Gap Around Chimney - Need HELP! - Page 2 - General Discussion - Contractor Talk
Old 05-31-2015, 01:49 PM   #21
A-1 Interiors's Avatar
Trade: Home Improvement
Rewards Points: 298
Re: Gap Around Chimney - Need HELP!
Originally Posted by slowsol View Post
Spray Foam. A lot of SPRAY FOAM!!
nah flex seal
A-1 Interiors is offline
Old 05-31-2015, 02:07 PM   #22
slowsol's Avatar
Rewards Points: 2,248
Originally Posted by A-1 INTERIORS View Post
nah flex seal
Gotta put the spray foam in first. Then Flex Seal!
-John
slowsol is offline
Old 05-31-2015, 03:01 PM   #23
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
mason and a helper is the only way to fix it
Tom Struble is offline
Old 06-02-2015, 09:52 AM   #24
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
...then distressed paint it.
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 06-02-2015, 09:52 PM   #25
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,992
My chimney is constructed in the same way, free standing.
It became a home for bats.
Another story. And a good one.
I closed it off with 2x2 cut on a 45. Gap around Chimney - need HELP!-imageuploadedbycontractortalk1433299931.811756.jpg
Okay it needs painting.
B.D.R. is offline
Old 06-07-2015, 09:54 AM   #26
PatChap's Avatar
Trade: Roofing, eaves
Rewards Points: 132
I closed it off with 2x2 cut on a 45. Attachment 189450
Looks like you need kickouts at the bottom of your chimney steps. Very simple to add.
PatChap is offline
Old 06-07-2015, 01:24 PM   #27
B.D.R.'s Avatar
Not sure what that is.
What is the reason?
B.D.R. is offline
Old 06-07-2015, 07:53 PM   #28
Knight-Builder's Avatar
Trade: Builder
Rewards Points: 526
What is the reason?
Pat's referring to kickout flashing added to the bottom of the step flashing used on chimneys where they meet the roof plane. They kick moisture sideways so it doesn't run down the chimney (presumably the cause of the moisture showing on the blocks in your pic - unless it's driven rain).
Knight-Builder is offline
Old 06-14-2015, 04:59 PM   #29
B.D.R.'s Avatar
That particular side of my house gets the direct weather, driving rain and or direct sun.
Not sure anything would protect it.
B.D.R. is offline
Paint over block chimney 2low4nh Masonry 5 07-14-2014 10:40 PM
Flashing a stone veneer chimney. PatChap Roofing 7 04-02-2013 12:19 PM
Adding a new chimney on an existing house Desdevinc Masonry 7 03-20-2011 11:14 AM
Flue cap GettingBy HVAC 11 02-14-2011 04:46 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 08:35 PM
