Framing Problem - General Discussion - Contractor Talk
Framing Problem
Old 07-09-2019, 08:30 PM   #1
Mike010's Avatar
Trade: Siding
Framing Problem
I am a young siding guy, just married, trying to build our first home. I have a relative that is supposed to be a framer that started framing the exterior wall on the walkout basement. When the wall was stood up there was a 1.5” gap between the top plate and top of the 2x6 wall. So it’s too short unless there is a second plate added. Will it pass inspection with what is essentially two top plates or will it have to be torn out and rebuilt.
Mike010 is offline
Old 07-09-2019, 09:01 PM   #2
TheConstruct's Avatar
Rewards Points: 996
Re: Framing Problem
Hard to say what's going on without a picture but a double top plate is almost exclusively how walls are framed, especially exterior walls. A double top plate allows a lot more flexibility with where the framing members above, joists, rafters or trusses land.
TheConstruct is online now
The Following 3 Users Say Thank You to TheConstruct For This Useful Post:
BlueRidgeGreen (07-09-2019), fjn (07-10-2019), hdavis (07-09-2019)
Old 07-09-2019, 11:31 PM   #3
hdavis's Avatar
Rewards Points: 2,750
Re: Framing Problem
I'm guessing he was planning on standing and bracing the wall in position, then use the second top plate to tie into the rest of the framing. Can't tell without a pic.
hdavis is online now
Calidecks (07-10-2019), TheConstruct (07-10-2019)
Old 07-09-2019, 11:41 PM   #4
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 3,488
Re: Framing Problem
It will pass with two top plates.
It may not pass with one.
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson
BlueRidgeGreen is online now
The Following 3 Users Say Thank You to BlueRidgeGreen For This Useful Post:
hdavis (07-09-2019), tgeb (07-10-2019), TheConstruct (07-10-2019)
Old 07-10-2019, 05:42 AM   #5
woodspike's Avatar
Rewards Points: 566
Re: Framing Problem
in south florida , you`d have to double plate , and also have a strap-tie , or hurricane strap on exterior walls
( look them up)they`re only $1 - $2 each
put a double plate , and /or all you`d have to do is call or go see inspector , and ask
but i`d also ask about the straps ,
it holds everything together , and makes the wall studs , and top plate all one unit
woodspike is offline
Old 07-10-2019, 09:43 AM   #6
META's Avatar
Trade: General and Trades
Rewards Points: 3,306
Re: Framing Problem
Bearing members would need to be stacked directly over studs on a single plate. Rigidity of exterior walls is reduced when using one top plate, unless cross building members are connected properly. Gable walls may have significant movement without bracing at the top of the walls in the truss area, especially at upper plate breaks.
META is online now
