General Rules For Building Headers... - General Discussion - Contractor Talk
Old 08-08-2019, 02:24 PM   #1
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Rewards Points: 180
I'm going to be removing part of a supporting wall, so needless to say I'll be putting in a header.
It's spanning about 8 feet, and I've always heard/read that a good, easy to remember rule is that a header built with 2 by Xs, will support X feet of span. So 2x6, 6 feet....2x8, 8 feet, and so on. Does that seem about right? I don't want to underbuild by any means, but I don't necessarily want to WAY overbuild either.
Thoughts....
Jim P.
jproffer is online now
Old 08-08-2019, 02:29 PM   #2
rrk's Avatar
Rewards Points: 3,464
Re: General Rules For Building Headers...
You are mistaken
rrk is online now
The Following 4 Users Say Thank You to rrk For This Useful Post:
Golden view (08-08-2019), greg24k (08-08-2019), griz (08-08-2019), hdavis (08-08-2019)
Old 08-08-2019, 02:47 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 674
never heard of such a rule.
depends on the load it is carrying.
don't forget footings.
griz is online now
The Following 3 Users Say Thank You to griz For This Useful Post:
Golden view (08-08-2019), greg24k (08-08-2019), hdavis (08-08-2019)
Old 08-08-2019, 04:32 PM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,478
Like others said, there is no such rule...Each header is calculated based on the load it will support.
greg24k is offline
Old 08-08-2019, 04:39 PM   #5
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 944
You want to overbuild a header. The more overbuilt, the less everything else it's carrying bounces. But as others have already stated, there is no "rule of thumb" for this. A lot of times it's pretty easy to figure out and you can do so with span tables for LVL manufactures. Other times you'll have to have it engineered which could be as simple as giving the span of the joists it's carrying, how many floors above, roof loads, point loads, etc and having someone run beam calc software.
EricBrancard is online now
Old 08-08-2019, 05:41 PM   #6
jproffer's Avatar
Rewards Points: 180
Thank you guys. It didn't sound right to me, but...I mean, it was on the internet right? SO......ya know.
Anyhow, thanks a lot. I'll do some more thorough calcs and see what I come up with.
Jim P.
Old 08-08-2019, 06:07 PM   #7
Texas Wax's Avatar
Rewards Points: 1,990
Up in your neck of the woods, old rule of thumb was dbl doug fir#2 or better 2x6 or 4x4 was good to 3-4' exterior. 2x8 dbl 4-6', 2x10 8-12' and 2x12 12-16'. Generally carried for bearing walls on interiors. HOWEVER, those rules don't hold or may not apply anymore. Have to check load and span tables across species or type of engineered lumber such as LVL.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 08-08-2019, 07:35 PM   #8
hdavis's Avatar
Rewards Points: 2,172
I've actually heard the same thing, but it doesn't match up with reality. Maybe for non-loadbearing.just to prevent sagging from the material's weight.
hdavis is online now
jproffer (08-08-2019)
Old 08-08-2019, 08:12 PM   #9
jproffer's Avatar
Rewards Points: 180
Maybe I misunderstood when I read that. Thanks for that info.
Jim P.
Old 08-08-2019, 08:41 PM   #10
hdavis's Avatar
There is no telling what it really was. I still see some shed's roofs framed on the flat with 2X4 with 8' span. We have decent snow loads. People used to do some crazy stuff, some still do.
Old 08-08-2019, 08:48 PM   #11
diplomat
Golden view's Avatar
Rewards Points: 704
IRC code book has header tables based on house width, number of floors and snow load, If I remember correctly. Last time I read it was 2009. Now everything is called out by my architect on the plans, so I don't have to know anything.
Golden view is offline
Old 08-08-2019, 10:28 PM   #12
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,048
I've heard that rule but it was with solid 4x material. It's been probably 25 years since I've heard that thrown around. 4x4 4' 4x6 6' etc. But it doesn't make since because there is no set weight. Every building is different and the loads are different. So it needs to be calced.
Mike.
_______________
Calidecks is online now
ScipioAfricanus (08-09-2019)
Old 08-08-2019, 10:30 PM   #13
GC/carpenter
Calidecks's Avatar
We can't use built headers anymore. They either need to be solid or engineered.
Mike.
_______________
hdavis (08-08-2019)
Old 08-08-2019, 10:39 PM   #14
Dirtywhiteboy's Avatar
Rewards Points: 13,082
Mike.
_______________
We always use 4X material also. I've never seen 2x built headers.
Dirtywhiteboy is offline
Calidecks (08-08-2019)
Old 08-08-2019, 10:42 PM   #15
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,012
Mike.
_______________
Who can't?
Cali, or your area?
Old 08-08-2019, 10:44 PM   #16
Trade: Highwayman
What are you doing for 2x6 walls?
4x Furred out?
Old 08-08-2019, 10:59 PM   #17
GC/carpenter
Calidecks's Avatar
Originally Posted by Seven-Delta-FortyOne View Post
Who can't?
Cali, or your area?
Not sure because I've only framed in my area. But we haven't been able to use built headers in years.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Rio (08-09-2019), Seven-Delta-FortyOne (08-09-2019)
Old 08-08-2019, 11:00 PM   #18
GC/carpenter
Calidecks's Avatar
4x Furred out?
Yep. Add a2x6 to the bottom of the header, flat.
Mike.
_______________
Old 08-08-2019, 11:01 PM   #19
GC/carpenter
Calidecks's Avatar
Or engineered.
Mike.
_______________
Old 08-08-2019, 11:23 PM   #20
4x Furred out?
Yes ,, what mike said 2x6 on the bottom or fur the bottom of the header and a lot of times the plans call for a 6x header.
