French Door Syndrome - Page 2 - General Discussion - Contractor Talk
Old 01-16-2019, 10:50 PM   #21
J.C.'s Avatar
Rewards Points: 162
Re: French Door Syndrome
Cheaper than tearing the house down and trying again with thicker doors. I would think you could also probably get most others locks to work with some careful trimming with a bandsaw.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 01-16-2019, 11:24 PM   #22
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,357
You're probably right, especially since I served time in a machine shop in one of my previous lives.
I used to do all sorts of things the experts said couldn't be done. Then I got old and only do that stuff now when I'm being paid for it. Sometimes.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
B.D.R. (01-20-2019), Xtrememtnbiker (01-17-2019)
Old 01-17-2019, 07:28 AM   #23
TimNJ's Avatar
Rewards Points: 4,494
Originally Posted by Big Johnson View Post
What, do you think Tin has to open both to get his wife in and out of the kitchen?
I didn't say that
TimNJ is offline
Old 01-17-2019, 07:48 AM   #24
Tom M's Avatar
Rewards Points: 3,538
Some great ideas with magnets and even a closers.
Outside of double closet doors I stay away from ball and catch. They bump around even if you adjust the screw / ball height to make tighter.
Where possible I add an astragal but you need to an extra inch in your rough opening. You should still be able to mortise head and foot latches to stabilize one side. That will help.
I made a wall of glass to create an office by a front door.
French door syndrome-hall-side-door-finished.jpg   French door syndrome-hall-before.jpg
Tom M is online now
Old 01-17-2019, 08:42 AM   #25
Lettusbee's Avatar
Rewards Points: 848
Quick and dirty would be surface mount head and foot latch.
I'd probably stick with the emtek plan though.
Lettusbee is offline
Old 01-17-2019, 09:00 AM   #26
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,102
I think you could get away with just a foot latch, especially on a 24” panel.
What’s the Emtek plan? I can’t find it.
Big Johnson is offline
Old 01-17-2019, 11:12 AM   #27
fred54's Avatar
Trade: contractor
Rewards Points: 228
totally unrelated and as usual no help but if you're kitchen is so tight what do you do about range hood make up air?
Also I hate French doors. they look nice but are almost always a pain.
See? No help!
fred54 is offline
Old 01-17-2019, 11:55 AM   #28
Texas Wax's Avatar
Rewards Points: 1,662
So you are opposed to, not contemporary enough, the standard surface mount cane bolt(s), an astragal stop and standard operating passage lock?
Two long drywall screws, hang a drill with charger nearby for easy access and you got it licked! Take the cat a few years to figure out to use that. Tho wife, maybe not so much so
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Tinstaafl (01-17-2019)
Old 01-17-2019, 02:18 PM   #29
VinylHanger's Avatar
Rewards Points: 10,338
Add some ventilation.
VinylHanger is online now
Old 01-17-2019, 06:46 PM   #30
Capra aegagrus
Tinstaafl's Avatar
Actually, the french doors are the weak point in that tightness.
But seriously, we usually crack a window if we need max air flow.
I'm not picturing how an astragal stop would make a standard latch fit. Unless you made the astragal 3-4" wide.
Don't care for surface mount bolts--this isn't a shed or a garden gate. I'd have no problem with putting a pair of flush mount bolts in the inactive door.
As for cat vs wife... not gonna go there in case she sees this post.
Old 01-17-2019, 08:26 PM   #31
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 276
Maybe just wedge one of them shut until you need to use it
Rooster Cogburn is offline
Old 01-17-2019, 08:28 PM   #32
Old 01-17-2019, 08:42 PM   #33
rrk's Avatar
Rewards Points: 1,650
Cremone bolts
rrk is online now
SmallTownGuy (01-17-2019)
Old 01-17-2019, 08:44 PM   #34
Fire up the BBQ
griz's Avatar
Rewards Points: 2,354
how about a flush top bolt?
https://www.doorware.com/site/product.cfm?id=158906
griz is online now
Old 01-17-2019, 08:59 PM   #35
Capra aegagrus
Tinstaafl's Avatar
Sure. Heck, I could use TW's drywall screw for the inactive door. For the active one, I just wanna turn a knob and open the door.
Life's too complicated.
Texas Wax (01-18-2019)
Old 01-17-2019, 09:00 PM   #36
John the Builder
SmallTownGuy's Avatar
Rewards Points: 8,226
Originally Posted by rrk View Post
Cremone bolts
YES. And some of them are damned beautiful and a work of art to behold mechanically.
SmallTownGuy is online now
Old 01-17-2019, 09:41 PM   #37
Box Builder
Morning Wood's Avatar
Rewards Points: 9,718
See? No help!
Crack a window as close as possible or install a range hood with make up air
Morning Wood is offline
Old 01-18-2019, 07:59 AM   #38
rrk's Avatar
But can be costly
rrk is online now
Old 01-18-2019, 12:57 PM   #39
Texas Wax's Avatar
This what I meant by traditional. Good heafty 5/8" - 3/4" x1 1/4" + wide stop applied to the fixed panel.
or a true "astragal" molding, bought or milled.
Fix the panel how ever you want and install the passage lock just like any other lock, viola operational door just like an operational door.
Tinstaafl (01-18-2019)
Old 01-18-2019, 01:33 PM   #40
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,474
That's what I used a few years ago for some customers that had the same problem. Installed one on the top and one at the bottom...worked beautifully.
Mine attached to the outside of the door.
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
Glaze/Putty REPAIR-ABLE French Doors & Windows ??? Tarh331_Dad Windows, Siding and Doors 8 03-03-2017 03:30 PM
French Drain into Solid Drain catahoula Excavation & Site Work 4 07-22-2013 08:02 PM
Wet basement french drain vs. footer drain moorewarner Excavation & Site Work 20 03-21-2010 07:30 PM
