Gap Around Chimney - Need HELP! - General Discussion - Contractor Talk
Old 05-29-2015, 07:08 PM   #1
naturemanmh's Avatar
Trade: Floor Tile
Rewards Points: 8
Hello all!!
I am doing the floor tile for a customer who has a home with a large gap surrounding a chimney. She asked me to close the gap so it looks good AND to help reduce heating/cooling leaks. This is a large gap going straight into her attic. Nice home and I am not good with exterior work.
Please take a look at the picture and offer any ideas...I would greatly appreciate it!! I was thinking to continue to wrap the soffit behind the chimney but there is nothing to tie into against the chimney.
Thanks!!!
naturemanmh is offline
Old 05-29-2015, 08:36 PM   #2
TimNJ's Avatar
Rewards Points: 5,784
Re: Gap Around Chimney - Need HELP!
You need to put some braces on that to re-attach to the wall.
TimNJ is offline
Old 05-29-2015, 09:11 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 554
Doesn't look like it was ever attached to the wall. First time I've ever seen vinyl siding passing behind a chimney.
Tinstaafl is online now
Old 05-29-2015, 09:21 PM   #4
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
If it goes into her attic, how can there be heat loss?
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
Old 05-30-2015, 07:09 AM   #5
Trade: Floor Tile
Rewards Points: 8
You are correct...it was never attached to the wall to begin with. I think they had a peice of metal flashing just covering it up but came off over the years.
What would you recommend using for me to mount onto the back of the chimney so I can attach some kind of metal to the other side where the wall is?
Old 05-30-2015, 07:28 AM   #6
AmeliaP's Avatar
Trade: Masonry
Rewards Points: 1,624
Can you access that spot from the inside? That might be easier.
www.BillPearnMasonry.com
AmeliaP is offline
Old 05-30-2015, 07:39 AM   #7
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
I'd say the chimney was built later after the house and they just maintained a safe airspace from the combustibles. You need to go ahead and cut the siding out, break trim coil on a 90 to cover the gap, install a J channel, it will look fine.
brickhook is offline
The Following 2 Users Say Thank You to brickhook For This Useful Post:
dom-mas (05-31-2015), fjn (05-30-2015)
Old 05-30-2015, 07:41 AM   #8
slowsol's Avatar
Rewards Points: 2,248
Spray Foam. A lot of SPRAY FOAM!!
-John
slowsol is offline
The Following 2 Users Say Thank You to slowsol For This Useful Post:
Anti-wingnut (05-30-2015), Morning Wood (05-30-2015)
Old 05-30-2015, 07:49 AM   #9
brickhook's Avatar
Trade: masonry
The only place you need to insulate is the gap at the soffit, mostly to keep the critters out...
Old 05-30-2015, 08:27 AM   #10
Trade: Floor Tile
Rewards Points: 8
You seem to have the most knowlede on this vs the other replies. Sorry for the stupid question, but what do you mean by cutting the vinyl siding out and breaking the trim coil? Is there a way you can send links to a photo or product?
Old 05-30-2015, 08:44 AM   #11
brickhook's Avatar
Trade: masonry
Your question isn't stupid at all. I'm sure everyone does things differently, but what I was talking about is the way people do it around here.
There isn't anything wrong with the picture you posted other than the gap in the soffit, which you can stuff insulation in, and it's not to pretty.
To make this look better, I would cut the vinyl up beside the chimney so when you break your metal on a 90 degree angle you can slide the metal underneath. Then attach your J channel, so you can finish out your siding.
This isn't very expensive, just takes a lil time, and I think you will be happy with the end results.
I will go through my pictures to see if I have any that might help you out.
Old 05-30-2015, 08:56 AM   #12
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,437
Lucky they don't have squirrels and birds in the attic already. That's the reason to close it, not heat loss.
MarkJames is online now
CO762 (05-30-2015)
Old 05-30-2015, 09:31 AM   #13
CO762's Avatar
I think it looks sort of cool, as a 'stand alone'. It's not inside the building envelope (other than below) so won't conduct.
You're right, the gap is nothing but a soffit vent and hopefully we don' t close those off...provided the attic is vented, provided there's insulation between the living area and the attic, provided the attic isn't a living space, provided....
CO762 is offline
Old 05-30-2015, 12:55 PM   #14
CHB70's Avatar
Trade: Roofing, Siding, Gutters
Rewards Points: 91
Here is a pic I found on google that shows what Brickhook was describing you could do.
The difference being the siding is not ending in a channel.
You can also install a continuous flashing that would eliminate all those seams.
RSC Builders, Inc
Complete Roof
RSC Builders
CHB70 is offline
The Following User Says Thank You to CHB70 For This Useful Post:
brickhook (05-30-2015)
Old 05-30-2015, 02:21 PM   #15
CO762's Avatar
As the official, unelected grand pubah of the Style Council, I must deduct 5 points for your offense. The only thing that goes well with plastic is, well, nothing but plastic, so the standoff rule remains in effect.
CO762 is offline
Old 05-30-2015, 04:47 PM   #16
Knight-Builder's Avatar
Trade: Builder
Rewards Points: 526
When brickhook says 'break... 90 degress,' it means neatly bending a piece of rolled flashing/metal (trim coil) on a metal break (a great piece of equipment that makes nice neat and even bends in sheet metal)
Knight-Builder is offline
The Following User Says Thank You to Knight-Builder For This Useful Post:
Old 05-30-2015, 05:01 PM   #17
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i would bet the were 2 layers of siding previously,most likely a wide exposure cedar shake then aluminum over that before the chimney was built,removed down to the sheathing when the vinyl was installed
Tom Struble is offline
Tom M (05-30-2015)
Old 05-30-2015, 11:46 PM   #18
AGullion's Avatar
Rewards Points: 1,422
Well, it looks like someone has possibly done an addition at some point ...not sure how that's set up, but I have several thoughts.
1. Don't be afraid to say no. Not sure your specialty (s) but that's a good pretty good stretch for a tile guy in some cases.
2. If its safe, and supported, brick could possibly be added. Still , going next to dutch lap vinyl , its not ideal .
3. The best solution is terminating the vinyl, breaking metal to the brick with a hemmed edge.
AGullion is offline
Old 05-31-2015, 06:05 AM   #19
builditguy's Avatar
Rewards Points: 1,964
I think you should consider passing on this project. By your own posts, it's not really your thing.
Once a lady wanted me to repair a crack in her brick house. I did the best thing for both of us. I recommended someone else. She became very upset. She wanted me to do the work. I explained it wasn't something I was very good at and neither of us would be happy with the results. She persisted until I said, "If your car was broke down, you wouldn't hire me to fix it because I'm not a mechanic. You need to hire a mason." Instantly she understood. 3 years later she's gotten over it.
builditguy is offline
Old 05-31-2015, 09:55 AM   #20
AGullion's Avatar
Well said.
AGullion is offline
Paint over block chimney 2low4nh Masonry 5 07-14-2014 10:40 PM
Flashing a stone veneer chimney. PatChap Roofing 7 04-02-2013 12:19 PM
Adding a new chimney on an existing house Desdevinc Masonry 7 03-20-2011 11:14 AM
Flue cap GettingBy HVAC 11 02-14-2011 04:46 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 08:35 PM
