 PM
Sizing a Pole Light Base 5.4Lariat Architecture & Design 0 05-31-2012 01:45 PM
ceiling fan light won't go on jhcontracting Electrical 11 07-17-2010 08:22 PM
