Frozen Air - General Discussion - Contractor Talk
Frozen Air
Old 12-31-2009, 01:24 PM   #1
kubie's Avatar
Trade: general contractor
Rewards Points: 278
Frozen Air
just wondering on what you all do to keep your air lines from freezing.
i have been taking the guns and hoses home, but the compressor is way to big and heating the trailer is out of the question.
antifreeze in the hoses works sometimes, but ruins the guns
kubie is offline
Old 12-31-2009, 02:44 PM   #2
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: Frozen Air
Here is what we do and did.
Buy air filter and lube regulator( cheap works as well as the expensive)
Then fill the lube side with tool air oil with antifreeze inthe product.
We have used this method for years with very little line freeze ups. Occasionally we get freeze up at the connectors, but no more frozen air lines. The water serperator keeps the water out of the lines, for the most part, and the tool oil keeps everything lubed up!!
Framer53 is offline
Old 12-31-2009, 02:51 PM   #3
Cjeff's Avatar
Trade: Renovations
Re: Frozen Air
I had a framing nailer freeze up once. The drain plugs on the compressor freeze occasionally.
I try to leave the compressor and nailers inside at night at the job if possible.
Cjeff is offline
Old 12-31-2009, 03:00 PM   #4
Aframe's Avatar
Trade: Carpenter/GC
Rewards Points: 550
Re: Frozen Air
We were dealing with the cold this week also. We have our small compressor in the basement of the house with the hose coming out of a window,
I put on my carhart insulated suit, take the hose and run it up the pant leg, wrap it around my body a few times and send it out my sleeve with only a couple of feet looped to the gun seems to work ok
But really, used my new strap shot gun this week and it would not cycle properly. Either the cold or just getting used to the gun. So we set the gun inside for a while and reduced the amount of hose exposed outside to as little as needed.
Got it working properly and was very happy about it.
Aframe is offline
Old 12-31-2009, 03:11 PM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Frozen Air
was talking about air dryers on another forum and apparently the farther away from the compresser the better they work
Tom Struble is offline
Old 12-31-2009, 05:08 PM   #6
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Re: Frozen Air
add brake line antifreeze to the air tank. drain the pressure from the tank before opening it up. :P
jlhaslip is offline
Old 01-01-2010, 11:14 AM   #7
fast fred's Avatar
Trade: carpentry
Rewards Points: 836
Re: Frozen Air
build a plywood or osb box put a small elec heater in there and keep it warm. A few drops of air tool lube in the male end will help.
Built one box next to the power pole and left it there all winter with the compressor inside. Drained it once a week and had to dig it out of four feet of snow in the spring to drag it back to the car when the job was done.
I laughed at one of my mentors when I was going through his tool box and found a pink hair dryer. the other co workers told me it was to dry off his back when it was all hot in summer. I razed him all day till he jumped on me and told me I'm not **** because any carpenter who works in the mountains needs a hairdryer and would know why. Well that winter I went out and bought my first hair dryer and people laugh at me when I pull it out of my tool box in the middle of winter. But then they see how it solves almost any problem.......
We have all kinds of problems @ 9000 ft.
fast fred is offline
Old 01-01-2010, 11:24 AM   #8
Trade: siding
Rewards Points: 20
Re: Frozen Air
i always carry an old heat gun when it starts to get cold
mostly to warm my fingers....feels so nice
Old 01-01-2010, 11:27 AM   #9
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Re: Frozen Air
Just as onthe other forum, I call BS. Totally unecessary! Works if it is attached or 100' away. In fact, the warmer the air the more water is compressed therefore I say just the opposite.
Don't like to fight over there!
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
Tom Struble (01-01-2010)
Old 01-01-2010, 11:34 AM   #10
Trade: siding
Rewards Points: 20
Re: Frozen Air
thats why i say words like apparently and maybe....i don't no nothin
Old 01-01-2010, 11:37 AM   #11
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Re: Frozen Air
[quote=kubie;840172]just wondering on what you all do to keep your air lines from freezing.
Bid on interior work during the winter months.
Paulie is offline
Old 01-01-2010, 07:40 PM   #12
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Frozen Air
There is a air product called killfrost. Use that and keep the compressor warm overnight. How is heating the trailer out of the question? If you heat it all night you really wont need to heat it while it is running.
RobertCDF is offline
Old 01-01-2010, 07:46 PM   #13
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
Re: Frozen Air
Stay home when temperature is below 40, or move south.
mudpad is offline
Old 01-01-2010, 10:56 PM   #14
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Frozen Air
I very raely get frozen pipes or compressor but when i do i just stick my small stanley heater infront of the compressor and warm it up for 5 mins before i start.
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 01-02-2010, 09:07 AM   #15
carpenter72's Avatar
Trade: carpentry
Rewards Points: 25
Re: Frozen Air
When we build new homes in the winter, we take half inch foam and make a box around the compressor which works great, and If we kept the hoses out of the snow they wouldnt freeze up on us.
carpenter72 is offline
Old 01-02-2010, 10:21 AM   #16
kubie's Avatar
Rewards Points: 278
Re: Frozen Air
well the trailer isnt mine. the general contractor has us use his compressor. theres only temp power on the jobsite with 2 breakers. i doubt the gen will pay the elect bill for heating his trailer.
thanks for all the ideas guys
kubie is offline
Old 01-03-2010, 01:06 AM   #17
RobertCDF's Avatar
Re: Frozen Air
All of our customers pay to heat our trailers, weather they be GC's or homeowners. Warm tools work better, if the GC wants you guys to work and get the job done then he should heat the trailer.
Old 01-03-2010, 01:31 AM   #18
13 Licenses & Counting
piercekiltoff's Avatar
Trade: Water well drilling & pumps
Rewards Points: 168
Re: Frozen Air
Run bigger compressors - output on this is at about 185 degrees F.
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook
Monroe, Washington, (360)-794-7300
Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA
piercekiltoff is offline
Old 01-03-2010, 09:42 AM   #19
kubie's Avatar
Rewards Points: 278
Re: Frozen Air
that would be nice. right now our guns are just nail starters. lol
kubie is offline
Frozen condensate lines flashheatingand HVAC 20 01-26-2011 09:21 PM
Hi from frozen WI RNR53901 New Member Introductions 5 12-20-2009 06:29 PM
Roof repairs in the frozen northwest cowboyremodeler Roofing 12 02-03-2009 09:26 AM
Frozen Mud? IBUILD Drywall 12 03-27-2007 09:45 PM
9:39 Chat frozen? denick Excavation & Site Work 5 02-23-2007 07:06 AM
