Generator Enclosure - General Discussion - Contractor Talk
Generator Enclosure
Old 10-31-2012, 07:28 AM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 10,280
Generator Enclosure
Since I went out and splurged on a genny for sandy, I figure I need to put together an enclosure for it. Does anyone have any tips or good ideas for a good enclosure? It is going to go on a concrete slab in a wood framed enclosure. I have a 2" conduit in the ground to house to my transfer switch. Thanks, Nick.
Morning Wood is offline
Old 10-31-2012, 10:49 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 620
Re: Generator Enclosure
Exhaust vent directly outside.
Plenty of air intake...
Leave enough room for air circulation for cooling.
griz is online now
aptpupil (10-31-2012)
Old 10-31-2012, 11:47 AM   #3
Handymen are people too
realelectrician's Avatar
Trade: electrician
Rewards Points: 356
Build a simple canopy type structure to protect it from rain. Use lattice for the walls so it gets plenty of air flow.
realelectrician is offline
Old 11-01-2012, 09:37 PM   #4
Box Builder
I like the lattice wall idea. But it isn't practical for my application. The genny will live in here most of the time and it has to be secure and out of the elements. It is going to be a bit tough to pipe exhaust directly outside but I think I can do it. I'll have to get some parts and do some welding. I'm actually thinking about jalousie windows. But I'd like to do shutter instead of glass. Close them when not in use, and open them when running the genny. Anyone know if it's possible to buy the hardware only? Might be better off buying windows, removing the glass and putting slats in instead. If I made the walls louvers and screened them inside do you think snow would blow in through the louvers?
Old 11-01-2012, 10:45 PM   #5
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
One of the other guys here uses this.
http://www.amazon.com/Suncast-GS2000...+can+enclosure
-Dennis
WarriorWithWood is offline
Old 11-01-2012, 11:07 PM   #6
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,034
If you run the exhaust very far I would be sure to up size the pipe. Even if only a couple of feet.
Randy Bush is offline
